| New Reply |
General Relativity: Prove that Four-Vector is 0 |
Share Thread | Thread Tools |
| Feb21-13, 01:26 PM | #18 |
General Relativity: Prove that Four-Vector is 0Chet |
| Feb21-13, 01:28 PM | #19 |
I'd like to take a moment while I'm struggling through this problem to thank you guys for helping and guiding me.
Thank you so much! |
| Feb21-13, 02:13 PM | #20 |
Since the notation is apparently confusing you, start by expanding ##U_iU^i = -c^2## to get
$$-U_0 U_0 + U_1 U_1 + U_2 U_2 + U_3 U_3 = -c^2.$$ Differentiate that, and then see how you could get the same result using the summation convention and without having to expand everything out. |
| Feb21-13, 04:07 PM | #21 |
Ok, I've resolved some issues with my understanding of index notations:
Ui = [itex]\frac{dx^i}{d\tau}[/itex] [eq 1] Such that writing out component form: Ui = [itex]\frac{dx^0}{d\tau}[/itex] + [itex]\frac{dx^1}{d\tau}[/itex] + [itex]\frac{dx^2}{d\tau}[/itex] + [itex]\frac{dx^3}{d\tau}[/itex] Where U1,2,3 would correspond to [x,y,z] or [r,[itex]\theta[/itex], [itex]\varphi[/itex]] or [i,j,k] and x0 = ct = c[itex]\gamma\tau[/itex] If in rest frame: UiUi = -c2 from [eq 1] this becomes: Ui [itex]\frac{dx^i}{d\tau}[/itex] = -c2 taking [itex]\frac{d}{d\tau}[/itex] Ui [itex]\frac{d^2x^i}{d\tau^2}[/itex] = -[itex]\frac{dc^2}{d\tau}[/itex] In rest frame, it follows that Ui with index i =1,2,3 are 0 so: U0 [itex]\frac{d^2c\gamma\tau}{d\tau^2}[/itex] = 0 U0 0 = 0 since U0 is just an index: 0 = 0 I really hope I got that right. If not, *sigh* |
| Feb21-13, 04:27 PM | #22 |
\begin{align*} U^0 &= \frac{dx^0}{d\tau} \\ U^1 &= \frac{dx^1}{d\tau} \\ U^2 &= \frac{dx^2}{d\tau} \\ U^3 &= \frac{dx^3}{d\tau} \\ \end{align*} On the other hand, in the expression ##U_a U^a = -c^2##, the index a is repeated, so there is a summation so that ##U_a U^a = U_0 U^0 + U_1 U^1 + U_2 U^2 + U_3 U^3##. Can you tell us how to lower an index? That is, how do you get ##U_a## from ##U^b## and the metric tensor ##\eta_{ab}##? |
| Feb21-13, 04:44 PM | #23 |
Ah yes, I see where I went wrong on [eq 1]. I was coming from the convention that:
Vector U = Uaea where ea can represent [i,j,k] [x,y,z] and in case of tangents, it can represent partial derivatives of correspondent components. I forgot to include that, now a sum is implied and [eq 1] would be correct. Yes, I do know how to lower and raise indices (just covered in class) Ua = gabUb or Ua = gabUb where gab and gab are metric and inverse to one another |
| Feb21-13, 06:28 PM | #24 |
OK, so you have ##U^aU^a = g_{ab}U^bU^a##. What do you get when you differentiate ##g_{ab}U^bU^a## with respect to ##\tau##? Just ignore the fact that it's being summed for now and apply the product rule.
| Mar14-13, 10:29 AM | #25 |
Alright, it took me a while but here's what I got:
UiUi = 1 [itex]\frac{d}{d\tau}[/itex] (UiUi) = 0 chain rule:[itex]\frac{d}{dx}[/itex] f(x)g(x) = f(x)g'(x)+ f'(x) g(x) Ui[itex]\frac{dU^i}{d\tau}[/itex] + [itex]\frac{dU_i}{d\tau}[/itex] Ui = 0 [EQ1] Raising and lowering indices: Ui = gkiUk Ui = gniUn Making these substitutions [EQ1] becomes: gkiUk[itex]\frac{d}{d\tau}[/itex](gniUn) +[itex]\frac{d}{d\tau}[/itex] (gkiUk)gniUn = 0 since g has no dependence on tau, it can be taken out: gkigniUk[itex]\frac{d}{d\tau}[/itex](Un) +gkigniUn[itex]\frac{d}{d\tau}[/itex] (Uk) = 0 from definition product of gki gni is the kroecker delta function: [itex]\delta[/itex]nk so that: [itex]\delta[/itex]nk Uk [itex]\frac{d}{d\tau}[/itex](Un) + [itex]\delta[/itex]nk Un[itex]\frac{d}{d\tau}[/itex] (Uk) = 0 from definition of kroenicker delta function. Let n=k so that [itex]\delta[/itex]kk = 1 (1) Uk [itex]\frac{d}{d\tau}[/itex](Uk) + (1) Uk [itex]\frac{d}{d\tau}[/itex](Uk) = 0 let k = i Ui [itex]\frac{d}{d\tau}[/itex](Ui) + Ui [itex]\frac{d}{d\tau}[/itex](Ui) = 0 So my question is...what next? Sorry for taking so long, midterms and all. |
| Mar14-13, 10:39 AM | #26 |
Recognitions:
Don't raise and lower both of them. Just do one, so you get ##U_i \frac{d U^i}{d \tau} + U_i \frac{d U^i}{d \tau} = 0##. Now what?
| Mar14-13, 04:06 PM | #27 |
That would give me:
2Ui[itex]\frac{dU^i}{d\tau}[/itex] = 0 And that would be the proof. The identity Ui[itex]\frac{dU^i}{ds}[/itex] = 0 Similarly, identity Ui[itex]\frac{dU^i}{d\tau}[/itex] would be zero |
| New Reply |
| Tags |
| four-vector, general relativity, notation, prove that |
| Thread Tools | |
Similar Threads for: General Relativity: Prove that Four-Vector is 0
| Thread | Forum | Replies | ||
| Prove that every non-zero vector in V is a maximal vector | Calculus & Beyond Homework | 0 | ||
| General Relativity: Prove symmetry of Einstein tensor | Advanced Physics Homework | 8 | ||
| General Relativity - Riemann Tensor and Killing Vector Identity | Advanced Physics Homework | 4 | ||
| How much is Special Relativity a needed foundation of General Relativity | Special & General Relativity | 97 | ||
| Prove that 4 vector potential is really a 4 vector? | Special & General Relativity | 59 | ||
