The transformer section in Flyback converter
In summary, the conversation discusses the concept of a flyback converter and its transformer unit, specifically the primary and secondary sides. It is mentioned that in a flyback transformer, the flux is maintained by the secondary current after switching, which eliminates any discontinuity and allows for a smooth change in current. Additionally, the flyback transformer is designed differently from a traditional voltage transformer due to its reliance on the magnetizing branch. The conversation ends with the speaker expressing gratitude for the clarification on this important concept.
NexusN
29
Hi everyone,
I am now studying the Flyback converter as a component in a SMPS,
my question is on the transformer unit on the converter.
There are Primary side and Secondary side in the converter,
at any given moment only either of the sides conducts, that is, when Primary conducts, Secondary doesn't.
From the book I am reading now, on switching to the OFF state, huge spike can arise as a result of the leakage inductance.
Does it mean, if we assume perfect coupling and neglect the effect of leakage inductance, we can actually strictly cut the current in the primary side from a finite value to zero without causing a spike, as the energy is free-wheeled via the secondary circuit?
Thank you.
Yes it does.
We often think in terms of "not being able to change the current in an inductor instantaneously", but more fundamentally it's about not being able to change the magnetic flux instantaneously. In the flyback transformer the flux that was produced by the primary current is maintained by the secondary current after switching, so there's no discontinuity.
It's important to realize that this makes a flyback transformer a very different beast compared to a normal voltage transformer, as the flyback tranny takes 100% of the load current through the magnetizing branch (compared with say 1% in a normal transformer). For this reason a flyback transformer is designed more like an inductor than a traditional transformer.
uart said:
Yes it does.
Thank you very much for the explanation,:tongue:
I think this is a very important definition I must understand before I can go deeper in SMPS,
I was struggled by the current definition in the past.
1. What is the purpose of the transformer section in a Flyback converter?
The transformer section in a Flyback converter is responsible for stepping up or stepping down the input voltage to the desired output voltage. It also provides isolation between the input and output circuits.
2. How does the transformer section work in a Flyback converter?
The transformer section works by utilizing the principles of electromagnetic induction. A switching element, such as a transistor, turns on and off to create pulses of current through the transformer. This creates a varying magnetic field, which in turn induces a voltage in the secondary winding of the transformer.
3. What are the main components of the transformer section in a Flyback converter?
The main components of the transformer section in a Flyback converter include a primary winding, a secondary winding, and a core made of a magnetic material. The primary winding is connected to the input voltage source, while the secondary winding is connected to the load. The core is used to concentrate the magnetic flux and increase the efficiency of the transformer.
4. What are the advantages of using a transformer in a Flyback converter?
One of the main advantages of using a transformer in a Flyback converter is its ability to step up or step down the voltage, allowing for a wide range of output voltages. It also provides isolation between the input and output circuits, which is important for safety and noise reduction. Additionally, the use of a transformer allows for a simpler and more compact circuit design.
5. What are some common issues with the transformer section in a Flyback converter?
Some common issues with the transformer section in a Flyback converter include leakage inductance, parasitic capacitance, and core saturation. Leakage inductance can cause voltage spikes and affect the output voltage stability. Parasitic capacitance can lead to high-frequency oscillations and affect the overall efficiency of the converter. Core saturation can cause the transformer to overheat and potentially damage the circuit.
  • Electrical Engineering
9K
