Why are time dilatation & length contraction infinite at light speed?
In summary: And I understand that as a limit, it increases without bound, but still, I don't get why.In summary, the concept of time dilatation and length contraction being infinite to a frame of reference moving at the speed of light arises from the fact that the Lorentz transformation, which allows us to calculate these effects, breaks down at the speed of light. This means that it is not possible for a body to actually reach the speed of light, as doing so would require a value of the Lorentz factor that is undefined.
tonyxon22
75
Considering that speed of light is constant and finite, then why are the time dilatation and length contraction infinite to a frame of reference moving at the speed of light?
We know that a moving frame of reference experiments time dilatation and length contraction from the point of view of a “static” observer. And, at the limit, if the frame of reference reached the speed of light, time would completely stop (what I called here “infinite dilatation”) and length would completely contract to zero (what I called here “infinite contraction”).
I know that it’s not possible for a body to reach that speed (although I really don’t understand why), but let’s think about the practical applications of this. For example, I heard that currently they are successful at accelerating particles at 99,999% the speed of light at the Large Hadron Collider.
So what does it means to have a particle that needs 1 second to move 299 792 458 meters? It looks like a normal speed to me, or at least as natural as any other.
I agree and understand the concept of electromagnetic waves traveling at this particular number, and that this measurement does not depend of the speed of the observer. But why does this creates a physical limit to movement? Why can’t we reach and actually beat that speed with enough acceleration in a particle?
And why a particle moving at this speed seems to cease to exist? When I say it ceases to exist I mean it has no dimension at all and it is not affected by time.
What can an observer say that happens to a particle in the LHC at this speed?
You have to be careful when you talk about the "point of view" of an observer. Usually that term means the Inertial Reference Frame in which the observer is at rest. Then we can calculate the Length Contraction and Time Dilation of objects moving according to that IRF but the observer himself cannot directly observe those effects. He has to do a lot of work to figure out what they are.
We can then transform the coordinates of events in one IRF to another IRF moving with respect to the first one using the Lorentz Transformation process but the process does not allow going all the way to the speed of light so forget about that.
Speeds are normal in the sense that once you have defined an IRF, you can assign a speed to any particle, short of c, transform to its rest IRF, define what it looks like, then transform back to the original IRF to determine its Length Contraction and Time Dilation. Since we can't transform to c, that limits the speed of particles.
When you accelerate an object in its rest frame, its speed increases by some amount. When you transform to its new rest frame you can repeat the process as many times as you like. When you transform back to the original IRF, you will see that its speed approaches c but never reaches it.
And what this is telling you is that a frame of reference "reaching the speed of light" is not possible: the Lorentz transformation is undefined (because you end up having to divide by zero).
You just gave the reason why. To expand on it a little: there is a factor called ##\gamma## in the Lorentz transformation, where ##\gamma = 1 / \sqrt{1 - v^2 / c^2}##. If ##v = c##, ##\gamma## is undefined (because you would have to divide by zero to evaluate it); but as ##v \rightarrow c##, ##\gamma## increases without bound. Physically, what this means is that, as you add more and more energy to an object (which is what increasing ##\gamma## corresponds to, physically), its speed gets closer and closer to ##c## but never reaches it; there is no way to actually reach ##c## this way (because there is no well-defined value of ##\gamma## for that speed).
Ok, I understand that the domain of the γ function does not include the c value as it will force to divide by zero, and for that matter, any number larger than c will involve imaginary numbers. But this for me seems a to be a problem about mathematical definition.
However, it looks logical to me that c/2 is in the domain of the γ function. So, if that’s the case, let’s suppose the following scenario:
Three observers in a train station. One of them remains in the platform. The other two observers get on a train each going in opposite directions at c/2.
For the observer in the platform, he will see that the other two are getting away at c/2. Also, for both observers on the trains, the person on the platform is getting away at c/2.
But what would the observers on the trains see when looking at each other?
No, this is one of those cases where the math models reality quite well, so it is NOT a problem about the math it's a description of an actual physical limitation.
Ok, with this formula for velocity addition it has become clear that there is no way to achieve c by adding relative movement. That settles one of my doubts quite well.
1. What is time dilatation and length contraction?
Time dilatation and length contraction are two phenomena predicted by the theory of relativity. Time dilatation refers to the slowing down of time for an object in motion relative to an observer, while length contraction refers to the shortening of an object in the direction of its motion.
2. Why do time dilatation and length contraction occur?
Time dilatation and length contraction occur because of the constant speed of light. According to the theory of relativity, the speed of light is the same for all observers, regardless of their relative motion. This means that as an object's speed approaches the speed of light, time and length appear to change for an observer.
3. Why are time dilatation and length contraction infinite at the speed of light?
According to the theory of relativity, time dilatation and length contraction become infinite at the speed of light because an object's mass also approaches infinity at this speed. This means that the energy required to accelerate an object to the speed of light would also be infinite, making it impossible to reach this speed.
4. How does time dilatation and length contraction affect our daily lives?
Although time dilatation and length contraction may seem like abstract concepts, they do have real-world implications. For example, GPS satellites, which are constantly moving at high speeds, must account for time dilatation in order to accurately calculate the position of a receiver on Earth. Additionally, particle accelerators, such as the Large Hadron Collider, must take into account length contraction in order to achieve accurate results.
5. Is there any evidence for time dilatation and length contraction?
Yes, there is significant evidence for time dilatation and length contraction. One of the most famous experiments that supports these concepts is the Hafele-Keating experiment, in which atomic clocks were flown around the world and showed a difference in time depending on their speed and altitude. Additionally, the observations of high-speed particles in particle accelerators also support the predictions of time dilatation and length contraction.
