Collisions homework problem
In summary, the collision between the two magnets results in a minimum separation of 0.50 kg and a maximum potential energy of 0.288 J.
pinkyjoshi65
260
A 1.0 kg magnetized air puck moving across a level table at 0.24 m/s approaches head-on a stationary, similarly magnetized air puck of mass 0.50 kg. If the "magnetic collision" is repulsive and perfectly elastic, determine:
(a) the velocity of each puck after the collision
(b) the velocity of both pucks at minimum separation
(c) the total kinetic energy at minimum separation
(d) the maximum potential energy stored in the magnetic force field during the collision
For A) i simply used the conservation of momentum and KE and found the final velocities (1-dimensional)
For B) I am not sure how to find th miniimum distance
Hint: When the pucks are as close to each other as they get, what's the relationship of their velocities?
uhh..i am not sure abt this..velocities become the same..?
Exactly! (If the velocities weren't the same, then they'd keep getting closer.) So figure out what that velocity must be.
so you are saying that the collision becomes the case of a perfectly inelastic collision...?
if that's the case, then M1v= (M1+M2)V
hence V= M1v/M1+M2
Exactly.
ahh k..so for part c its quite staight foreward. we have to use0.5(M1+M2)V2
For part d potential energy will be max when the h is max. How do we find the h..?
and also this is all 1-dimensional yes?
Right.
What do you mean by "h is max"? Just use the fact that total energy is constant.
Yes. (It's a "head-on" collision.)
so then the potential energy will be equal to the kE in part C)..?
No, but the sum of PE + KE must be constant. (What's the initial total energy?)
initial total energy is M1v1^2+ M2v2^2
Not exactly. Initially, only one puck is moving. (And that's not the correct formula for KE!)
yes so M2v2^2 will 0..i know that hence the initial total energy will be 0.5*M1v1^2= 0.0288J. so then we can subtract the KE (from part c)frm this energy to find the PE
Now you've got it.
1. What is a collision in physics?
A collision in physics refers to an event where two or more objects come into contact with each other and exert forces on each other. This can result in a change in the motion or direction of the objects involved.
2. How do you calculate the momentum of objects in a collision?
The momentum of an object can be calculated by multiplying its mass by its velocity. In a collision, the total momentum of the objects before and after the collision must remain the same, according to the law of conservation of momentum.
3. What is the difference between an elastic and inelastic collision?
An elastic collision is one where the total kinetic energy of the objects involved remains the same before and after the collision, while in an inelastic collision, some of the kinetic energy is lost in the form of heat or sound.
4. How do you calculate the coefficient of restitution for a collision?
The coefficient of restitution is a measure of the elasticity of a collision and is calculated by dividing the relative velocity of the objects after the collision by the relative velocity before the collision.
5. How does the angle of collision affect the outcome of a collision?
The angle of collision can affect the outcome of a collision by changing the direction of the forces exerted on the objects involved. This can result in a different change in momentum or direction of motion for the objects compared to a head-on collision.
