Infinity and unique don’t mix. Theory
In summary: I'm not trying to argue (and I hope you don't get me wrong), I'm just saying that it's not a matter of personal beliefs, but a matter of theoretical predictions and observations. The consensus among cosmologists (and most physicists) seems to be that the universe is spatially infinite, and either infinitely old or at least much older than 13.8 billion years. So your saying both have a start point and an end point? Well I believe otherwise. So humor me and pretend they are. Open your mind a little.In summary, the conversation discusses the idea of infinite space and time and its implications on the uniqueness of objects in the universe. The speaker proposes that there are an infinite number of copies of the Earth in
Alestair
Because space and time are infinite, doesn’t that make it impossible for anything to be truly unique. I propose there are an infinite number of this planet right now in this universe. The distance between each planet is probably unconceivable. Also there is an infinite number of this planet in the past and in the future. Not only is there an infinite number of Earth's exactly the same as this one, there are also an infinite number of this planet with slight differences and infinite number with extreme differences. This possibility is opened up because time and space are infinite. Nothing can ever be unique.
Space news on Phys.org
Neither space nor time are likely infinite.
I am far from an expert in these matters, but two fairly basic points come to mind.
#1 - While infinities seem to have a functional place in mathematics, infinite quantities and values tend to have a rather dyspeptic relationship with physics.
#2 - Just from the standpoint of mathematics, an infinite quantity of values does not imply all possible values for the class or variable in question. For example, if you imagine a number line, marked off in both directions with integer values, you have an infinite sequence of numbers, but you are hardly expressing _all possible_ numbers. Far from it, in fact. The same statement could be said for the rational numbers, the real numbers, etc... with each expressing an infinite sequence, yet containing 'more' numbers. Similarly, counting numbers and whole numbers are both infinite sequences, yet containing fewer numbers than the integers. FWIW, this has been a historical issue in mathematics of some controversy that involves some mind bending counter-intuitive thinking.
An intersting popular/mid-level book on the subject and history of 'Infinity' is A Brief History of Infinity. Constable & Robinson. 2003. ISBN 1-84119-650-9
http://www.brianclegg.net/infinity.html
By author Brian Clegg
http://en.wikipedia.org/wiki/Brian_Clegg
--diogenesNY
Yes, these would all be logical consequences of a spatially infinite, infinitely old universe.
Let's leave time aside, and focus on space. Spatial geometry of universe is flat as far as we can measure it. That implies that universe is either spatially infinite, or that it is really, really big (radius of curvature is so big that it simply can't be detected).
So, you can take any arbitrary volume, and calculate all possible states and arrangement of matter in that volume, and then if physics is same everywhere, you can calculate how far is identical copy of that volume. Simple as that.
Here is what famous multiverse guy Max Tegmark has to say about it. You can read whole paper at http://arxiv.org/abs/0905.1283" :
This is an extremely conservative estimate, simply counting all possible quantum states that a Hubble volume can have that are no hotter than 108K. 10^115 is roughly the number of protons that the Pauli exclusion principle would allow you to pack into a Hubble volume at this temperature (our own Hubble volume contains only about 10^80 protons). Each of these 10^115 slots can be either occupied or unoccupied, giving N = 2^(10^115) ~ 10^(10^115) possibilities, so the expected distance to the nearest identical Hubble volume is N^(1/3) ~ 10^(10^115) Hubble radii ~ 10^(10^115) meters. Your nearest copy is likely to be much closer than 10^(10^29) meters, since the planet formation and evolutionary processes that have tipped the odds in your favor are at work everywhere. There are probably at least 10^20 habitable planets in our own Hubble volume alone.
Is this your personal feeling, or is it based on some scientific argument?
1. What is the concept of "Infinity and Unique Don't Mix" theory?
The theory states that if something is truly infinite, it cannot be unique and if something is truly unique, it cannot be infinite. This is because infinity implies endless repetition, making it impossible for something to be one-of-a-kind. On the other hand, uniqueness suggests that there is only one of something, making it impossible for it to continue infinitely.
2. What examples support this theory?
An example that supports this theory is the concept of infinity in mathematics. In mathematics, infinity is represented by a symbol (∞) and it is used to represent a number that is larger than any other number. However, this number cannot be unique because it is used to represent an endless repetition of numbers.
3. Can there be exceptions to this theory?
Yes, there can be exceptions to this theory. For example, in philosophy, the concept of a "perfect being" is often described as infinite and unique. This is because the idea of a perfect being implies that it has all possible qualities and is therefore both infinite and unique.
4. How does this theory impact scientific research?
This theory can impact scientific research by limiting our understanding and exploration of the concept of infinity. It suggests that there are certain limitations to what can be considered truly infinite or truly unique, which can affect the way we approach certain scientific questions and hypotheses.
5. Are there any potential implications of this theory in real-world applications?
Yes, there can be potential implications of this theory in real-world applications. For example, in technology and computer science, the concept of infinity is often used in calculations and algorithms. However, this theory suggests that any calculation or algorithm that involves infinity cannot be truly unique, which could impact the accuracy and reliability of these applications.
  • Cosmology
  • General Math
  • Cosmology
  • Other Physics Topics
  • Quantum Physics
