Register to reply
Attractive Forces from Particle Exchange
by anorlunda
Tags: attractive, exchange, forces, particle
Share this thread:
anorlunda
#1
Jul20-14, 09:18 AM
P: 215
Above is Figure 65 from Feynman's book QED. It shows the bidirectional stream of photons between an electron and a nucleus, that Feynman says "keeps the electron within a certain range." I can visualize repulsive forces, but I'm having trouble with attractive forces.
I understand that force comes from the gradient of fields, and that fields result from the presence of particles, so I should be able to answer my own question, but I'm having trouble putting it all together.
"Feynman diagram general properties" by Maschen
My thinking reflects the Feynman diagram above that I found on Wikipedia. As long as a right moving photon carries only right pointing momentum, (ditto for left) it can only produce repulsive forces. It sounds like I am describing radiation pressure, which indeed can only be repulsive between two emitting neighbors. But I fail to include in the analysis the magnitude and signs of the charges of the two particles, which is the elephant in the room.
As I see it, Feynman's Figure 65 would be the same if I substituted a positron for the electron, and Maschen's Feynman diagram would be the same regardless of charges. So there's got to be more to the story.
What am I missing, and where is a source I can go to learn more about it?
p.s. I have the same conceptual problem with gluons, Z bosons, W bosons, and gravitons. If they are simply carriers of momentum, exchanges of particles should create only repulsive forces. Clearly I'm thinking wrong.
Phys.Org News Partner Physics news on Phys.org
'Squid skin' metamaterials project yields vivid color display
Team finds elusive quantum transformations near absolute zero
Scientists control surface tension to manipulate liquid metals (w/ Video)
Simon Bridge
#2
Jul20-14, 09:25 AM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 13,052
This is a common question:
http://math.ucr.edu/home/baez/physic...particles.html
... question (2).
TLDR: you have correctly identified a flaw in the picture you have already been given. The actual model is somewhat more complicated than that.
anorlunda
#3
Jul20-14, 09:50 AM
P: 215
Wow; that's quite an answer. It will take me some time to absorb it. Thank you Simon Bridge.
Register to reply
Related Discussions
Attractive force from gauge particle exchange High Energy, Nuclear, Particle Physics 8
Explain electromagnetic attractive and repulsive force via virtual photon exchange? High Energy, Nuclear, Particle Physics 3
Attractive exchange forces? Quantum Physics 13
Attractive forces High Energy, Nuclear, Particle Physics 2
Particle exchange forces High Energy, Nuclear, Particle Physics 26
