Finding potential at the center of metal sphere
In summary, Griffiths says that the charge on the outer surface of the metal sphere will be uniformly distributed.
  • #36
IssacNewton said:
sorry for the confusion.
By the way I have related question about this problem. If we have a cavity(of some weird shape) in spherical metal ball and if we place charge in it, then we of course have induced charge on the cavity walls and then we have equal but opposite charge
on the outer surface on the sphere. Now Griffiths in his books says that the charge
on the outer surface get distributed uniformly irrespective of the cavity shape and the
location of test charge inside the cavity. He didn't really offer any explanation for this.
What would be the reason ?
Going back to your question here, I think I can give you a better answer.
Put a Gaussian spherical surface around O, radius between R1 and R2. The E field everywhere over this surface is zero since it's in a metallic environment. So the charges at the outside surface (at R2) do not experience a radial force. That means that the only force exetrted on them is that due to their neighbors, i.e. all on the surface R2, and that obviously will distribute the charges so that there is uniform distance between them, in other words, uniform charge density.
  • #37
IssacNewton said:
so the total potential at the center would be (adding the potential contribution due to
the charge q itself)
[tex]V=\frac{1}{4\pi\epsilon_o}\left[\frac{q}{r}+\frac{q}{R_2}-\frac{q}{R_1}\right] [/tex]
I took some efforts to get this...
thanks
I'm sorry that I misinterpreted and misread the problem,
Thanks to rude man for pointing out the details of the problem.
I fully agree with the result you have in the above quote.
The potential at the center of the spherical shell is [itex]\displaystyle V_{\text{at the center}}=\frac{1}{4\pi\epsilon_0}\left(\frac{q}{r}-\frac{q}{R_1} \right)\,[/itex] relative to the inner surface of the shell.
The inner surface of the shell is at the same potential as the entire shell, including the outer surface, which is at a potential of [itex]\displaystyle V(r)=\frac{1}{4\pi\epsilon_0}\frac{q}{R_2}\,[/itex] assuming the potential at infinity to be zero.
  • #38
Good work, everybody, and congrats to IssacN who got it right the first time! We are all on the same page, finally!
  • #39
I have problems with the method of image charges. Replacing the metal surface by an image charge works perfectly when the real charge is outside a grounded sphere. When a=R1 the potential of the charge-image system will return zero, which has sense as an opposite charge from the Earth would cancel its effect.
In case of a stand-alone metal sphere a charge Q' equal and opposite to Q has to be placed into the centre, and the potential outside the sphere is obtained with that three-point-charge system.
Here the problem is that the charge is placed inside the sphere. Both the magnitude and distance of the image charge is obtained with respect to the inner sphere when it is at zero potential. But then a charge of -Q has to be added somewhere outside, but where? Without doing so, we added a charge Q to the system, so it is not equivalent to the original one.
Does the potential inside the sphere really tend to q/R2 when r approximates R1? Which would mean putting that extra charge Q' at infinity...
:confused:
ehild
  • #40
Wow,
So many posts. I only got one email notification for all these posts. Anyway great discussion.
I have some problems with the method of images presented. What about the equipotential
spherical surfaces between R1 and R2. Don't we need images charges
for them. Maybe that's what ehild is trying to say. My understanding of method of images
is from Feynman's lectures. I couldn't understand Griffiths properly here.
Sammy, sorry for the confusion you had to go through. I didn't type the problem correctly. r is
a fixed variable here as I pointed out later.
rude man, thanks for the explanation in post # 36. After reading some Feynman, that's the
understanding I developed too. I am sure there is rigorous mathematical reasoning for that. But
for basic physics the argument given by you should suffice I guess.
  • #41
ehild, there is no doubt left that IsaccN's original anwer is correct. Now, I haven't verified that that answer is obtainable by the magnitude and location of SammyS's image charge, but if it is then what he did was ipso facto correct.
I would sum up the situation, which as I say produces the answer that IssacN, SammyS and I agree on, as follows:
Potential at R2 is kq/R2 by Gauss, as SammyS pointed out.
Then, V(R1) = V(R2) 'cause we're going thru metal.
Inside the cavity, while we have no clue as to the exact distribution of the negative induced charges at the cavity wall (R1), we do know that all the charges have to add up to q, again by Gauss, and since they're all equidistant from O, the potential due to all those charges at O is just -kq/R1. It's of course negative since the induced charges are also.
