How Is the Center of Mass Calculated in a Balancing Torque Problem?
In summary, echild was trying to calculate the torque of a weight with respect to a pivot. He used the equation Torque=(distance perpendicular to force from the center of mass)(mass of force)(acceleration of force) and explained that the force has neither acceleration nor mass. The force is just force.
Rayquesto
318
A 1.0 kg rock is suspended by a massless string from one end of a 1.0 m long measuring stick. What is the mass of the measuring stick if it is balanced by a support at the 0.25 m mark?
Torquesum=0 in static equilibrium
Torquesum=0= +(counterclockwise)(.25meters)(9.81m/s^2)(1kg) + (counterclockwise)(?.5meters?)(.25total mass Stick)(9.81m/s^2) - (clockwise)(?.5meters?)(.75TMS)(9.81m/s^2)
solve for TMS and 2.4525=2.4525TMS; TMS=1kg
So, why is ?.5meters? considered to be how far away the meter stick is from the center of mass?
Originally, the individual centers of masses I tried to put as .25meters for the left part of the stick and .75meters for the right part of the stick. How did I make a mistake?
The centre of mass of the measuring stick is at the middle. The weight of the stick acts at that point. I do not understand why do you cut the stick into two.
The torque can be calculated with respect to any point, but it easiest to calculate it with respect to the support.
ehild
oh thank you. then the center of mass with respect to the stick itself is .5meters which is why you use that quantity to calculate torque right?
Yes, the centre of mass of the stick is 0.5 m from one end. If you calculate the torque with respect to the support, you have to use 0.25 m.
ehild
thats only for the rock though right?
What do you mean?
There are three forces: the tension of the string the rock is connected to, but it is equal to the force of gravity on the rock;
the weight of stick at the CM of the stick;
and the upward force of the support.
Both the resultant of these three forces and the resultant of their torques is zero.
You can calculate the torque with respect to any point.
ehild
so the torque of the rock is (9.81)(.25meters from the pivot point)(1kg)
the torque of the left end of the stick is -(9.81)(.25massofstick)(.5meters from center of mass)
and the torque of the right end of the stick is +(9.81)(.75mass of stick)(.5meters from center of mass)
and adding these up gets you 0 since its static equilibrium
how else would you go about solving this torque?
I do not understand you. You can take that the whole mass of the stick is at the CM, the weight acts there.
If you cut the stick to pieces, the weight of each piece acts at the centre of that piece.
How do you calculate the torque of a force?
ehild
I'm basically trying to ask why you'd use .5meters (distance from the center of mass) instead of using however amount of meters away from the pivot point. I understand now. Well, basically, since the pivot point is anything in relation to forces that are trying to circulate in such away that the fulcrum is the center for the rock and the center of mass for the stick is the middle of the stick itself.
the only unanswered question now is how else would you go about solving this?
The force has neither acceleration nor mass. The force is just force.
Supposing a massless rod can move horizontally around a vertical axis, and a force F acts perpendicularly on the rod at d distance from the axis, what is the magnitude of the torque?
ehild
I would not use 0.5 m, but the distance from the pivot point to the line of force. Have you seen my drawing? How far is the line of gravity of the rock from the pivot? What is the torque of the weight of the rock with respect to the pivot?
What is the force exerted by gravity on the stick? Where does it act? How far is that "point of attack" from the pivot? What is the torque of the weight of the stick with respect to the pivot?
ehild
mass of force meaning the mass that is being affected by a force which in this case is only gravity and acceleration of force which again is gravity.
Fdsin180=torque
trust me. If you don't use .5meters, the answer is wrong. You should try and work out the problem to see where you get. I know I know...its not your problem, but you have to use .5meters. Idk how else it can be done.
i meant Fdsin90=torque duh
+(9.81)(.25meters from the pivot point)(1kg)
+(9.81)(.25massofstick)(.5meters from center of mass)
-(9.81)(.75mass of stick)(.5meters from center of mass)
2.4525t+1.22625tmos-3.67875tmos=0
mos=1kg
how else would you solve this. this is in fact that correct answer. I thought it was something else at first, but I was wrong. This is the correct answer.
Well, the torque from the rock is 1 kg * g* 0.25 m counter-clockwise,
The weight of the stick acts at the CM, middle of the stick, at 0.25 m distance from the pivot. Its torgue is clockwise,
m *g *0.25. mg*0.25=g*0.25, m=1 kg.
The equation you wrote up for the torque is wrong, but accidentally has lead the same result for m.
ehild
1. What is torque?
Torque is a rotational force that causes an object to rotate around an axis. It is measured in units of Newton-meters (Nm) and is calculated by multiplying the force applied to an object by the distance from the axis of rotation to the point of application of the force.
2. How is torque related to center of mass?
The center of mass of an object is the point at which its mass is evenly distributed in all directions. The torque on an object is directly proportional to the distance between the point of application of the force and the center of mass. The closer the force is to the center of mass, the smaller the torque will be.
3. How can I calculate the torque of an object?
To calculate torque, you will need to know the magnitude of the force applied to the object and the distance between the point of application of the force and the center of mass. You can then use the formula T = F x d, where T is torque, F is the force, and d is the distance.
4. What is the significance of the center of mass in torque?
The center of mass is important in torque because it determines the point around which an object will rotate. If the center of mass is not aligned with the axis of rotation, the object will experience a torque and will rotate. The location of the center of mass also affects the stability of an object.
5. How does torque affect the motion of an object?
Torque can cause an object to rotate or change its rotational speed. If the net torque on an object is zero, the object will remain in a state of rotational equilibrium and will not rotate. However, if the net torque is not zero, the object will rotate around its center of mass. Additionally, torque can also cause an object to accelerate or decelerate its rotational motion.
