Register to reply
Two questions about the binding energy chart?
by magdi_gamal
Tags: binding, chart, energy
Share this thread:
magdi_gamal
#1
Feb8-14, 06:34 AM
P: 9
Hello I'm a little confused about the binding energy chart and its relevance to nuclei stability.
1) why is nickel-62 nucleas more stable than iron-58 and iron-56 though they have higher binding energy?
2) Why is binding energy lower in nuclei with least number of nucleons?
correct me if I'm wrong, but my understanding is that the less nucleones there is the closer they'd be to the nucleus and therefore the strong nuclear force would be more dominant.
So wouldn't make sense that nuclei with the least number of nucleons to be harder to split apart, and so have a higher binding energy? I guess that's not the case seeing that they have the lowest binding energy in the chart, but why?
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
magdi_gamal
#2
Feb8-14, 07:36 AM
P: 9
By the least number of nucleons elements, I meant H isotopes, HE, Li-6 Li-7...etc
mfb
#3
Feb8-14, 09:04 AM
Mentor
P: 11,925
In which respect is Ni62 "more stable"?
The iron nuclei might have more binding energy per nucleon, but what about the total binding energy?
The nucleons are always in the nucleus, as the nucleus is made out of all nucleons. Small nuclei have a large surface relative to the volume, that lowers the binding energy.
magdi_gamal
#4
Feb8-14, 12:13 PM
P: 9
Quote Quote by mfb View Post
in the sense that its nucleones are more tightly bound, and not being able/not needing to decay I guess? I read somewhere on the Internet that it's the most stable nucleas.
Oh, so the values presented in the binding energy chart are per nucleon NOT the overall binding energy?
um, not sure I got this. So the nucleus is the entire area that holds the nucleones and not simply just the center point? and elements like Li, H, and helium basically have lower binding energy because they have a smaller nucleas?
okay, but despite their lower binding energy, they're still not even closely radioactive as elements such as Uranium. the reason being their low amount of nucleons right?
Thanks for your answer.
Bill_K
#5
Feb8-14, 12:25 PM
Sci Advisor
Thanks
Bill_K's Avatar
P: 4,160
Quote Quote by magdi_gamal View Post
I read somewhere on the Internet that it's [Ni-62] the most stable nucleas
It says here that Ni-62 is the most tightly bound: (B.E. per nucleon) http://hyperphysics.phy-astr.gsu.edu...ucbin2.html#c1
mfb
#6
Feb8-14, 12:58 PM
Mentor
P: 11,925
Right.
The nucleus is the whole volume where nucleons are present. This volume depends on the nucleus - in general, the volume is roughly proportional to the number of nucleons.
Uranium is radioactive as emitting nucleons (-> alpha radiation) brings the remaining nucleus closer towards nickel/iron, towards larger binding energies per nucleon.
The corresponding process for small nuclei would be fusion, not decays. Fusion of small nuclei does indeed release a lot of energy, this is the energy source of stars.
Register to reply
Related Discussions
Gravitational potential energy, orbital speed, binding energy. Introductory Physics Homework 3
Energy pie chart for proton, field energy? High Energy, Nuclear, Particle Physics 2
Datapath and ASM chart questions Engineering, Comp Sci, & Technology Homework 0
Planck's constant on a time-energy wave chart Quantum Physics 6
Is Energy of Gauge Bosons matched by Binding Energy? High Energy, Nuclear, Particle Physics 0
