neelakash
- 511
- 1
Hello everyone...I was wondering if it is possible to conceive a 2nd center of a finite sphere in infinity...(I am not a mathematician and therefore, my words might look ridiculous)
apparently, it looks like every point on the sphere is at the same distance from infinity...Anyway, this statement is incorrect.What I should say is that say P is a point at [tex]\ r\rightarrow\infty[/tex] from the center O of the sphere. In this limit the distance PS where S is any point on the sphere is the same...That is PS1=PS2=...=PSn
One of my fiends told that the answer depends on the definition of the center of the sphere: like if one defines the center as the point of intersection of two diameters etc...In that case, I would say it's a chicken and egg problem for there is scope to ask to define diameter.
The problem actually appears for in the context of image problems. One can show that if a charge is placed outside a sphere and is interested in the same region,an image charge may be conceived inside the sphere. This is done in all undergrad books.However,one can also show that if you place the real charge inside the sphere and try to calculate the potential inside,you get the image charge outside the sphere. In fact, it is just the inverse problem. The value and positions of the image charge are inverted with respect to the sphere.
Once you are inside the sphere,the outside world is outside the spherical surface (that looks concave to you). However, it is the same surface by which you are separated from an observer outside the sphere. If the definition of convexity or concavity is a matter of terminology to both of you you should see the outside world confined within a sphere of radius infinity...
What do you think about this?
