New Reply
rate of change of the area of the rebgion
Share Thread
Nov10-12, 10:16 PM   #1
1. The problem statement, all variables and given/known data
A board 5 feet long slides down a wall. at the instant the bottom end is 4 feet from the wall, the other end is moving down the wall the rate of 2 feet per second.at that moment how fast is the area of the region between the board, the ground and the wall changing?
2. Relevant equations
a=1/2bh
3. The attempt at a solution
x^2 + 4^2= 5^2
x=3
da/dt= 1/2b(db/dt)(dh/dt)
I think i started it up wrong and I don't know where to go next..
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Nov11-12, 01:03 AM   #2
Mentor
Quote by fifaking7 View Post
a=1/2bh
x^2 + 4^2= 5^2
x=3
What is the shape of the region below the board and above the ground at the moment under consideration?
Nov11-12, 01:42 AM   #3
just a normal triangle drawn on a line like a typical triangle leaning against a wall problem.
Nov11-12, 01:49 AM   #4
Mentor
Neither end of the board is touching the ground, so it's not a triangle.
Nov11-12, 01:49 AM   #5
a=1/2bh
Have another look at that derivative. It looks like the product rule hasn't been applied properly. Also one of those b/h is x. You'll have to stay consistent with your variable names.
Nov11-12, 01:26 PM   #6
that is how it looks
Nov11-12, 01:44 PM   #7
Mentor
You're right. I misread the problem.
When you said x=3, that should be h=3 .
In general, how are b and h related, considering that they're legs of a right triangle?
Nov12-12, 12:50 AM   #8
i said b= 4ft and h=3 ft
Nov12-12, 12:57 AM   #9
Mentor
That's what b & h are at the instant that h = 4 ft, but how are they related in general?
(Use the Pythagorean theorem.)
Nov12-12, 12:19 PM   #10
Recognitions:
Homework Helper Homework Help
The crucial point that you seem to be missing is that you need to figure out what is happening as the board slides down the wall, so h moves from more than 3 ft to less than 3 ft (and, at the same time, b moves from less than 4 ft to more than 4 ft). When that is happening, the area of the triangle is changing, and that is what you are supposed to be reckoning. So, you need to let b and h be variables, not fixed numbers.
RGV
Nov12-12, 01:04 PM   #11
Mentor
Quote by SammyS View Post
Of course, that's a typo !!!
It should have said:
That's what b & h are at the instant that b = 4 ft, but how are they related in general?
New Reply
Similar discussions for: rate of change of the area of the rebgion
Thread Forum Replies
Rates of change: The rate of change of the area of a triangle. Is my answer right? Calculus & Beyond Homework 1
Rate of emf decline and rate of change of internal resistance Electrical Engineering 1
Rate of change (surface area/radius) Calculus & Beyond Homework 6
rate of change of area Calculus & Beyond Homework 1
Measuring rate of reaction via rate of temperature change Chemistry 3
