Colliding Black Holes: Will the Smaller Get Pulled In?
In summary, the smaller black hole would be pulled into the larger one due to their mutual gravitational attraction, just like the moon is pulled towards the Earth. This process of merging would result in a single, more massive black hole. The collision would go through three distinct stages: the plunge, merger, and ringdown. Each stage has its own complexities and can be studied through numerical modeling and approximations of general relativity. However, neither black hole would decompose, they would either merge or continue on their own paths depending on their mass and velocity.
Worzel
I am sure this must have been asked before but here goes.
If two black holes were on a collision course with each other or would pass close to each other. Would the smaller one get pulled into the bigger one?
Astronomy news on Phys.org
In short, yes.
The smaller black hole would also be pulling on the larger black hole just like the moon pulls on the Earth. The issue would be the same if you were talking about the Earth and the Moon, although the actual collision would happen quite a bit differently. This is all taking into account they are on a direct collision course with each other.
well provided that a collision is imminent, I'm not so sure that one BH would consume the other BH so much as they would just merge and become a single, more massive BH, where the mass of the new BH would be the sum of the masses of the two BH's prior to the merger. but i must throw in a disclaimer - this suggestion is based only on my very limited knowledge about black hole mergers. i do not know enough on the subject to confidently say that one BH or singularity can or cannot "consume" another of its kind.
Yes, the two black holes will coalesce as described into a single black hole with surface area greater than the sum of the surface areas of the two individual black holes. Generally, the entire process can be broken down into three distinct regimes:
1) Plunge. The black holes are relatively far away from each other and are approximately kerr-schild (i.e there is not much tidal deformation due to the curvature of the other hole). Much of this stage can actually be computed with post-Newtonian approximations to general relativity, provided the holes are not too close together.
2) Merger. The black holes get close and are extremely distorted as they come together and the event horizons of each black hole reach out and touch with each other (when you can say they have truly merged). Things are very complicated during this stage, and numerical modeling is the only way to get any results.
3) Ringdown. Once a single event horizon has emerged, it will oscillate from its strange distorted shape down to a kerr-schild horizon that one would expect. This part is rather like the ringing of a bell which slowly damps away its oscillations to become a static solution. This part is (relatively) easy, as these oscillations modes can actually be computed analytically with approximations to general relativity.
I can answer (hopefully!) any questions you have about any of the three regimes or anything in general about merging black holes, as it is a line of research I am currently involved in.
Depends on mass and velocity at closest approach. Nabeshin gave the detailed answer. In any event, neither will 'decompose' under any circumstances. They will either merge or go on their merry way.
1. What happens when two black holes collide?
When two black holes collide, they merge together to form a larger, more massive black hole. This process is known as a binary black hole merger and is predicted by the theory of general relativity.
2. Will the smaller black hole get pulled into the larger one?
Yes, the smaller black hole will eventually get pulled into the larger one during a collision. The larger black hole has a stronger gravitational pull, causing the smaller one to be pulled towards it.
3. How long does it take for two black holes to collide?
The amount of time it takes for two black holes to collide can vary greatly depending on their mass and distance from each other. In some cases, it could take billions of years for the collision to occur.
4. What happens to matter when two black holes collide?
When two black holes collide, they release a tremendous amount of energy in the form of gravitational waves. This energy can also be converted into other forms, such as light and heat, depending on the amount of matter present in the collision.
5. Are there any observable effects when two black holes collide?
Yes, there are observable effects when two black holes collide. The most significant and direct evidence is the detection of gravitational waves, which were first observed in 2015. Additionally, the merger can also produce intense bursts of electromagnetic radiation, which can be detected by telescopes.
  • Astronomy and Astrophysics
