Robot vision distance sensing & launch tube design
In summary, the team is researching different ways to launch a foam basketball into a goal that is 18 inches in diameter. They are also researching different sensors that could be used on the robot to help it pick up the retroreflective vision target.
physicsofme
So, For FIRST FRC robotics, We have made 3 different objectives to research, and I decides to start with the projectile.
We need to launch an 8" diameter foam basketball into a goal that's 18" diameter. We can be anywhere from 3feet to 54 feet away.
We had an idea of using the classic catapult style but then making the stopping point moveable to take the range calculations and compute them with a varying force of the arm.
However, this can be very unreliable in a sense if we want to actually score. Now I've been researching but I just cannot determine this: would pneumatic pistons offer a more precise force with a calculated air pressure instead of a springy force that would be in the catapult that would deteriorate?
As well, are there any other methods of launching this projectile up between 2' and 8'?
Sensors?
Here is the known facts:
Mounted around 5 foot off of the floor.
"see" objects anywhere from 3 feet to 54 feet away that are anywhere from 2 feet to 8 feet tall.
Will then take a distance feedback and use that information to calculate a needed arch and force to make a basket.
Basically, its a foam basketball shooting robot, but our design team is having problems deciding what sensors we want to put on the robot so that it can pick up "A retro-reflective Vision Target (Reflexite GP020, 50mm; Pro Gaff Tape, “black”, 2 in.) mounted behind each Hoop".
Any ideas on exactly what sensors to use? We were looking at using a time of flight one, but we aren't sure how that would work. Also, could we actually use the time of flight, rotate it to map points in 3D then have an executing algorithmic sequence to determine what we're actually looking at and then shoot? or would that take too much time? Any other sensors you might suggest I research?
1. How does robot vision distance sensing work?
Robot vision distance sensing works by using cameras and sensors to capture images and measure the distance between objects. These images are then processed using algorithms to determine the distance and provide the robot with information about its surroundings.
2. What factors affect the accuracy of robot vision distance sensing?
The accuracy of robot vision distance sensing can be affected by various factors such as lighting conditions, camera resolution, and the type of sensor used. Environmental factors like dust, fog, or reflections can also impact the accuracy of the measurements.
3. How can I improve the accuracy of robot vision distance sensing?
To improve the accuracy of robot vision distance sensing, you can use high-resolution cameras and sensors, as well as implement advanced algorithms for image processing. You can also control the lighting conditions and minimize any environmental factors that may affect the measurements.
4. What is the purpose of launch tube design in robot vision distance sensing?
The purpose of launch tube design in robot vision distance sensing is to ensure that the camera or sensor has a clear and unobstructed view of its surroundings. This can help to improve the accuracy of the measurements and prevent any interference from external factors.
5. How does launch tube design impact the overall performance of a robot?
The launch tube design can impact the overall performance of a robot by influencing the accuracy of its distance sensing capabilities. A well-designed launch tube can provide clear and unobstructed views, leading to more accurate measurements and better performance in tasks that require precise distance sensing.
  • Other Physics Topics
  • Aerospace Engineering
  • Atomic and Condensed Matter
