Solving Unknown Compound: A:O = 2:3, 8.0g O, 28g A
  • Thread starter haengbon
In summary, a compound containing element A and oxygen has a mole ratio of A:O = 2:3. If 8.0 grams of the oxide contains 2.4 grams of oxygen, then a) what is the atomic weight of A? ; b) what is the weight of one mole of the oxide? ; c) what is the theoretical weight of the oxide formed when 28 g of A is heated in excess oxygen? ; d) what is the % yield if 38 grams was produced from 28 grams of A?
haengbon
38
A compound containing element A and oxygen has a mole ratio of A:O = 2:3. If 8.0 grams of the oxide contains 2.4 grams of oxygen...
I didn't have any because I barely understood what to do :( can someone please guide me on how to solve this? It'll be of great help ^^
Start with the oxygen. How many moles of oxygen is equivalent to that 2.4 grams of oxygen from the compound?
so I'll convert the oxygen grams to moles right? :)
Yes. Then try to find out how many moles of the oxide you have (look at the formula).
8.0 - 5.6 = 2.4 gO
2.4 gO x 1 mole O / 16 gO = 0.15 moles O
A:O = 2:3
A:0.15 = 2:3
[tex]\frac{A}{0.15}[/tex] x [tex]\frac{2}{3}[/tex]
3A = (0.15)(2)
3A = 0.30
A = 0.1 moles Oxygen
a)
AW = g/mole
AW = 5.6 gO / 0.1 moles O
AW = 56 g/mole
b)
2:3
A2O3
= (56)(2) + (16)(3)
= 160 g
c)
A + O2 [tex]\rightarrow[/tex] A2O3
4A + 3O2 [tex]\rightarrow[/tex] 2A2O3
1 mole A x 2moles A2O3 / 4moles A = 0.5
.5 moles A x 2 moles A2O3 / 4moles A = 0.25
LR: 0.25
= 0.25 x 160
= 40 g
d)
% = [tex]\frac{actual}{theoretical}[/tex] (100)
% = [tex]\frac{38}{40}[/tex] (100)
% = 95
Is this correct? I'm sure with my a & b but with c and d, I don't really get how that happened :( I asked for help in solving this, and this was the solution he gave.
haengbon said:
3A = (0.15)(2)
3A = 0.30
No - this is not "moles of Oxygen". This is number of moles of A in the sample.
AW = g/mole
AW = 56 g/mole[/quot]e
Here it becomes obvious - 56 g/mol is not molar of oxygen. It is molar mass of A.
160 g
Miraculously you get the correct answer, by ignoring incorrect information :wink:
Answers given for c & d are correct, but this is just a simple stoichiometry. You have a balanced reaction equation
4A + 3O2 -> 2 A2O3
that gives molar ratio, you know molar mass of A... I guess it can be symbolic A instead of some well defined element that throws you off. Would it be easier if I will tell you to solve c & d assuming A is the iron?
methods
AW = g/mole
AW = 56 g/mole
oops! I'm very sorry for that :)) the one in my paper was 0.1 moles of A :D
haha xD
4A + 3O2 -> 2 A2O3
thank you! um, but the part that I'm really confused about is this one ...
4A + 3O2 -> 2 A2O3
if we take the balancing off..
A + O2 -> A2O3
Where did we get A + O2 ? Is this common knowledge? because all I understood was A2O3 since we had a mole ratio of 2:3 right? :D
Not sure what your problem is. There are many ways of producing oxides, but direct reaction between the element and oxygen is the simplest one (even if technically not always possible). Even if it is not possible, you were told in the question that 38 grams of A2O3 were produced from 28 grams of A - no matter what the real reaction was, molar ratio of the A and A2O3 will be always the same.
Then A2O3 was given, O[ub]2[/sub] is a common knowledge, A is just the simplest way of approaching the problem.
1. What is the molar mass of compound A?
The molar mass of compound A can be calculated by dividing the mass of A (28g) by the ratio of A to O (2:3). This gives a molar mass of 42g/mol.
2. How much of compound A is present in a 1 mol solution of the unknown compound?
Since the ratio of A to O is 2:3, we can calculate that there is 2 mol of A in every 3 mol of the unknown compound. Therefore, in a 1 mol solution, there would be approximately 0.67 mol of A present.
3. What is the empirical formula of the unknown compound?
The empirical formula is the simplest ratio of elements in a compound. In this case, the ratio of A to O is 2:3. Therefore, the empirical formula of the unknown compound is A2O3.
4. How can the molecular formula of the unknown compound be determined?
The molecular formula represents the actual number of atoms of each element in a compound. To determine the molecular formula, the molar mass of the empirical formula must be compared to the experimental molar mass. In this case, the molar mass of A2O3 is 98g/mol, which is half the experimental molar mass of the compound (196g/mol). Therefore, the molecular formula of the unknown compound is A4O6.
5. How can the identity of compound A be determined?
The identity of compound A can be determined by using various analytical techniques such as spectroscopy, chromatography, or mass spectrometry. These techniques can provide information about the molecular structure and functional groups present in the compound, which can help identify it. Additionally, comparison with known compounds or databases can also aid in determining the identity of A.
  • Biology and Chemistry Homework Help
10K
