What does symmetry in GR mean and where does it lead?
In summary, symmetry in General Relativity refers to the idea that the laws of physics are the same for all observers, regardless of their position or motion. This leads to the principle of equivalence, which states that gravitational and inertial mass are equal, and the theory of relativity, which explains the relationship between space, time, and gravity. Symmetry in GR also leads to the concept of curved spacetime, where the presence of mass and energy can bend the fabric of the universe, causing objects to follow curved paths. This has significant implications for our understanding of the universe and has been confirmed through various experiments and observations.
Naty1
5,606
40
Steve Carlip says this [back in 2007], here,:
http://www.2physics.com/2007/06/symmetries-horizons-and-black-hole.html"...Until fairly recently, no one had a clear idea of the microscopic states responsible for black hole entropy. Today, we suffer the opposite problem: we have many explanations, each describing a different set of states but all agreeing on the final numbers. ...
[1] One attractive possibility is that a hidden symmetry of classical general relativity controls the thermodynamic properties of black holes. ...
[2] The uncertainty principle prevents us from simply saying,"A black hole is present." [Instead, we must find a way to impose constraints strong enough to ensure the presence of a black hole,but weak enough to be allowed by quantum mechanics.] . ...
[3]The key point is that the horizon constraints break the fundamental symmetry of general relativity, general covariance (technically, diffeomorphism invariance). [As a result, states that would normally be considered equivalent, differing only by a "gauge" transformation, are now physically distinct.]
[The brackets[] are not Carlips and are included for perspective.]
Is this area of research active: 'hidden symmetries in GR?' and has it produced anything interesting...Is it known by maybe a different term today?? Any suggested reading sources??
And what in layman's terms do 1,2,3 mean?
Wiki had nothing I could find under "Symmetry in GR". I just got Taylor and Wheelers' "Exploring Black Holes, Introduction to GR" an hour ago in the mail and there is nothing in the index there about symmetry in GR.
edit: Wikipedia makes mention:
"In general relativity, the symmetric stress-energy tensor acts as the source of spacetime curvature... "
thank you.
I hope you aren't expecting a short answer. Algebraic symmetries are at the heart of GR and are used to classify spacetimes into 'families' according to the structure of the Lie group formed by all possible solutions of Killings equation. Effectively this means that we can think in families of solutions that share certain core properties. Spaces of constant curvature for instance have stringent conditions on the curvature tensor, which are also called symmetries.
I think what Carlip means in [1] is that the different ensembles of states that apparently describe the same thing, are not actually different because they share some algebraic property ( a symmetry) and are actually the same thing ( this might be tautologous ... ).
Fully understanding symmetry requires a close acquaintance with group theory, every physicists nightmare.:wink:
I was especially interested in Carlip's comment #2 about uncertainty...
There have been some long discussions in these forums and I thought I had a reasonable
understanding, but what is meant by
is really baffling...
Mentz:
These were, then, discovered after the formulation of GR??...they were likely not formal input restrictions which Einstein recognized and which guided him beforehand?
When Einstein was deciding what mathematics to use for his new theory, I seem to recall he was aware of 'stress, strain' and these are described by symmetric tensors...we now know...was such 'symmetry' understood/known in the 1920's?
Mine too. Do you know of any good book on Lie groups, Lie algebras, representation theory, tensor products, direct sums, etc? Annoyingly advanced physics books act as if this stuff is common knowledge (which it probably is, to a lot of readers).
I'm guessing, but I'd say Einstein was not aware of the richness of GR right away. He wanted a theory with geodesic motion because he understood that free-fall is what distinguishes gravity. Later, Killing found the GR equivalent of Noether's theorem which enables space-times to be classified according to their invariants.
I cannot recommend a specific book but there must be many now aimed at physicists. I can write down everything I know about groups in a few sentences so I'm not the person to answer this.
I do have a copy of 'The Theory of Groups and Quantim Mechanics' by Hermann Weyl, which kicked off a lot of this, but I wouldn't recommend it to any non-geniuses like me.
that's what I've found to be in the literature so far...and seems convincing considering Minkowski introduced Einstein to the 'merger' of space and time...and that it took others to solve Einstein's own equations...
Hmm? "and that it took others to solve Einstein's own equations..."
What do you mean by that Naty?
