Using MOSFET in Saturation (as a switch)
In summary: The operating point should be towards the left-side on the load line in order for the MOSFET to work efficiently as a switch.
saad87
85
I'm trying to learn about MOSFETs in order to use them as a switch. (note: this is not a homework/school question). On my breadboard, I have the following circuit hooked up:
I vary the gate voltage using a potentiometer. Here is what confuses me: according to wikipedia, the MOSFET is in saturation when V(GS) > V(TH) and V(DS) > V(GS) - V(TH).
If I slowly increase the gate voltage starting from 0, the MOSFET remains off. The LED starts conducting a small amount of current when the gate voltage is around 2.5V or so. The brightness stops increasing when the gate voltage reaches around 4V. There is no change in the brightness of the LED when the gate voltage is greater then 4V.
I also monitor the Drain to Source voltage while I'm increasing the gate voltage. The drain to source voltage drops from 12V to close to 0V when the gate voltage is 5V or so. This is easy to understand: since R1 and R(DS) form a voltage divider and R1 is much larger than R(DS), most of the voltage is dropped on R1. In my measurements, around 10V is being dropped on R1 and the rest on the red LED (2V).
However, since V(DS) is now approximately 0, the condition V(DS) > V(GS) - V(TH) is not satisfied, is the MOSFET not in saturation? If so, what type of circuit do I need to make the MOSFET go into saturation?
Try drawing a load-line analysis. You will see that when Vgs-Vt is small (i.e. you are slightly above threshold), then the MOSFET is in saturation. In this case, most of the voltage is being dropped across the MOSFET. As you increase Vgs, the device will leave saturation and move down into the linear region, where most of the voltage is being dropped across the resistor, as you said.
Ah, so one moves from right to left in the graph! Am I correct in my understanding that, when used as a switch, the MOSFET should then reach the "linear" region as soon as possible?
This use of the word saturation is very confusing for me!
Hi Saad. I think your confusion arises from an unfortunate discrepancy in the way the regions of operation for a BJT and Mosfet are usually defined.
Both terminologies agree with what the "cut off" region is, however the terminology for the other two regions are pretty much swapped around.
- The "constant current" region is usually called the "active" or "linear" region for a BJT but is called the "saturation" region for the mosfet.
- The region where Vds/Vce in too low to sustain constant current operation is usually referred to as the "saturation" region in the BJT but is usually called either the "linear" or "triode" region in a mosfet.
This is a good sign that you are understanding the device operation in my opinion. The differing use of the term "saturation" is inherently confusing, at least to the beginner.
This is the load line that I plotted. I measured the drain current (vertical axis) and the Drain to Source voltage (horizontal axis). I varied the Gate-Source voltage via potentiometer.
Now, I'm not going to confuse myself with saturation or linear/triode. I'm going to ask: in order for the MOSFET to work efficiently as a switch, the operating point should be towards the left-side on the load line.
Am I correct regarding this?
If one imposes the MOSFET characteristic curves on this graph, one could see that the operating point would be in the so-called triode region.
Do I get it? :(
Yes that is correct.
1. What is a MOSFET and how does it work as a switch?
A MOSFET (Metal-Oxide-Semiconductor Field-Effect Transistor) is a type of transistor that can be used as a switch in electronic circuits. It works by controlling the flow of current between its source and drain terminals using an electric field produced by a voltage applied to its gate terminal.
2. How does a MOSFET operate in saturation mode?
In saturation mode, a MOSFET acts as a closed switch, allowing maximum current flow between the source and drain terminals. This is achieved by applying a voltage to the gate terminal that is higher than the threshold voltage, which turns the transistor fully on and allows it to conduct current without any resistance.
3. What are the advantages of using a MOSFET as a switch?
One of the main advantages of using a MOSFET as a switch is its high switching speed. It can be turned on and off very quickly, making it suitable for applications that require fast switching. Additionally, MOSFETs have a very low on-resistance, meaning they can handle high currents without dissipating too much power.
4. What are the limitations of using a MOSFET as a switch?
One limitation of using a MOSFET as a switch is its sensitivity to static electricity and electrostatic discharge (ESD). Care must be taken to handle the transistor properly to avoid damaging it. Additionally, MOSFETs have a limited voltage and current handling capacity, so they may not be suitable for high-power applications.
5. How can I ensure proper operation of a MOSFET switch?
To ensure proper operation of a MOSFET switch, it is important to select a transistor with the appropriate specifications for the desired application. This includes choosing a MOSFET with a suitable voltage and current rating, as well as a low on-resistance. Additionally, proper circuit design and layout, as well as careful handling, can help ensure the reliability and longevity of the MOSFET switch.
  • Electrical Engineering
17K