Finally, obviously the potential at O due to q itself, located at r, is kq/r.
So add them all up and you get IssacN's original answer!
  • #42
:confused:
ehild
Hello ehild !
As r → R1, the potential inside the sphere does tend to q/R2, but the position of the image charge tends to the position of the charge, i.e. its distance from the center of the sphere approaches R1. As for the amount of charge of the image charge, Q: Q → -q .
  • #43
SammyS said:
Hello ehild !
That I knew Sammy. My problem is not the image charge but the position of the charge which compensates the image charge in the method of images.
Now I think that the space between the inner sphere and infinity can be filled with a metal, and then the sphere can be taken "grounded", no need of compensating charge. But the "ground" is at potential q/R2.
ehild
  • #44
rude man,
I also think IsaccN's solution correct. I have problems with the method of images.
ehild
  • #45
IssacNewton said:
Wow,
Yours was a great solution, congratulation!
There is a theorem in Electrostatics that the inside of an equipotential surface can be filled with metal, it does not change anything outside. The beauty of this problem was that the inside was outside. :wink: I think it is only the inner surface of the shell for the image charge you need to take into account. The inside of the shell is not influenced by the outer surface except the additive constant of the potential.
ehild
  • #46
ehild said:
rude man,
i also think isaccn's solution correct. I have problems with the method of images.
Ehild
Well, did you "try it on", meaning did you use SammyS's image charge magnitude and location and find that it did not give what we all agree is the correct answer? I was going to do that myself but I'm too lazy ...
SammyS, did you? I would have expected you did, seeing as you agree with IssacN's answer.
  • #47
I have done it, but the method works for a grounded metal surface, at zero potential, and results with the magnitude and distance for the image charge cited by SammyS. Assuming grounded shell, the potential at the middle is kq/r - kq/R1. Saying that it is with respect to the potential of the inner surface which is at kq/R2 potential with respect to infinity, we add that term to U(0). The result is the same as IsaacN's. I have doubts concerning that additive term.
The potential was assumed to be k*q/distance which means zero potential at infinity. If the zero of the potential is at R1, the potential is not k*q/distance.
In case the metal is not grounded and the original charge is outside the sphere my book says to add a charge equal in magnitude with Q and of opposite sign to the centre, to preserve charge.
My problem is that extra charge, when the original charge is inside the shell.
It is impossible to find an "image charge" if the sphere is not at zero potential with respect to infinity.
ehild
  • #48
ehild
What is this theorem ? Any name ?
It seems that image approach does not work in all cases in this particular problem. So my
method is probably better here. We don't have to worry about the images...
  • #49
ehild, potential is classically defined as zero at infinity. It's always V/r in my book (Halliday & Resnick). So it seems that SammyS has determined the image correctly.
IssacN, I think imaging is extremely important and good to understand, even though I agree that your reasoning got us the answer pronto. I myself did not follow your reasoning 100% and had to do some hard thinking and stumbling along the way before agreeing with your answer, as you know. I wasn't totally convinced until I wrote my final post on the subject, "filling in the blanks" for myself. Both approaches ought to be given full credit.
  • #50
I do not know the name if it has got any. But think: the metal surface is equipotential. The grad U lines (electric field lines) are perpendicular to the metal surface just like to the equipotential surfaces. So filling the inside of a closed equipotential surface with a metal does not change the field outside.
You applied the method replacing the metal with the surface charge distribution formed on it. And the method worked well, as the potential in the centre was asked. To determine the field at any point inside the cavity, you would need the distribution of the surface charges on the inner surface. With the method of image charges, the calculation is easy: you get the inner electric field as that of two point charges - the real one and the image.
ehild
  • #51
You can add any arbitrary constant to a potential function: it stays potential for the same problem.
For a point charge, it is convenient to choose the zero of potential at infinity, but that can not be always done: Think of the field near infinite line charge. It is inversely proportional to r, the potential is proportional to ln(r) which is not zero at infinity.
ehild
  • #52
ehild
It's still true for every element of charge dq along the infinite line. It's just when you add (integrate) the dq to + and - infinity that the total line potential becomes infinite.