His equations was his own as far as I can see? And worked in the presentation of them he gave. That you can continue to manipulate them and get more or less far fetched outcomes that he hadn't considered, as 'time travels' for example, doesn't minimize what he did, to me.
He was one of a kind.
Some related topics:
Symmetry (physics)
Spacetime symmetries
(It's always easier to find the answer to a question if you already know the answer! :smile:)
Googling off Carlip's http://www.gravityresearchfoundation.org/pdf/awarded/2007/Carlip_2007.pdf suggests these papers.
Carlip, http://arxiv.org/abs/hep-th/9812013
"Restricted to a black hole horizon, the "gauge" algebra of surface deformations in general relativity contains a Virasoro subalgebra with a calculable central charge. The fields in any quantum theory of gravity must transform accordingly, i.e., they must admit a conformal field theory description."
Solodukhin, http://arxiv.org/abs/hep-th/9812056
"The existence of black hole horizon is considered as a boundary condition to be imposed on the fluctuating metrics. ... The diffeomorphisms preserving this condition act in (arbitrary small) vicinity of the horizon and form the group of conformal transformations ..."
Maldacena, Strominger, http://arxiv.org/abs/hep-th/9702015
"Fundamental string theory has been used to show that low energy excitations of certain black holes are described by a two dimensional conformal field theory. This picture has been found to be extremely robust. In this paper it is argued that many essential features of the low energy effective theory can be inferred directly from a semiclassical analysis of the general Kerr-Newman solution of supersymmetric four-dimensional Einstein-Maxwell gravity, without using string theory."
There seems to be some differences between the various views, as reviewed by Joan Simon. The Kerr/CFT picture seems to apply to extremal black holes, Carlip proposes using Killing horizons, while Solodukhin proposes using apparent horizons.
As for whether the horizon absolutely exists or only approximately exists in quantum gravity, there are ideas like Mathur's fuzzball conjecture in which the horizon only exists for macroscopic objects.
Einstein as far as I know did not find any solutions to the Einstein equations. Even the simplest known solution, that of a nonspinning point mass, was found by Schwarzschild.
"The Einstein field equations (EFE) or Einstein's equations are a set of 10 equations in Albert Einstein's general theory of relativity which describe the fundamental interaction of gravitation as a result of spacetime being curved by matter and energy. First published by Einstein in 1915 as a tensor equation, the EFE equate spacetime curvature (expressed by the Einstein tensor) with the energy and momentum within that spacetime (expressed by the stress–energy tensor).
Similar to the way that electromagnetic fields are determined using charges and currents via Maxwell's equations, the EFE are used to determine the spacetime geometry resulting from the presence of mass-energy and linear momentum, that is, they determine the metric tensor of spacetime for a given arrangement of stress–energy in the spacetime. The relationship between the metric tensor and the Einstein tensor allows the EFE to be written as a set of non-linear partial differential equations when used in this way. The solutions of the EFE are the components of the metric tensor. The inertial trajectories of particles and radiation (geodesics) in the resulting geometry are then calculated using the geodesic equation.
As well as obeying local energy-momentum conservation, the EFE reduce to Newton's law of gravitation where the gravitational field is weak and velocities are much less than the speed of light.
Solution techniques for the EFE include simplifying assumptions such as symmetry. Special classes of exact solutions are most often studied as they model many gravitational phenomena, such as rotating black holes and the expanding universe. Further simplification is achieved in approximating the actual spacetime as flat spacetime with a small deviation, leading to the linearised EFE. These equations are used to study phenomena such as gravitational waves."
From http://en.wikipedia.org/wiki/Einstein_field_equations.
and this one http://www.btinternet.com/~j.doyle/SR/Emc2/Derive.htm is for SR.
One thing though, he (Jim Doyle) uses the older definition of 'relativistic mass' in his description, although Einstein later found 'invariant mass' to be the preferred concept. But you can use both.
Um, I'm not sure why your quoting all this. The point is not that Einstein didn't come up with the Einstein equations, but rather that he didn't find solutions to them himself.
You mean that SR and GR wasn't his?
Seems we're defining 'solutions' quite differently here?
Maybe you have another word, that will clear it up :)
Okay, then we're agreed on that :) The other solutions you're speaking of I would define as manipulating the equations he gave for SR and GR, taking them to their limits more or less. And who knows, maybe there still are new ways to use them?
I mean solution in the mathematical sense of solution of an equation. Einstein came up with but did not solve the field equations of general relativity.
