| New Reply |
How atoms fuse together |
Share Thread |
| Jan31-13, 05:50 AM | #1 |
Hello, i'd just like to know do atoms fuse together the instant that they make contact after overcomming repulsion or does it take time?
I've been led to believe that when we touch something we never actually touch it since electrons repel each other and we can't generate enough force to overcome it, so when we touch something it's just the items electric field we are touching/feel and not the actual atoms. I guess i'm wondering what would happen if say someone went to clap their hands and just before they did they were zapped by some magic ray which gave them to power to overcome the repulsive force so that the atoms of their hands actually made contact with each other? Would they simply just fuse together and have their hands stuck unable to pull apart, would there be a flash of light as energy is released then they are stuck or an explosion instead of just a flash? Would there be an explosion that actually destroys their hands and fused atoms of whatever it is after they fused fall to the ground or get blown away? I can picture a dozen things happening if you actually touched other atoms but I have no idea what if any is correct
| Jan31-13, 06:35 AM | #2 |
There is no meaning of the word 'touch' in atomic scale just like there is no meaning of the word 'surface' in that scale. Your imagined situation sounds so unusual I am not even going to analyse it. |
| Jan31-13, 09:33 AM | #3 |
Mentor
In nuclear fusion, atoms do fuse together.
You have to overcome both the electromagnetic force and the strong nuclear force (which holds the nucleus together), but yes it is essentially instantaneous. It doesn't make sense to talk about it happening to your hands because the energy levels are so high, molecules can't exist...much less hands. |
| Jan31-13, 04:13 PM | #4 |
I believe it is instant. Fusion occurs as a quantum jump.
| Jan31-13, 05:44 PM | #5 |
| Feb1-13, 10:55 AM | #6 |
I believe your hands would just pass one throurgh the other, because at atomic level distances between atoms and molecules are huge. It would be unlikely that even two atoms collide.
| Feb1-13, 11:04 AM | #7 |
It's important to realize that an atom is a COMPOSITE particle. It is made up of other, more fundamental particles. The electrons surround the nucleus in orbitals that are vaguely analogous to a "cloud" whose density is very high near the nucleus and tapers off as you increase the distance. As two atoms approach each other their "electron clouds" start to repel each other with increasing force the closer the two approach. However, if you can overcome this, and you have the right atoms, the two can bind together and reach a lower energy state. It's kind of like pushing a boulder out of a pit on the side of a hill. Sure you expend some energy getting the boulder out of the shallow pit, but you get much more out of it as it rolls to the bottom of the hill. This is why chemical reactions can release net energy even though they take some to start. The distance between the nucleus and the densest part of the electron orbitals is very large compared to the size of the nucleus. Perhaps that is what you were thinking of? This is where the common saying of "an atom is 99% empty space" comes from. (Which is arguable) |
| Feb2-13, 12:34 PM | #8 |
I imagined the situation where we could magically make all forces act normaly between all particles in each hand, but not between the particles of the other hand, except the nuclear forces.
Then I thought the distances between individual atoms and molecules are huge. You are right about the atom picture, but what about the distance between the molecules? |
| Feb2-13, 02:15 PM | #9 |
| New Reply |
Similar discussions for: How atoms fuse together
| Thread | Forum | Replies | ||
| Fuse Question | Electrical Engineering | 6 | ||
| Amount of Energy to Fuse Two Atoms | High Energy, Nuclear, Particle Physics | 9 | ||
| If a fuse repeatedly blows, it should be replaced by a fuse of one step higher rating | Introductory Physics Homework | 7 | ||
| fuse question | Electrical Engineering | 6 | ||
| Why is a fuse connected in the live wire only? | Electrical Engineering | 18 | ||
