| New Reply |
How does a vacuum motor work? |
Share Thread |
| Aug9-12, 08:17 PM | #1 |
I was wondering about the how the suction works? I got this cordless vacuum broom for free and it has terrible suction. It runs on like 7 or 8 recharge c battery's and I was wondering if i increased the amperage or voltage would the motor run faster and have more suction?
| Aug10-12, 05:05 PM | #2 |
I would not recommend increasing the volts/amps past the design specs, this will likely cause the motor to have a reduced lifetime, and may actually be dangerous to you (electrocution, motor catching fire / bursting).
In terms of how these work, many of them are turbine based - i.e. a radial turbine. But there are many many variations as you can imagine. In general I would say that you won't be able to fix it yourself. The parts may be very tight tolerance that you can't replicate without CNC machines. |
| Aug10-12, 07:09 PM | #3 |
Recognitions:
| Aug10-12, 10:22 PM | #4 |
So increased air flow to the motor should increase the suction of the vacuum?
| New Reply |
Similar discussions for: How does a vacuum motor work?
| Thread | Forum | Replies | ||
| Old Vacuum Motor | General Discussion | 9 | ||
| What sort of motor is used in the lead retraction device in my vacuum cleaner? | Electrical Engineering | 2 | ||
| how to work out vacuum in in.hg | General Physics | 3 | ||
| Vacuum Motor Questions | General Engineering | 2 | ||
| Does a Vacuum Cleaner work inside a Vacuum? | General Physics | 12 | ||