Are you sure that all derivations of his equations are known now? There can be no new derivations in the future? What Einstein did was to introduce SR and GR. To prove it mathematically he was forced to both learn new math as well as invent some of it. He also was the one introducing the concept of symmetries that we all use nowadays.
But I see how you thought, and we used 'solutions' differently. To me SR and GR represent the solutions for Einsteins equations and all further derivations coming from them is manipulating the concepts he introduced of SpaceTime.
As long as we're discussing SpaceTime that is. Quantum mechanics is a different coin, or side of it at least.
No, only a very small number of exact mathematical solutions are known for the Einstein equations. Most solutions are not expressible using elementary functions.
Okay, and some of them are very far from what we observe, as closed timelike curves, and 'wormholes' as the Einstein-Rosen Bridge. Even though Einstein and Rosen created it in 'an attempt to to explain fundamental particles like electrons as space-tunnels threaded by electric lines of force.' As for if you can manipulate the field equations further I don't know, but I would really like too :)
Here is a candidate for hidden symmetry in GR :
[tex]R_{\mu \nu}-\frac{1}{2}g_{\mu \nu}R=G_{\mu \nu}=g_{\mu \nu}\Lambda-\Pi_{\mu \nu}[/tex]
Personally, I think it leads to a link between gravity, quantum theory and the accelerating expansion. Just my opinion though.
If you would like to debate this, please go to the forum http://www.bautforum.com/showthread.php/129309-Negative-Mass-Interpretation-of-General-Relativity
(mods: Please let me know if the link is not allowed, I will delete.)
There are few solutions to the equations that are physically realistic. For instance there are more than 100 perfect fluid solutions but only a few are physically acceptable. It is a problem, maybe, with the EFE that there are many solutions that are so weird they describe implausible alternative universes. Vacuum solutions are much rarer.
Messenger, what is ∏ in the equation ?
Just a curvature tensor, the symmetric opposite of G where if they were summed would equal [tex]\Lambda[/tex]
As you are here Messenger, why not open a thread from scratch. Start it with trying to describe where you think your idea differ from what we use now. Then try to explain it as simple as possible. Don't hesitate to put in historical references if you find it appropriate.
If you succeed with coming through using words you will have built a framework for understanding your equations, and also give all a chance to see where your thinking take you. It's like writing that v e r y important letter to someone :) You start out, then throw it in the wastebasket, just to try again. After the tenth you finally find yourself satisfied, alternatively just giving up on it, as you find yourself unable to formulate it the right way.
You have already written some letters, write one more and see if it comes out as you want it.
Hi yoron,
That would get me banned on PF. Did find another forum where I could discuss it, and in the mean time have heard back from the editors of a journal who recommended me to two others. Will post the link here if it is accepted.
Oh, sorry about that. I looked at your other (first) forum and was frankly surprised over the lack of response you got to your original question. Otherwise I have found those guys and gals to be quite interesting to read at times.
1. What is symmetry in general relativity (GR)?
Symmetry in GR refers to the idea that the laws of physics remain unchanged when certain transformations, such as rotation or translation, are applied to the system. This means that the laws of physics are the same for all observers, regardless of their location or orientation in space.
2. How is symmetry related to the theory of relativity?
Symmetry is a fundamental component of the theory of relativity. According to Einstein's theory, the laws of physics must be the same for all observers in any inertial frame of reference. This is known as the principle of relativity and is closely tied to the idea of symmetry.
3. Where does symmetry in GR lead?
The principle of symmetry in GR leads to the idea of spacetime symmetry, which is a fundamental concept in the theory. It also has important implications for the behavior of matter and energy in the universe, as well as the structure of spacetime itself.
4. How does symmetry in GR impact our understanding of the universe?
Symmetry in GR plays a crucial role in our understanding of the universe. It helps us to develop mathematical models and equations that accurately describe the behavior of matter, energy, and spacetime. It also allows us to make predictions and test the validity of the theory through experiments and observations.
5. Can symmetry in GR be broken?
While the laws of physics in GR are generally considered to be symmetric, there are certain situations where symmetry may be broken. For example, in extreme conditions such as near a black hole or during the early stages of the universe, the laws of physics may behave differently than expected. However, overall, symmetry remains a fundamental principle in GR and has been supported by numerous experimental and observational evidence.
