Electric Potential for an Infinite line charge question
In summary, the conversation is about changing "dl" to "dr" in the context of two parallel infinite line charges. The original poster is confused about the notation and is seeking clarification. Another user suggests providing more information and the exact question for a better understanding.
Impoor
This may be simple but apparently I can't see it. When given two parallel infinite line charges, how do you change dl to dr? A book I have says that dl*\hat{r}=dr but I don't see how. Any help is greatly appreciated. Thanks!
it would be easier to answer you if you explain in more detail what you mean by "dl" and "dr" and "*".
as olgranpappy said.. it is necessary that you provide us with the EXACT question since the title implies a single infinite line charge.. however you mention 2 infinite line charges.
1. What is an infinite line charge?
An infinite line charge is a hypothetical charge distribution that extends infinitely in one direction. It is often used as a simplified model in physics and engineering calculations.
2. What is electric potential?
Electric potential is a measure of the potential energy per unit charge at a specific point in an electric field. It is a scalar quantity and is measured in volts (V).
3. How is electric potential calculated for an infinite line charge?
The electric potential at a point near an infinite line charge can be calculated using the formula V = kλ/2πε0r, where V is the electric potential, k is Coulomb's constant, λ is the linear charge density of the line charge, ε0 is the permittivity of free space, and r is the distance from the point to the line charge.
4. What is the relationship between electric potential and electric field?
Electric potential and electric field are related by the equation E = -∇V, where E is the electric field, V is the electric potential, and ∇ is the gradient operator. This means that the electric field is the negative gradient of the electric potential.
5. How does the electric potential change as distance from the line charge increases?
The electric potential decreases as distance from the line charge increases. This is because the electric potential is inversely proportional to the distance from the charge, meaning that as distance increases, the potential decreases.
