Probability Theory- Standard Normal Distributions
In summary: X) = (k+1/2-1/2)*(k-1/2) = k*(k+1/2-1/2) = k+1.5.In summary, the coin is biased and the probability that we will reach a false conclusion is .0571.
dzza
Two types of coins are produced at a factory: a fair coin and a biased one that comes up heads 55 percent of the time. We have one of these coins but do not know whether it is a fair coin or a biased one. In order to ascertain which type of coin we have, we shall perform the following statistical test: We shall toss the coin 1000 times. If the coin lands on heads 525 or more times, then we shall conclude that it is a biased coin, whereas, if it lands heads less than 525 times, then we shall conclude that it is the fair coin. If the coin is actually fair, what is the probability that we shall reach a false conclusion? What would it be if the coin were biased?
The DeMoivre-Laplace limit theorem
Since n is large, we can use the normal approximation to the binomial distribution.
We first assume that the coin is fair, that is p = .5
Our mean is np = 1000*.5 = 500
The variance is np(1-p) = 250, so the standard deviation is sqrt(250).
We would reach a false conclusion if the number of heads we observe is greater than or equal to 525.
[tex]P(S_{n} \geq 525) = 1 - P(S_{n} < 525)[/tex]
We now put into form to apply the DeMoivre-Laplace limit theorem:
[tex]1 -P(\frac{S_{n} - np}{\sqrt{np(1-p)}} < \frac{525-500}{\sqrt{250}})[/tex]
[tex]= 1 - \Phi(1.581)[/tex]
Using the table in the book, I look up the the value of the area beneath the standard normal curve to the left of 1.58. This value is .9429.
Hence 1-.9429 = .0571 is the probability of reaching a false conclusion.
The answer in the back of my book is .0606.
I think my method is sound, but I'm maybe acquiring phi incorrectly?
Rounding 1.581 up to 1.59 still doesn't get me to .0606.
Any ideas? I've run into a similar error in other problems, which makes me think I'm doing something systematically wrong.
I don't have a calculator / table at hand, so I cannot check this. But you are only off by a little bit, so I suspect that you might have a slightly incorrect z-value.
Did you apply a continuity correction? You are using a normal (continuous) distribution for a discrete problem. Usually, you adjust your boundary value (525 in this case) a little bit to compensate for that. If n is small enough, that might just mean the difference between .0571 and 0.0606.
Thanks CompuChip,
I had not applied the continuity correction to change the value of 525 to 524.5.
From this I was able to get the answer in the back of the book.
I'm not entirely sure why I'm subtracting 1/2 in this case.
The wiki page for continuity correction only seems to showcase adding the quantity 1/2.
The other examples in my book do this as well, except in the case where one wants to find the probability that x is a specific value A, where one then expands that to mean within the interval A +/- 1/2.
In any case, now that I know where the error lies I'll look into it further and hopefully I'll see why.
Thanks again.
The number of 'heads', N, is a discrete random variable, taking integer values only. Thus, the
event {N >= 125} is the same as the event {N >= 124.5}, and approximating the latter by the normal gives better accuracy, basically because the discrete
probability P{N=k} (for integer k) is being approximated by the probability that the approximating normal variate X lies between k-1/2 and k+1/2.
RGV
Likes Izzy
1. What is a standard normal distribution?
A standard normal distribution is a probability distribution with a mean of 0 and a standard deviation of 1. It is often represented by the letter Z and is used to describe the distribution of a random variable that has been standardized.
2. How is a standard normal distribution related to probability theory?
In probability theory, the standard normal distribution is used as a reference distribution to calculate probabilities and make statistical inferences. It is also used to transform other normal distributions into a standard form for easier analysis.
3. What are the characteristics of a standard normal distribution?
A standard normal distribution is symmetric, bell-shaped, and has a mean of 0 and a standard deviation of 1. Approximately 68% of the data falls within one standard deviation of the mean, 95% within two standard deviations, and 99.7% within three standard deviations.
4. How is the standard normal distribution calculated?
The standard normal distribution is calculated using the formula for the z-score, which is (x-μ)/σ, where x is the value of interest, μ is the mean, and σ is the standard deviation. This formula standardizes the data and allows for easy comparison between different distributions.
5. What is the significance of the standard normal distribution in statistical analysis?
The standard normal distribution is significant in statistical analysis because it allows for the standardization and comparison of different distributions. It is also used to calculate critical values and p-values for hypothesis testing, making it a fundamental tool in statistical inference.
