[Matlab] Problem in modeling a DAE system using ode15s
In summary, Greg was not able to generate the correct response for the ode15s function. He found a workaround and it seems to be working fine.
ruwais92
Dear all,
I have a coupled system of ode's with an algebraic equation. The equations are as follows,
function dy=lorentz(t,y)
global Vfc;
%fcdata.m
% Data file for the hybrid system with parameters values
% Physical parameters
Rl = 0.024; %Value in ohm 0.07%
n = 11; % Number of fuel cells
% SuperCapacitor parameters:
Csc = 58; % Value in F Taken from owner's manual (SuperCapacitor data-sheet)
Rsc = 0.019; %Value in ohm Taken from owner's manual (SuperCapacitor data-sheet), internal DC resistance
% Disturbance
Iload = 25; % Value in amps
Afc=75; % Value in cm sq
F = 96485;
mH2 = 1;
%Equilibrium point:
Tfce=353.15; % Value in K
alphafce = 0.4774; %old value = 0.4608 (old values were computed with SAILLER)
alphasce = 0.3875; %old value = 0.3875
Ifce = 35.8107; % Value in amps %old value = 36.7023
Isce = 0; % Value in amps
Vsc = 14.7; % Value in volts
Ct=17.9;
% References
Vcref = 24; % Value in volts
Lfc = 50e-6; % Value in micro H
Lsc = Lfc;
C=0.0376;
Rsc = 0.019;
T=353.15; % Value in K
Tamb=298.15; % Value in K
tau=2.06;
%%Function
x=(-1.524e-4*(y(4)))+4.110e-2;
w=(-3.185e-6*(y(4)))+4.684e-4;
z=(-1.219e-6*(y(4)))+1.108e-4;
Vfc=1.05-x.*log((y(1)*1000)/Afc)-w.*(y(1)*1000)/Afc-z.*exp(8e-3*(y(1)*1000)/Afc);
dy(1)=1/Lfc*((Vfc*n)-Rl*y(1)-(1-alphafce)*y(3));
dy(2)=1/Lsc*(Vsc-Rsc*y(2)-(1-alphasce)*y(3));
dy(3)=1/C*((1-alphafce)*y(1)+(1-alphasce)*y(2)-Iload);
dy(4)=1/Ct*(mH2*(n*y(1)/(2*F))-((Vfc*n)*((y(1)*1000)/Afc))-(Ct*((T-Tamb)/tau)));
dy=dy';
end
The function call is as follows,
% Function call for ODE %
clear all
clc
close all
global Vfc;
[t,y]=ode15s(@lorentz, [0 0.05], [35.2 0 13.4 353.15]);
subplot(231)
plot(t,y(:,1),'-');
xlabel('time');
ylabel('Ifc');
title('Ifc reponse over time');
subplot(232)
plot(t,y(:,2),'-');
xlabel('time');
ylabel('Isc');
title('Isc reponse over time');
subplot(233)
plot(t,y(:,3), '-');
xlabel('time');
ylabel('Vc');
title('Vc reponse over time');
subplot(234)
plot(t,y(:,4),'-');
xlabel('time');
ylabel('T');
title('T reponse over time');
subplot(235)
plot(t,Vfc,'-');
xlabel('time');
ylabel('Vfc');
title('Vfc reponse over time');
I believe there is an error in the usage of ode15s. I don't know how to create the mass matrix, what it means or how I'm supposed to use it. I am getting diverging outputs. Could anybody please help me?
Thank you.
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
Dear Greg,
I have not yet been able to identify the exact nature of the error in that code. However, I did manage to find a workaround. It's working fine just like the original was intended to.
Thankyou very much for your your concern. Much appreciated!
1. What is a DAE system?
A DAE (Differential Algebraic Equation) system is a set of equations that involves both differential and algebraic equations. These types of systems commonly arise in scientific and engineering applications, such as in modeling physical systems.
2. Why is ode15s used for modeling DAE systems in Matlab?
ode15s is a numerical solver in Matlab specifically designed for solving stiff and nonstiff DAE systems. It uses an implicit method and can handle both differential and algebraic equations, making it well-suited for modeling DAE systems in Matlab.
3. How do I define a DAE system in Matlab for use with ode15s?
To define a DAE system in Matlab, you will need to create a function that describes the system in terms of its differential and algebraic equations. This function should take in the current time and state variables as inputs, and return the derivatives of the state variables and the values of the algebraic equations as outputs.
4. What are some common issues when modeling DAE systems with ode15s in Matlab?
Some common issues when modeling DAE systems with ode15s in Matlab include convergence problems, stiffness, and inconsistent initial conditions. These issues can often be resolved by adjusting the solver settings or modifying the DAE system formulation.
5. Are there any alternative methods for solving DAE systems in Matlab?
Yes, there are alternative methods for solving DAE systems in Matlab, such as using the symbolic math toolbox or implementing a custom numerical solver. However, ode15s is the recommended method for solving DAE systems in Matlab due to its efficiency and accuracy.
