What is the theoretical proof of the quantization of the energy of the EM field?
In summary, the energy of the electromagnetic field is quantized by applying the canonical quantization procedure to the classical field Lagrangian. This is done by finding the conjugate momentum, writing the Hamiltonian, and imposing commutation relations between the generalized coordinate and momentum. The operators a and a+ are derived from this process and are identified as creation and annihilation operators of photons. However, this cannot be considered a proof of quantization as it is a postulate and not a proven fact in quantum mechanics.
Abu Abdallah
Hi,
The energy of the quantum mechanical harmonic oscillator is proved to
be quantized after solving the Schrodingers equation which leads to Hermite equation and discovering that normalizable solutions of the wavefunction exist only for a discrete spectrum of energy. When the electromagnetic field is quantized in the beginning of any textbook on Quantum Optics, (see for example Zubairy and Scully), the field is supposed to be inside a bounded cavity and is decomposed into the normal modes of this cavity. The conjugate coordinates and momentum that comprise the field Lagrangian are
converted into operators and the commutation relations between qi and
pi, namely: [qi,pj]=i hbar.delta ij are imposed on the generalized coordinate
and momentum. The operators a, a+ are directly produced from these
generalized coordinates and momenta and by writing the Hamiltonian of
the field we discover that it's of the same form of the hamiltonian of
the mechanical quantum harmonic oscillator. We then jump to the
conclusion that the energy of the EM field is also quantized and the
operators a, a+ are creation and annihilation operators of photons!
Is this a sound proof for the quantization of the energy of
electromagnetic field? I don't think so...
I received this answer from Dr. Daniel Steck :
Hi (...)
That book isn't my preferred one for thorough treatments, but the
basic idea is that there is no proof for quantizing the
electromagnetic field, you *postulate* that there is a quantum
description of the EM field. The quantization procedure (where you
identify cononical coordinates and promote them to operators) is the
standard way of constructing the quantum model from the classical
model. The normal-mode decomposition is a trick to make the
quantization easier, otherwise you have to deal with field operators
as the fundamental object, which are much more complicated.
Hope that helps.
Daniel A. Steck
Oregon Center for Optics and Department of Physics
Isn't it strange that we can't prove the quantization of EM energy ?!
You can't really "prove" any of quantum mechanics, you just go through the canonical quantization procedure. To do the same thing for the EM field, you just write down the classical field lagrangian, find the conjugate momentum, write down the hamiltonian, and use the commutation relations. I'm not sure why this is terribly peculiar. Mark Srednicki does this very early in his field theory book, which you can find on-line for free.
Question 1: What is the meaning of "quantization" in the context of the energy of the EM field?
Quantization refers to the idea that energy can only exist in discrete, specific amounts rather than being continuous. In the context of the energy of the EM field, it means that the energy of the field can only take on certain values, rather than being able to take on any value.
Question 2: What is the significance of the quantization of the energy of the EM field?
The quantization of the energy of the EM field is significant because it helps explain several fundamental phenomena in physics, such as the photoelectric effect and the stability of atoms. It also plays a crucial role in the development of quantum mechanics and our understanding of the behavior of matter and energy on a subatomic level.
Question 3: How was the quantization of the energy of the EM field first discovered?
The quantization of the energy of the EM field was first discovered by Max Planck in 1900. He proposed that the energy of electromagnetic radiation, such as light, is not continuous but rather exists in discrete packets called "quanta". This idea helped explain the behavior of blackbody radiation, and it laid the foundation for the development of quantum mechanics.
Question 4: What is the theoretical proof of the quantization of the energy of the EM field?
The theoretical proof of the quantization of the energy of the EM field is based on mathematical equations and principles of quantum mechanics, such as the Schrödinger equation and the Heisenberg uncertainty principle. These theories and equations have been extensively tested and verified through experiments, providing strong evidence for the quantization of energy in the EM field.
Question 5: How does the quantization of the energy of the EM field relate to the concept of wave-particle duality?
The quantization of the energy of the EM field is closely related to the concept of wave-particle duality. It suggests that particles, such as photons, can exhibit both wave-like and particle-like behaviors, depending on how they are measured or observed. This duality is a fundamental aspect of quantum mechanics and is essential to understanding the nature of the EM field and its interactions with matter.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
