Where are melted Fukashima cores going?
  • Thread starter Skip Hawley
In summary, Project Gnome 1961 proposed that nuclear bombs could be used to create caverns or tunnels for construction projects. This is not the same as using nukes to collapse the WTC buildings on 9/11.
Skip Hawley
Project Gnome 1961: "Construction industry officials, used to large-scale projects being accomplished by blasting away rock, saw this as an opportunity. People talked of setting off nuclear bombs as a way to hollow out mountains to make vast caverns to be used as living quarters, or to construct roads through otherwise impassable hills. People thought nuclear explosions could be just one more tool, to be used in any number of public works projects."
A somewhat similar application of nuclear bombs was proposed in a "conspiracy theory" of 911 where the WTC buildings were said to have collapsed because mini nukes were set off underground resulting in the loss of foundation support for the buildings and they collapsed or imploded.I'm wondering if mini nukes could be used under Fukashima to create a cavern or series of caverns,one under the other,where what's left of the the Fukashima Reactors and cores would fall into and then be covered up?
No! That's about the worst thing you could possibly do. Not only would you just add more radioactive waste/fallout to the environment from the nukes, the cores would come into direct contact with the ground and release a far greater amount of much more hazardous radioactive waste into the environment through the groundwater.
That is like trying to crash an already crashed car and hoping that somehow the next hit will make the geometry better than the last one :D:D
the bombs for hills and rocks thing is kinda different because they used it deep underground for rock breaking purposes not for radioactive waste sitting at the seaside problems.
Those are totally different things.
The WTC trust me hasn't seen a nuke near it under any circumstances.Don't be fooled by a bunch of lunatics on the internet.
If one would have set off a nuclear detonation at the basement of WTC we would not have seen a collapse we would have seen the destruction of all the lower financial district of manhattan.
Last time I checked nuclear bombs don't come in the sizes of "mini" , or in other words you can't make a little boom , the smallest possible booms are big enough to destroy parts of a city.
According to wiki, the B61 nuclear bomb has a variable yield with a low end of 0.3 kilotons. I'm not really sure how much damage that would do, but it's considerably less powerful than the 16 kt blast on Hiroshima. Still, I doubt it would be easy to dismiss as anything other than a nuke.
This video shows what a conventional blast from 500 tons of TNT does:
This is more or less in the range of a small nuke.
The small yield devices are known as 'tactical nukes'. There were a variety of tactical nuke designs produced in the 1950s primarily for use in artillery shells. The W48 device was fitted into a 155 mm shell and weighed between 50 and 60 kg. It had a yield of 72 tons of TNT.
http://en.wikipedia.org/wiki/W48
Before anyone gets confused, this is not to say that somebody set off any nukes in Manhattan on 9/11. While tactical nukes are small, they also leave radioactive fallout behind, just not as much as their bigger brothers.
Something like this - namely, isolating melted cores for a longer time (hundreds of years) instead of dismantling them in 10..30 years - does not need any bombs.
There are not many rational reasons to hide damaged reactor buildings underground, they can be completely covered with concrete ("cocooned") perfectly fine where they are now. Most other buildings on site then can be dismantled - they aren't heavily contaminated.
Hanford reactors already underwent this "cocooning" procedure.
Exactly. Anyone who pushes that theory is much loonier than Moon landing deniers. Any nuke detonation under Manhattan, however small (even a few tons TNT) would be easily detected by now. If not by US govt, then by someone else. Such event can't possibly be consealed.
To be sure, anyone proposing that Fukushima be cleaned up by using nuclear explosions, tactical or otherwise, does not realize what a political upheaval that would create in Japanese politics. Hiroshima and Nagasaki are still sensitive subjects to the Japanese, and the mere visit to Japan by a nuclear powered warship causes protests to break out. The US has always based a conventional carrier battle group in a Japanese port; now that no conventionally powered carriers are in service, the USS George Washington (CVN-73) was selected to be based in Japan in 2005. Much PR by the US Navy was required to quell any potential unrest by the Japanese before the ship docked in Japan. When the reactors at Fukushima melted down, the GW happened to be at Yokosuka, providing relief efforts for the tsunami, where it detected some of the radiation released by the reactors. The vessel was ordered to sea with a reduced crew until the situation became better understood.
It's a terrible idea.
Till now only relative low percentage of the core material were released from the containments to the environment.
If anything breaks the containments then 100% of the cores would be out. It would be far much worse than Chernobyl.
That stuff should be cleaned up with time and moved to a location where all of it is accessible and under control. That's the only acceptable solution.
Fatal [STRIKE]flow[/STRIKE] flaw number 1 - explosion would not create a cavern. After explosion rocks will be still left where they are. Shaken, stirred and melted - but they would not miraculously disappear.
Borek said:
Fatal flow...
Now that sounds like a bad volcano movie...
:tongue:
Sigh.
Likes 1 person
1. Where are the melted Fukashima cores currently located?
The melted Fukashima cores, also known as corium, are currently located at the bottom of the reactor pressure vessels in Units 1, 2, and 3 at the Fukashima Daiichi nuclear power plant. It is estimated that they have melted through the reactor pressure vessels and have accumulated in the primary containment vessels.
2. Is there a possibility that the melted Fukashima cores could leak into the environment?
There is a possibility that small amounts of radioactive material from the melted Fukashima cores could leak into the environment. However, extensive measures have been taken to prevent this from happening, such as the use of a steel and concrete structure called the "ice wall" to surround the reactors and prevent groundwater from entering and becoming contaminated.
3. How long will it take for the melted Fukashima cores to cool down?
The melted Fukashima cores are still generating heat due to the radioactive decay of the nuclear fuel. It is estimated that it could take anywhere from 30 to 40 years for the cores to fully cool down. However, measures are being taken to accelerate the cooling process, such as the injection of coolant water into the reactors.
4. What are the potential risks associated with the melted Fukashima cores?
The main potential risks associated with the melted Fukashima cores are the release of radioactive material into the environment and the potential for a nuclear meltdown. However, extensive measures have been taken to prevent these risks, and the situation is constantly being monitored and managed by experts.
5. How is the cleanup and removal of the melted Fukashima cores being handled?
The cleanup and removal of the melted Fukashima cores is a complex and ongoing process. Currently, robots are being used to assess the conditions inside the reactors and develop a plan for removing the cores. It is estimated that the actual removal of the cores could take decades and will require advanced technology and specialized equipment.
  • Nuclear Engineering
  • DIY Projects
  • High Energy, Nuclear, Particle Physics
  • Science Fiction and Fantasy Media
  • Mechanical Engineering
  • General Discussion
