Boltzmann Transport Equation : Hall Effect in the Relaxation Time Approximation
In summary, the conversation is about a user seeking help with a particular issue related to the Boltzmann Transport Equation (BTE) for electrons in a semiconductor with constant and uniform electric and magnetic fields. The user presents the homework statement and equations related to the BTE, including the relaxation time approximation. They also mention their attempt at a solution, but express difficulty in isolating a specific variable and manipulating the vectorial equations involved. They request help with finding a solution for arbitrary fields while keeping everything in vectorial notation.
gougoune5
Hello everyone!
I have been on this website for quite a while, and found some interesting answers to many questions, and I decided to create an account to seek you help with a particular issue I encountered in my assignment.
Please have a read, and thank you for any input!
I need to show that the Boltzmann Transport Equation (BTE), in the relaxation time approximation, for electrons in a semiconductor with constant and uniform electric (E) and magnetic (B) fields gives a steady-state electron distribution function of the form [itex]g=g_B+f[/itex], with f the typical Fermi distribution function and
[itex]g_B=-\frac{\partial f}{\partial \epsilon}\textbf{v}\cdot\textbf{X}_B[/itex] is the distribution perturbation
where
[itex]\textbf{X}_B (1+\phi^2)=\textbf{X}+\textbf{X}\times\phi+( \textbf {X}\cdot\phi)\phi[/itex]
[itex]\textbf{X}=-q\tau\textbf{E}[/itex]
[itex]\phi=-\frac{q\tau}{m}\textbf{B}[/itex]
We consider the spatial gradients of g and of temperature to be zero. q is the electronic charge (in absolute value), τ is the relaxation time, v is the particle velocity, m is the electron effective mass and [itex]\epsilon[/itex] is the energy.
The BTE, including the aforementioned approximations and in the relaxation time framework, boils down to
[itex]-\frac{q}{\hbar}( \textbf{E} + \textbf{v} \times \textbf{B} )\vec{\nabla_k} g = -\frac{g-f}{\tau}[/itex]
When I work out the equation relative to [itex]g_B[/itex] rather than g, I can cancel out some terms due to the vector orthogonalities arising from the cross product.
I have worked out that [itex]\vec{\nabla}_k f=\hbar \textbf{k} \frac{\partial f}{\partial \epsilon}[/itex]
Also, knowing that [itex]\hbar\textbf{k}=m\textbf{v}[/itex], we can change the gradient on k by a gradient on v.
Finally, come up with
[itex]-q\frac{\partial f}{\partial \epsilon} \textbf{v}\cdot \textbf{E}-\frac{q}{\hbar}(\textbf{E}+\textbf{v} \times \textbf{B} ) \vec{\nabla}_k g_B = \frac{g-f}{\tau} = \frac{g_B}{\tau} [/itex]
or
[itex]-q\frac{\partial f}{\partial \epsilon} \textbf{v}\cdot \textbf{E}-\frac{q}{m}(\textbf{E}+\textbf{v} \times \textbf{B} ) \vec{\nabla}_v g_B = \frac{g-f}{\tau} = \frac{g_B}{\tau} [/itex]
However, I have absolutely no idea how to isolate [itex]g_B[/itex] in this equation. In our course, we did a similar treatment for the case with no magnetic field, and we approximated [itex]\vec{\nabla}_k g \simeq \vec{\nabla}_k f[/itex] , which is equivalent to saying [itex]\vec{\nabla}_k g_B \simeq 0[/itex].
However, this poses a problem here since we oversee the effect of the magnetic field in this approximation due to the gradient of f being parallel to v, thus perpendicular to [itex]\textbf{v} \times \textbf{B}[/itex]
I have seen in another work someone postulating that we have a solution of the form [itex]g_B=-\textbf{v} \cdot\textbf{P}(\epsilon)\frac{\partial f}{\partial \epsilon}[/itex], where [itex]\textbf{P}(\epsilon)[/itex] is a vectorial quantity dependent solely on the energy.
They managed to work out that [itex](\textbf{v} \times \textbf{B})\cdot\vec{\nabla}_k g \simeq -\textbf{v}\cdot(\textbf{B} \times \textbf{P})\frac{\partial f}{\partial \epsilon}[/itex] but I can't for the life of me figure out how they swapped around the vectors in this product...
Also, their final solution was obtained by assigning orthogonal axes to the fields and writing out the individual scalar components of P. However, I have to work out the solution for arbitrary fields and keep everything in vectorial notation. Even if the approximation above holds true, I don't know how to isolate P in the resulting equation, how can I invert the cross product? :
[itex]\textbf{P}-\frac{q\tau}{m}(\textbf{B} \times \textbf{P}) + q\tau \textbf{E}=0[/itex]
I am not very familiar with manipulating vectorial equations such as these and I have been turning this upside down for a few days now, so any help would be appreciated!
Thanks in advance!</code>I am not very familiar with manipulating vectorial equations such as these and I have been turning this upside down for a few days now, so any help would be appreciated!Thanks in advance!
1. What is the Boltzmann Transport Equation?
The Boltzmann Transport Equation is a mathematical equation that describes the behavior of a system of particles, such as electrons in a material. It takes into account factors like collisions, forces, and energy levels to predict the movement and distribution of particles over time.
2. What is the Hall Effect?
The Hall Effect is a phenomenon in which a voltage difference is created across a material when a magnetic field is applied perpendicular to the current flow. This can be used to measure the mobility and concentration of charge carriers in a material.
3. What is the Relaxation Time Approximation?
The Relaxation Time Approximation is a simplification of the Boltzmann Transport Equation that assumes that the particles in a material are constantly undergoing collisions and are in thermal equilibrium. This allows for a simpler and more manageable solution to the equation.
4. How is the Hall Effect related to the Boltzmann Transport Equation?
The Hall Effect can be described by the Boltzmann Transport Equation, which takes into account the motion of particles in a magnetic field and their interactions with other particles and forces. The equation allows for the calculation of the Hall coefficient, which is a measure of the relationship between the current, magnetic field, and voltage in a material.
5. What are some applications of the Boltzmann Transport Equation in studying the Hall Effect?
The Boltzmann Transport Equation is commonly used in the study of semiconductors and other materials to understand the behavior of electrons and other charge carriers in the presence of a magnetic field. It has applications in fields such as material science, electronics, and solid state physics.
  • Electromagnetism
