Does the Fizz Keeper Device Really Keep Carbonated Drinks from Going Flat?
  • Thread starter ContangoJoe
  • Tags
    Partial
In summary: Since the volume of carbon dioxide in the atmosphere is very large, the partial pressure of carbon dioxide contributed by the pressurized air is insignificant. Therefore, about the same amount of carbon dioxide must still come out of solution to reach an equilibrium partial pressure in a resealed bottle.
ContangoJoe
There is a device called a Fizz Keeper that attaches to carbonated beverage bottles and is supposed to keep them from going flat after they are opened by pressurizing them with air. Dalton's law and Henry's law have been used to debunk the device as ineffective.
The argument against the device's effectiveness goes something like this:
Henry's law states that the concentration of a gas dissolved in a liquid is proportional to the gas's partial pressure. Since the concentration of carbon dioxide in the atmosphere is low, the partial pressure of carbon dioxide contributed by the pressurized air is insignificant. Therefore, about the same amount of carbon dioxide must still come out of solution to reach an equilibrium partial pressure in a resealed bottle.
But there's something I don't understand.
According to Wikipedia, the carbon dioxide in the headspace of an unopened soft drink bottle exerts a pressure of about 2 atmospheres. When the bottle is opened, that carbon dioxide escapes and is replaced with air. If the bottle is closed again, carbon dioxide will come out of solution until its partial pressure again reaches 2 atmospheres (actually a bit less because the concentration of carbon dioxide in solution has decreased some, but let's call it 2 atmospheres for simplicity). But now we also have air in the headspace at 1 atmosphere, so why wouldn't the total pressure be 3 atmospheres (the sum of the partial pressures per Dalton's law) at equilibrium?
The total pressure doesn't really go up 50% after a bottle opened and resealed, does it? Can anyone alleviate my confusion?
Chemistry news on Phys.org
Right, but that is mainly an effect of your approximation - the partial pressure of CO2 in the liquid will drop significantly the first time you open the bottle.
Another effect: depending on the way the bottle is filled, it might have O2 and N2 partial pressures below the atmospheric pressure, so some gas can get dissolved there.
Thanks for your answer. I guess I'm thinking about this correctly then.
I have another question that's a little deeper I think.
It's always seemed strange to me that molecules in a situation like this apparently make a distinction between themselves and molecules of a different compound. It seems to me that molecules would bump into molecules of another kind in basically the same way they would bump into molecules of their same kind.
How is it that the carbon dioxide molecules in this situation can just ignore the pressure of the atmospheric molecules in the headspace?
They do, but if there is no CO2 in the gas, no CO2 molecules can dissolve. To reach equilibrium, both fluxes have to be the same, and that needs a certain density of CO2 in the gas. More other atoms just make the motion more jagged (shorter mean free path), but the collision rate of CO2 molecules with the water surface stays the same.
At the pressures you are considering, the mixture of CO2 and air is still essentially in the ideal gas region where the various species act essentially independently.
Chet
1. What is a Fizz Keeper Partial Pressure?
A Fizz Keeper Partial Pressure is a device that helps preserve the carbonation in a carbonated beverage by maintaining a higher pressure inside the bottle or can.
2. How does a Fizz Keeper Partial Pressure work?
The Fizz Keeper Partial Pressure works by creating a seal around the bottle or can, and then using a small pump to inject carbon dioxide gas into the container. This creates a higher pressure inside the container, which helps preserve the carbonation of the beverage.
3. Can a Fizz Keeper Partial Pressure be reused?
Yes, a Fizz Keeper Partial Pressure can be reused multiple times. It is designed to be durable and can be easily cleaned after each use.
4. Can a Fizz Keeper Partial Pressure be used on any type of carbonated beverage?
Yes, a Fizz Keeper Partial Pressure can be used on any type of carbonated beverage, including soda, beer, sparkling water, and more.
5. How long does a Fizz Keeper Partial Pressure preserve the carbonation in a beverage?
The length of time a Fizz Keeper Partial Pressure preserves the carbonation in a beverage can vary depending on factors such as the type of beverage, the initial carbonation level, and the storage conditions. However, on average, it can help preserve the carbonation for several days.
  • Biology and Chemistry Homework Help
10K