You have to be very careful when you deal with infinities. We are of course not dealing with them in this problem, and the correct expression for the potential of a finite charge is the integration from +/- ∞ to a point where the potential is to be determined: kq/r.
In the case of the infinite line the calculation of the potential is actually still correct. Potential is work per unit charge, and it takes infinite work to move a unit charge from infinity to the line.
  • #53
ehild, why would image approach not work at other points in the cavity ? When we consider the case of a point charge outside an isolated metal spherical shell , we have the image charge inside the shell. And then the potential everywhere outside is given by these two charges. We no longer talk about the induced charge on the metallic sphere itself.
So in this particular problem, the point charge is inside the spherical shell with some thickness. As you said, we can divide the problem in two parts. One is the charge itself
and the induced charge on the inner wall. Second is the charge on the outer wall which is distributed uniformly. So we can combine the solutions of these two problems by superposition principle. For the first part of the problem, we can fill entire outer space with the metal. So we can place an image charge somewhere within the metal body.
So the potential everywhere within the inner cavity would be given by the charge and the image charge only. And then we can add the constant potential term due to the second part of the problem.
  • #54
I take back my last paragraph. I'll leave things by repeating that one has to be careful with infinities. An infinite line is an impossibility so it should not be surprising that calculating its potential as the work from infinity to a point r is mathematically unrealistic.
  • #55
I did not say that. I have said that your method would not be easy to calculate the potential in an arbitrary point.
In that case the potential everywhere outside is given by three charges: The original one, the image charge and an extra charge of equal magnitude and of opposite sign as the image at the centre of the sphere.
I do not think I said it, but it is very clever. I am getting convinced :smile:
If we really can fill the outer space with a metal (what I said but was not sure if we really can) then the first part is like the problem of a grounded sphere. No need to add that extra charge.
I think, you convinced me about the validity of the solution with the image charge method. :smile:
ehild
  • #56
The potential of a point charge is zero at infinity. The potential in general need not be zero at infinity.
The potential function we use in calculations must be distinguished from the real potential. Infinite line, infinite plane do not exist, but the potential can be approximated near them with a function that do not tend to zero at infinity.
ehild
  • #57
ehild
Yes, the potential of a point charge is zero at infinity. So is the potential of two charges at infinity. So also for any finite number of charges. I haven't calculated it but I bet the potential of any finite-length, finite charge-density line is also zero at infinity.
Like I said - one must be careful with infinities. For all finite cases, kq/r holds, I believe.
  • #58
As I think about this problem, I think the image approach will work even in situations where
the inner spherical cavity of radius [itex]R_1[/itex] is not centered at the center of the whole sphere. As long as we have a spherical cavity within a metallic sphere, the above image approach will work. So after all the discussion on this problem, we can generalise the situation and we can think of applying this to any spherical cavity within any metallic sphere.
  • #59
rude man or ehild, can you confirm my opinion in post # 58
  • #60
I have confirmed that the image charge method can be applied for a cavity in post #55.
Find the potential at an arbitrary point when the charge q is very near to the centre of the cavity and see the limit a -->0. You can get the potential easily in case of a central charge. Check if the potentials are equal.
ehild
  • #61
ehild, in post # 58, I am talking about the inner spherical cavity which is not necessarily concentric with the outer spherical shell. You were replying to different question in post # 55. I just generalised that in post # 58.
  • #62
I see. How do you get the potential at the outer surface then?
ehild
  • #63
Ok
Irrespective of the shape of the cavity inside the metallic sphere, if we place the charge ,q,
inside the cavity, then equal charge q is distributed uniformly on the outer spherical surface.
The cavity and the outside are different worlds altogether as long as we are talking about
electrostatic case. So potential on the outer surface would just be [itex]\frac{1}{4\pi\epsilon_o}\frac{q}{R_2}[/itex]
  • #64
IssacNewton said:
Ok
I agree with this of course, Issac. It's early in the morning for me :grumpy: but that sounds right.
As for your earlier query: as long as you can wrap a spherical Gaussian surface around the cavity and fully contained in metal, your statement must be true, otherwise the E field could not be zero everywhere about the surface. So it makes no difference what the shape of the metal is - it can be quite irregularly shaped - the charges in the cavity have to be distrtibuted so as to null the net field at every point on the Gaussian shell just beyond R1, just as in the concentric case. So the image would not change from the concentric c ase.
