Does g increase asymptotically near a black hole singularity or event horizon?
In summary, the value of g at the singularity of a black hole is like asking for the temperature in Narnia - it doesn't describe a point in space-time. Instead, we talk about curvature which increases as you get closer to the singularity. The event horizon does not have any special effect on curvature, and the acceleration required to hold station near a black hole increases without bound as the distance drops to the Schwarzschild radius. There is also speculation about whether black holes can gain mass in finite time, as all infalling matter is re-radiated as energy in exact balance.
pawprint
62
On approach to a simple (non-rotating, uncharged) singularity, does g increase asymptotically near...
a) the singularity,
b) its event horizon,
or c) no?
At any point in spacetime, g has any value you want it to have. For a free-falling observer, it always equals zero. This is what the equivalence principle is about: http://en.wikipedia.org/wiki/Equivalence_principle
The singularity isn't a point in spacetime. There's no "there" there. Asking the value of g at the singularity is like asking the temperature right now in Narnia. Narnia isn't a place, so "right now in Narnia" doesn't describe a point in spacetime.
That's why we don't talk about g in general relativity. We talk about curvature. Curvature gradually increases as you get closer to the singularity. It doesn't do anything special at the event horizon. It approaches infinity as you approach the singularity.
I'd like to expand on bcrowell's answer by talking about what happens to an observer who's trying to stay at rest with respect to the black hole (hover a certain distance away from it). For such an observer, the amount of power he needs to hover at a given radius away increases without bound as his distance drops to the schwarzschild radius.
bcrowell- I'm sorry my question was imprecise. I spent some time editing it to the bone but it looks as though I should have left a little more meat. I was unwise in using the word 'approach'- I meant to suggest that the measurements were taken at progressively closer distances along a 'straight' line ending at the singularity. There is no need to debate the existence of a straight line near a singularity; I seek an intuitive answer rather than a mathematical one.
Thank you Nabeshin. You have grasped my meaning. I take it you mean that b) is the answer within this context.
The acceleration required to "hold station" will be equal to
[tex] \frac{G\,m}{r^2 \sqrt{1-r_s/r}}[/tex]
where G is the gravitational constant, m is the mass of the black hole, r is the Schwarzschild r coordinate, and [itex]r_s[/itex] is the Schwarzschld radius, [itex] r_s= G m / c^2 [/itex]
The Scwarzchild r coordinate isn't really a distance, because space-time is curved near a black hole, but the surface area of a sphere given by r=constant is 4 pi r^2.
By contrast, for Newtonian gravity, the acceleration requires to hold station is G m / r^2, (but here r is the radius, though it's still true that the surface are of a sphere given by r = constant is 4 pi r^2).
As you can see, the GR expression goes to infinity as r approaches r_s, the Schwarzschild radius.
I can't accept that the event horizon is not "a point in spacetime" We can and do assign coordinates to it, so it must be! However, I do have some grave doubts about its nature.
Here is one issue I am struggling to understand:
I think I am right in saying the gravity gradient at the event horizon is finite and gets smaller, the larger the Black Hole is. So make it large enought, and matter falling in does not necessarily get torn apart while still on the outside, especially if heading in in a straight line plumb dead center. So consider that situation. Now, just before the matter enters, the event horizon's radius is given by thre mass already on the inside; and just after enters, the Black Hole's mass and its radius must have increased.
Here is the $64000 question: At what point does the Black Hole's event horizon increase its radius? Doe sit come out to meet the falling in mass, like a big snake's mouth opening up" Does that mean the Black Hole gets a bulge on side, that subsides as the matter plummets towards the cental singulaity? I have big problem with the latter, because that implies we a getting information on the outside about events on the inside. I have other reasons to want to believe that a Back Hole can only accrete mass in a sphercially synnetric way. At least in a cylindrically symmetric way, if there is angular momentum invloived. But preferably, only in a spherically symmetric way when there is no angular momentum involved. In the latter case, the matter would cover the event horizon uniformly and then continue its chute towards the central singularity as a uniform sphere of collapsing radius.
Any opinions, arguments or math about this, anyone?
This rather depends on the observer. A distant observer will see the infalling mass slow down and finally halt at the event horizon. From her point of view the EH will never expand.
A brave observer entering a sufficiently massive BH may, as you pointed out above, avoid spaghettification. From her point of view the external universe will accelerate and die as she nears the EH. She would believe that the EH expanded slightly as her conveyance passed through, but would be unable to verify this.
