How Do You Calculate Enthalpy with Ammonia's Dryness Fraction at -10C?
  • Thread starter rubberduckie
  • Tags
    Fraction
In summary, the conversation discusses the use of dryness fraction in relation to the properties of Ammonia (R717). The dryness fraction, or quality, is defined as the mass of the vapor phase divided by the total mass of the substance. It is important to understand in order to find the enthalpy of the refrigerant using the properties table. Additional resources are provided for further understanding.
rubberduckie
With the use of Ammonia (R717) properties table, find the enthalpy of the refrigerant if the saturation temperature is -10C and the dryness fraction, x, is 0.9.
can anyone help me with this? i do not understand the use of dryness fraction
Many thanks!
Check one's text, but if 'dryness' is like steam quality, then it refers to the fraction of a saturated two phase system which is gas (vapor), as opposed to the other fraction which is liquid.
I assume dryness does not refer to the water content, which would lead to ammonium hydroxide, or 'aqua' ammonia.
This might be of interest - http://www.tannerind.com/anhydrous-ammonia.html
http://www.iifiir.org/en/doc/1055.pdf
Many thanks!
The dryness fraction is just another term in thermodynamics for quality. It's equal to the mass of the vapor phase of the substance divided by the total mass of the substance.
Hope that helps.
CS
1. What is Dryness Fraction?
Dryness Fraction, also known as steam quality, is a measure of the amount of dry steam in a steam-water mixture. It is expressed as the percentage of the total mass of the mixture that is made up of dry steam. A dryness fraction of 1 indicates that the mixture is completely dry, while a dryness fraction of 0 indicates that the mixture is completely saturated with water.
2. How is Dryness Fraction calculated?
Dryness Fraction is calculated by dividing the mass of dry steam in the mixture by the total mass of the mixture. This can be determined using the steam table or by measuring the temperature and pressure of the mixture and using the steam tables to find the corresponding dryness fraction value.
3. Why is Dryness Fraction important in steam systems?
Dryness Fraction is important in steam systems because it affects the efficiency and safety of the system. A high dryness fraction indicates that there is a greater amount of dry steam in the system, which is more efficient in transferring heat. On the other hand, a low dryness fraction can lead to water hammer and damage to the system.
4. What factors can affect Dryness Fraction?
Dryness Fraction can be affected by several factors, including the pressure and temperature of the steam, the amount of water in the system, and the type of steam generator being used. Changes in these factors can alter the dryness fraction and impact the performance of the steam system.
5. How can Dryness Fraction be controlled?
Dryness Fraction can be controlled by adjusting the pressure and temperature of the steam, regulating the amount of water in the system, and ensuring proper maintenance of the steam generator. It is important to regularly monitor and control the dryness fraction to maintain efficient and safe operation of the steam system.
15K
