Calculate flux with normal form of Green's theorem
In summary, the outward flux of the vector field \vec{F} over the boundary of the region R is \frac{5}{6}, calculated using Green's theorem. This theorem is a useful tool for simplifying calculations of flux in two-dimensional regions.
dustbin
240
Let [itex] R [/itex] be the region bounded by the lines [itex] y=1 [/itex], [itex] y=0 [/itex], [itex] xy=1 [/itex], and [itex] x=2 [/itex]. Let [itex] \vec{F} = \begin{bmatrix} x^4 & y^2-4x^3y \end{bmatrix}^T [/itex]. Calculate the outward flux of [itex] \vec{F} [/itex] over the boundary of [itex] R [/itex].
Green's theorem (normal form): [itex] \int_{\partial R} F_1\,dy - F_2\,dx = \iint_R F_{1_x} + F_{2_y}\,dx\,dy [/itex].
We have [itex] F_{1_x}+F_{2_y} = 4x^3+2y-4x^3 = 2y [/itex]. Then
[tex]
\begin{align*}
\iint_R 2y\,dx\,dy &= \int_0^1\int_0^x 2y\,dy\,dx + \int_1^2\int_0^{\frac{1}{x}} 2y\,dy\,dx \\
&= \int_0^1 x^2\,dx + \int_1^2 \frac{1}{x^2}\,dx \\
&= \frac{1}{3} + \frac{1}{2} = \frac{5}{6} \ .
\end{align*}
[/tex]
By Green's theorem, the flux is [itex] \frac{5}{6} [/itex].
I would like to add that Green's theorem is a powerful tool for calculating flux in two-dimensional regions. It relates the flux over a closed boundary to the double integral of the curl of the vector field over the region. This allows us to avoid tedious line integrals and instead focus on calculating simpler double integrals. In this case, we were able to use Green's theorem to find the flux of the given vector field over the boundary of the region bounded by the given lines.
What is Green's theorem?
Green's theorem is a mathematical theorem that relates the area enclosed by a closed curve to a line integral along the curve. It is used to calculate the flux of a two-dimensional vector field.
What is the normal form of Green's theorem?
The normal form of Green's theorem is a simplified version that relates the flux of a two-dimensional vector field to a double integral over the region enclosed by a closed curve.
How do you calculate flux using Green's theorem?
To calculate flux using Green's theorem, you first need to find the line integral of the vector field along the closed curve. Then, you can use the normal form of Green's theorem to convert the line integral into a double integral over the region enclosed by the curve. Finally, you can solve the double integral to find the flux.
Can Green's theorem be used for any vector field?
No, Green's theorem can only be used for two-dimensional vector fields. For three-dimensional vector fields, a similar theorem called the Divergence theorem is used to calculate flux.
What are some real-life applications of Green's theorem?
Green's theorem has many applications in physics and engineering, such as calculating the force on a boat moving through water or the amount of fluid flowing through a pipe. It is also used in electromagnetism to calculate the electric and magnetic fields around a wire.