Two threads discussing this aspect are-
https://www.physicsforums.com/showthread.php?t=355960
https://www.physicsforums.com/showthread.php?t=498215
Over the past few years speculation has grown as to whether BHs can gain any mass in external finite time. I was unable to find the thread(s) discussing this but it is now considered at least an open question. I DO remember the argument is that all infalling matter is re-radiated as energy in exact ballance. I'm sure this has been discussed here (on PF) and I would appreciate someone posting the relevant link(s).
Thank you all. If only I had a mathematically inclined brain I could use those equations. I'm currently faced with variations of g at different heights above the surface of Earth. I'm reduced to expressing my answer in μgals!
While it's not a point (technically, it's a null surface), the event horizon is "in space-time". But the singularity at the center of the black hole (which isn't the event horizon) , isn't part of the manifold, i.e. it's not part of space-time. So I think you misunderstood what Ben said earlier, as he was talking about the singularity not being part of space-time, not the event horizon.
The acceleration required to hold station - the "gravity" for a hovering particle approaches infinity as the particle approaches the event horizon. This might lead one to conclude that the gravity gradient also approaches infinity for a particle approaching the event horizon. This is not correct, at last not for a particle that free-falls into the event horizon. The gravity gradient for a free-falling particle is always finite. Explaining exactly why convincingly probalby would require some math - all I can say is that the gravity gradient isn't quite observer independent, but the effect is important only for large accelerations.
Specifically: the Riemann tensor is observer independent quantity (being a true tensor), but the tidal forces you measure with rods and accelerometers are only exactly equal to the Riemann tensor for someone who is not accelerating, for someone who is accelerating there is a (usually very tiny) difference between the observer-independent Riemann tensor components and the actual measurements of the gravity gradient, also known as tidal forces.
Since the acceleration required to hold station at the event horizon is infinite, even a very small observer dependence that's usually ignorable becomes important to know about.
It depends on how you define the event horizon. There's an apparent horizon, and an absolute horizon, as I recall. http://archive.ncsa.illinois.edu/Cyberia/NumRel/AppVsEventHorizonCaption.html and http://en.wikipedia.org/w/index.php?title=Apparent_horizon&oldid=457048068 have some details.
If we imagine a hole of mass M, and throwing in some small mass dm, the event horizon smoothly expands from its radius at r=2M to r=2(M+dm) as the mass falls in. If the situation is not axisymmetric, indeed there will be a tidal budge induced on this surface. After the mass falls in, the horizon will ring down, emitting gravitational radiation until it settles back into a symmetric black hole.
No information is transferred here because the event horizon is simply a mathematical surface, not something physical.
You mean [itex] r_s= 2G m / c^2 [/itex], right?
Ooops, yes, right...
It is useful to look at the Vaidya metric. See Figure 5.7 on page 134 (pdf page 150) of Eric Poisson's notes,
http://www.physics.uoguelph.ca/poisson/research/agr.pdf,
which evolved into the excellent book, A Relativist's Toolkit: The Mathematics of black hole Mechanics.
Radiation falls into a black hole from v1 to v2, but the left diagram of Figure 5.7 shows that the event horizon starts to grow before the first radiation crosses the event horizon.
Poisson said:
It is a remarkable property of the event horizon that the entire history of the spacetime before its position can be determined
Here, "history" means past and future.
I do not think that is correct.
The total mass will be slightly less than M+dm.
Well yes, thank you. My point in using those values was to illustrate that it asymptotes to what you would 'expect' the horizon to be when the additional mass has fallen in, minus of course some losses from gravitational radiation. If I wanted to be a little more analytic, the power radiated by waves will be [itex] \propto dm^2 [/itex], while the mass increase is linear, so to first order indeed the mass is M+dm.
1. What is the value of g near a black hole?
The value of g, or the acceleration due to gravity, near a black hole is extremely high. It can reach up to billions of times stronger than the gravity on Earth.
2. How does the value of g near a black hole compare to Earth's gravity?
The value of g near a black hole is significantly stronger than Earth's gravity. This is because the mass of a black hole is so concentrated in a small area, creating an intense gravitational pull.
3. Can anything escape the strong gravitational pull near a black hole?
The gravitational pull near a black hole is so strong that even light, which is the fastest thing in the universe, cannot escape. This is why black holes are often referred to as "light traps."
4. Does the value of g near a black hole change depending on the distance?
Yes, the value of g near a black hole changes depending on the distance from the black hole. The closer an object is to the black hole, the stronger the gravitational pull.
5. How does the value of g near a black hole affect time?
According to Einstein's theory of relativity, time near a black hole is affected by the intense gravitational pull. Time appears to slow down near a black hole, as observed by an outside observer. This is due to the effects of gravity on space-time.
