Ingrid
- 1
Greetings, gents.
I have a modelization problem you might be able to help me with...
I have two oscillators, modeled as:
[tex]osc_{1}=\cos{(a z)}[/tex][tex]osc_{2}=\cos{(\frac{b}{z})}[/tex]
and a resonance condition f(z) when these two oscillators are combined, modeled as:
[tex]f(z)=\frac{1}{2-\cos{(a z)}-\cos{(\frac{b}{z})}}[/tex]
Assume, for illustration purposes, that [tex]a=10\pi[/tex] and [tex]b=70\pi[/tex]
Then, if z=5, we have:
[tex]f(5)=\frac{1}{2-\cos{(10\pi 5)}-\cos{(\frac{70\pi}{5})}}=\frac{1}{2-1-1}=\frac{1}{0}=\infty[/tex]
That is, the function f(z) would have a pole at z=5 (in addition to the trivial poles at z=1 and z=2)
I'm trying to find a quick way to check whether a value z, for a given value of a and b (not necessarily 10 π
and 70 π), is inferior to the resonance value at which f(z) becomes infinite (at z=5 in the example above).
f(z) can be seen as a complex-valued function of a complex variable z. Looking at the complex plane from
above, we'd have three poles on the real axis, at 1, 2 and 5, indicated with a "P" in the picture below:
The value of the function at z=0 is complicated by the factor cos(b/z) but doesn't interest us for now.
I thought about inspiring myself from the residue theorem of complex analysis.
Assume I'm integrating f(z) along the contour of a circle "C1" of radius 1, centered on 3.5+0i.
That contour won't contain any poles, and, from the Cauchy Integral theorem, the value of that
contour integral should thus be zero.
[tex]\oint_{C_1} \frac{1}{2-\cos{(10\pi 5)}-\cos{(\frac{70\pi}{5})}}\,dz = 0[/tex]
Now, if I were to integrate f(z) along a larger contour, say, a circle "C2" of radius 2, centered
on 4.5+0i, that contour would encompass exactly one pole, the one at 5+0i.
The value of the contour integral should then be the residue at 5+0i.
[tex]\oint_{C_2} \frac{1}{2-\cos{(10\pi 5)}-\cos{(\frac{70\pi}{5})}}\,dz = \operatorname{Res}( f, 5+0i )[/tex]
Note that the circular contours I'm interested in are always centered on a point of the real axis.
Furthermore, the circular contour's radius, as well as its center's position, are chosen so that the
poles with real parts less than or equal to 2 are not included in the contour.
I understand that the relation between the value of the contour integral and the residue at the pole
included in the contour would depend on the nature of the singularity at 5+0i — e.g. removable,
or multiple, or essential.
A quick value check shows that, with a=10 π and b=70 π:
[tex](z-5)f(z)=\infty[/tex]
whilst
[tex](z-5)(z-5)f(z) = 0[/tex]
We thus seem to have a second-order pole at 5+0i.The attempt at a solution
Where I'm stumbling is the calculation of a closed analytical form of the following contour integral
along a circle centered on the real axis:
[tex]\oint_{C} \frac{1}{2-\cos{(a z)}-\cos{(\frac{b}{z})}}\,dz[/tex]
I've tried the usual integration tricks:
Note that the derivative of f(z) is:
[tex]\frac{df}{dz}=\frac{b\sin{(\frac{b}{z})}-a z^2 \sin{(a z)}}{z^2(2-\cos{(a z)}-\cos{(\frac{b}{z})})^2}[/tex]
Given that the derivative's denominator becomes zero at the same points as the denominator of f(z), the locations
of the derivative's poles are the same as those of f(z).
So, I think that either the value of the contour integral of f(z), or of the contour integral of its derivative
[tex]\oint_{C} \frac{b\sin{(\frac{b}{z})}-a z^2 \sin{(a z)}}{z^2(2-\cos{(a z)}-\cos{(\frac{b}{z})})^2}\,dz[/tex]
along a circle C of my choosing, with its center on the real axis, should provide me with a quick
and reliable indication as to whether a pole is — or isn't — included in the contour.
Any help on obtaining closed forms for the contour integrals of either f(z) or of its derivative
would be much appreciated !
Of course, indications as to why the evaluation of a contour integral as a quick check for the
presence of a pole within a circular contour of a given radius might work or not — e.g. at essential
singularities — would also be appreciated…
Greetings, gents.
Code:
| i axis
-------*---P---P---.---.---P---.---.---.--->
0| 1 2 3 4 5 6 7 . . Real axis
whilst
- subsituting cos(z) with (e^iz+e^-iz)/2
- parametrizing the circular contour integral as an integration over a single variable t in [0..2π] using the z=e^it substitution
- Note that in the general problem that interests me, that is, for arbitrary values of a and b, the location of
the non-trivial pole (5+0i in the illustration above) is, unfortunately, totally unknown. - Thus, the residue cannot be calculated, as the point where it should be calculated (the pole) is unknown.
- Thus, we cannot rely on the residue theorem. The only way to calculate the contour integral — whether of f(z) or of
its derivative — would seem to be by using fairly advanced integration techniques, and this is where I'm stumbling.
