Fermi velocity in a non-degenerate semiconductor
In summary, the Fermi-velocity is only properly defined for a degenerate system of fermions, and for me, a non-degenerate semiconductor is pretty far away from being exactly that.
BeauGeste
49
Hi,
Ok, so let's say we have a non-degenerate n-type semiconductor such that the Fermi-level/chemical potential is somewhere in the bandgap (probably needs to be low temperature). Typically in a metal you would say that the Fermi velocity is [tex]\hbar k_F/m_e[/tex]. But since the Fermi-energy is below the conduction band, that doesn't seem to make sense.
My thought would be that since we are at a non-zero temperature, there are some conduction electrons from the donors simply due to thermodynamics. So my thought would be to find the conduction electron density due to thermalized donors and use that as [tex]n_c[/tex] and then use the standard expressions for Fermi wavevector and Fermi velocity.
What do you think?
Thanks.
Hi BeauGeste,
The concept of the fermi-velocity is clearly defined at T=0 when you have a degenerate gas, and all electron levels are filled up to EF (Fermi-Dirac distribution). But in the case you are describing, the electrons in the conduction band are distributed according to Boltzmann, and this means there is really no sharp edge in the electron distribution, So I do not see how to define a meaningful Fermi velocity. What are you trying to calculate ?
Regards
BeauGeste said:
Hi,
a remark: in a non-degenerate semiconductor, the Fermi-Level is always (almost by definition) in the bandgap, especially at higher temperatures. At sufficiently high temperatures, all semiconductors become intrinsic and in this region, the Fermi level is somewhere in the middle of the bandgap
Thanks for your reply.
I would like to determine the (average, I guess) velocity of electrons in the conduction band in the system I described. So I guess I would have to average [tex]k_F[/tex] over the Boltzmann distribution since there will be a distribution of velocities.
i would suppose that averaging the velocities (velocity should be something like gradkEn(k)/[tex]\hbar[/tex] for an electron in a level specified by a band index n and wave vector k) over Boltzmann would give more meaningful results.
the concept of Fermi-velocity (or Fermi-impulse) is only properly defined for a degenerate system of fermions, and for me, a non-degenerate semiconductor is pretty far away from being exactly that
cheers
What is the Fermi velocity in a non-degenerate semiconductor?
The Fermi velocity in a non-degenerate semiconductor is the velocity at which electrons move at the Fermi energy level. It is a measure of the average speed of electrons in the conduction band.
How is the Fermi velocity calculated?
The Fermi velocity in a non-degenerate semiconductor can be calculated using the formula vF = (2/m*)1/2, where m* is the effective mass of the electron in the conduction band.
What factors affect the Fermi velocity in a non-degenerate semiconductor?
The Fermi velocity in a non-degenerate semiconductor is primarily affected by the effective mass of the electron in the conduction band. Other factors such as temperature, impurity concentration, and external electric and magnetic fields can also affect it.
What is the relationship between Fermi velocity and conductivity in a non-degenerate semiconductor?
The Fermi velocity and conductivity in a non-degenerate semiconductor are directly proportional. This means that as the Fermi velocity increases, so does the conductivity, and vice versa.
How does the Fermi velocity in a non-degenerate semiconductor differ from that in a degenerate semiconductor?
In a degenerate semiconductor, the Fermi velocity is not constant and varies with energy. In contrast, in a non-degenerate semiconductor, the Fermi velocity remains constant and does not depend on energy.
  • Atomic and Condensed Matter
