Best fit three-sphere radius 130 gly (after Ned Wright)
In summary, Ned Wright's recent paper suggests that the best fit for Omega, the measure of the density of the universe, is 1.011. This is only slightly better than the fit for an exactly flat universe with Omega at 1. However, if we were to take this best fit literally, we can imagine the universe as a bumpy dimply three-sphere with a radius of curvature of 130 billion light years. This is based on a formula given in George Smoot's lecture notes, which uses the Hubble length and the difference between Omega and 1. Wright's paper also discusses the constraints on dark energy from various measurements, and suggests that a flat universe is still consistent
marcus
Dearly Missed
24,775
792
In his most recent, Ned Wright gives the best fit Omega as 1.011.
He hastens to say that since the fit is not all that better than for Omega exactly 1, space being flat infinite, one cannot rightfully conclude that Omega > 1.
However suppose, simply as an intellectual exercise, that one were to take this best fit Omega literally on its own terms. Imagine that the U really is as Wright has determined.
Then we imagine space as a bumpy dimply THREE-SPHERE, and the radius of curvature, or the actual fourspace RADIUS if you like to picture the threesphere living in a boyscout Euclid fourspace, is 130 BILLION LIGHT YEARS.
Try it on, and if you like the fit, wear it. :smile:
Space news on Phys.org
The formula in George Smoot's lecture notes
George Smoot has sometimes taught Physics 139 at Berkeley, an advance undergrad course in Spesh-and-Gen Relativity with supplemental Cosmology.
You can get his notes if you google "smoot notes geometry universe"
The notes give a simple formula for the radius of curvature. It is incredibly simple but let's try it. At least this will give a first approximation.
You just take the HUBBLE LENGTH which we usually say is 13.8 gly, and you divide it by a factor which is sqrt(Omega - 1). that is all.
If we use the best fit Omega of 1.011, then Omega - 1 is 0.011
and the square root is 0.105
and if you divide 13.8 billion lightyears by 0.105 you get
So if we live in a threesphere, and you want to picture it contained in boyscout fourspace, and as having a radius, this is a possible guess about the radius.
If I have made a mistake in reading Smoot's notes or in calculating please let me know :smile:
The Ned Wright paper that I am having fun with is mentioned here:
https://www.physicsforums.com/showthread.php?p=1220828#post1220828
marcus said:
New Wright's new paper
just came out
http://arxiv.org/abs/astro-ph/0701584
discussion section page 14:
"Using all the data together
gives the plot shown in Figure 5. The best fit model is slightly closed with
Omega_tot = 1.011 and M = 0.315. "
Wright is an WMAP princ. investigator.
Here is Wright's paper
Constraints on Dark Energy from Supernovae, Gamma Ray Bursts, Acoustic Oscillations, Nucleosynthesis and Large Scale Structure and the Hubble constant
Edward L. Wright (UCLA)
16 pages, 8 figure
"The luminosity distance vs. redshift law is now measured using supernovae and gamma ray bursts, and the angular size distance is measured at the surface of last scattering by the CMB and at z = 0.35 by baryon acoustic oscillations. In this paper this data is fit to models for the equation of state with w = -1, w = const, and w(z) = w_0+w_a(1-a). The last model is poorly constrained by the distance data, leading to unphysical solutions where the dark energy dominates at early times unless the large scale structure and acoustic scale constraints are modified to allow for early time dark energy effects. A flat LambdaCDM model is consistent with all the data."
the initial announcement of WMAP3 "implications for cosmology" paper by Spergel et al already contained hint of this.
warning: it doesn't prove anything. the INFINITE FLAT universe is still consistent, it just is not the best fit. the best fit is with nearly spatially flat, slight positive spatial curvature and therefore the best fit is spatially finite.
flat would be Omega = 1.00 exactly, the best fit is Omega = 1.011
However as Ned Wright is careful to say: a flat model is "consistent" with the data
1. What is the significance of the "best fit three-sphere radius 130 gly (after Ned Wright)"?
The "best fit three-sphere radius 130 gly (after Ned Wright)" refers to a specific measurement and calculation performed by astronomer Ned Wright. It represents the radius of a hypothetical three-dimensional sphere that best fits the observed data points, and is often used to determine the curvature of the universe.
2. How was the "best fit three-sphere radius 130 gly (after Ned Wright)" determined?
To find the "best fit" radius, Ned Wright used a method called the Three-Sphere Fit, which involves fitting a three-dimensional sphere to a set of data points and adjusting the radius until it best matches the observed data. This calculation takes into account the curvature of space and the observed distances between celestial objects.
3. Why is the "best fit three-sphere radius 130 gly (after Ned Wright)" important in astronomy?
The "best fit three-sphere radius 130 gly (after Ned Wright)" is important in astronomy because it can help us understand the shape and curvature of the universe. By measuring the curvature of space, we can gain insights into the expansion and evolution of the universe, as well as the distribution of matter and energy within it.
4. Is the "best fit three-sphere radius 130 gly (after Ned Wright)" a constant value?
No, the "best fit three-sphere radius 130 gly (after Ned Wright)" is not a constant value. It can vary depending on the data and method used for calculation. Additionally, our understanding of the universe's curvature is constantly evolving, so the "best fit" radius may change as new data and theories emerge.
5. How does the "best fit three-sphere radius 130 gly (after Ned Wright)" relate to the age of the universe?
The "best fit three-sphere radius 130 gly (after Ned Wright)" does not directly relate to the age of the universe. However, it is often used in conjunction with other measurements and calculations to estimate the age of the universe. By understanding the curvature of space, we can better determine the rate of expansion and therefore the age of the universe.
