Why atom shells can only hold specific numbers of electrons
In summary, the number of electrons that can fill a shell in an atom is determined by the solution of Schrodinger's equation. Closed shells are favored because it minimizes the energy of the atom. Atoms "seek" a full outer shell because it allows them to have a lower energy level and potentially bond with other atoms to form more stable compounds. This behavior is explained by quantum mechanics and can be found in introductory texts on the subject.
mikewday
I am looking for a fairly simplistic answer to why different "shells" in atoms can only hold a specific number of electrons. There is so much based on valence electrons and how many electrons make a full shell but, do we know why atoms "seek" a full outer shell? It seems like there should be a pretty simple answer but, I have had a hard time finding information. I appreciate any help or insight.
I can read two questions in your post and I will attempt a brief answer here. More info can be found in any introductory quantum mechanics (or Physical chemistry) text.
(1) The number of electrons that can fill a shell (or a subshell) emerges naturally from the solution of shrodinger equationn.
(2) Closed shells are favored as this minimizes the energy of the atom.
hi mikewday! :smile:
mikewday said:
… why atoms "seek" a full outer shell?
you mean, why eg does sodium like to buddy-up with chlorine, why isn't it happy just to be itself? o:)
simple answer: it is happy when it's on its own
but when there's a nearby chlorine atom, the energy level is lower if they share an electron, so they hang around together, and have more energy for doing other things than if they stayed solo :smile:
1. Why can atom shells only hold specific numbers of electrons?
Atom shells can only hold specific numbers of electrons due to the arrangement of the electrons in the atom. This is known as the electron configuration, which follows the principles of quantum mechanics. The electrons in an atom are organized into energy levels, and each level has a specific capacity for electrons.
2. How do we know the specific numbers of electrons that can be held in an atom shell?
Scientists have conducted numerous experiments and studied the electron configurations of different elements to determine the specific numbers of electrons that can be held in an atom shell. This knowledge is also supported by mathematical calculations based on the principles of quantum mechanics.
3. What determines the specific numbers of electrons that can be held in an atom shell?
The specific numbers of electrons that can be held in an atom shell are determined by the energy levels and sublevels within an atom. Each energy level has a specific number of sublevels, and each sublevel can hold a certain number of electrons. This ultimately determines the total number of electrons that can be held in an atom shell.
4. Are there any exceptions to the specific numbers of electrons that can be held in an atom shell?
Yes, there are some exceptions to the specific numbers of electrons that can be held in an atom shell. For example, transition metals can have varying numbers of electrons in their outer shells due to the unique arrangement of their energy levels and sublevels.
5. How does the number of electrons in an atom shell affect the chemical properties of an element?
The number of electrons in an atom shell plays a crucial role in determining the chemical properties of an element. The outermost shell, also known as the valence shell, is responsible for the element's reactivity and ability to form chemical bonds with other elements. The number of electrons in this shell can determine an element's ability to form different types of bonds and its overall chemical behavior.
  • Atomic and Condensed Matter
