Newton's third law in ropes and tension
In summary: Newton's 3rd law) and the force the other person exerts. If the 2 people have unequal force (e.g. 1 person has 200 N and the other has 100 N), then the tension in the rope will be different because the force the other person is exerting is not equal to the force the 1 person is exerting.
davidbenari
466
For some reason I couldn't answer this, and I hope you can help me:
a) Two people pull on a rope, one with 200 N , the other 100 N. Why is the tension on the rope the shared magnitude of both forces?
b) If two people pull on a rope with equal force (say, 100 N), each person pulling feels their own force (Newton's 3rd law) plus the force the other guy exerts. Why is the tension not 200 N then?
c) If you could also explain what really happens in (b) with another combination of forces (non-equal), addressing how Newton's third law works in that case, I'd appreciate it very much. (say, 200 N and 100 N).
Thank you very much.
Science news on Phys.org
What do you mean by "shared magnitude of both forces". If the rope is presumed massless (as typically done in physics exercises), then the net force on the rope must be zero. So it would be impossible for the two people to pull with different forces.
Says who?
If you pull the rope with a force X, then the tension in the rope is X.
Again, for a massless rope they cannot pull with unequal forces. For a real rope with mass, if they were to pull with those forces then the tension would vary from 200 N on one end to 100 N on the other. Realize that there would be a net force on the rope, which will cause it to accelerate.
This is like the "man walks into a bar" joke.
If two people pull on a rope, the first pulls with 100 N and the second pulls back with 200 N, then the first person will probably fall down. They need to both be pulling with the same force (e.g., 200 N) but in opposite directions to keep the rope stationary between them.
You pull "back" on the rope, it pulls "forward" on you (indirectly because of the other person). That's Newton's 3rd law.
The forces are always equal. That's why the 3rd law is as stated.
Why can't a massless rope have a net force? I know it's a little bit weird because of F=m*a but without caring much about how it's accelerating why can't we say it has a net force? I think this is what happens in the atwood problems from typical physics exercises where unequal weights are hanging on each side.
Also, you're saying the felt tension is only equal to the reactive force?
What I mean by shared magnitude is that if one person exerts 200 N and the other 100 N the tension is only 100 N because that's the magnitude they both share. That's what I read somewhere else (in another forum).
Is this problem hard because it's suggesting something which isn't really possible?
It's kind of a bad idealization when what you care about is the acceleration of the rope.
If you care about the acceleration of some dangling weight, then you can at least say the mass of the rope is "negligibly small" compared to the weight.
It should be.
Ok so assuming a rope with mass held between two astronauts in space, and one astronaut pulls with 200 N while the other pulls 100 N. What happens to the system? To each astronaut? To the rope?
Also, I'm interested in what made you think the scenario was impossible for the massless rope. I know it was the fact that it's massless, but I'd like to know what you think would've happened that made you say this was unreal.
Thanks.
I don't think it's possible for the astronauts to pull on the rope with different tensions. I dunno, unless there's something I'm overlooking.
My earlier example might have been a bit misleading: suppose you're holding on to the rope and the other astronaut yanks on it with 200 N. You will have to pull back with 200 N if you plan to keep holding on to the rope.
If you both pull on the rope with 200 N then I guess you'll both accelerate toward each other at whatever rate 200 N produces on your respective bodies.
You can't "not care" about its acceleration.
As long as the pulley is massless and frictionless, the tension is the same throughout the rope.
Newton's 3rd law applies. By definition, the tension is the force that the rope exerts on whatever is pulling it. So if the tension is 100 N, that means you are pulling with 100 N.
As I said before, if one person pulls with 100 N and the other with 200 N, then the tension will have to vary across the rope. (If the rope has no mass, this will be impossible.)
Not clear what the problem is that you need to solve.
Ah yes—this is another possibility. The rope can be stretchy/springy.
You cannot assume that because they may want to pull with those forces that it is actually possible. But if they did pull with such forces, the rope would accelerate. (I don't see how that would be possible, except for a short time, since the astronauts will be pulling themselves as well. Regardless of how they pull on the rope, the center of mass of the system--rope plus astronauts--cannot accelerate.)
Maybe this question is stupid and I should work out the answer but:
If the tension is just the reactive force, then how can it be the same throughout a rope that holds two unequal weights in an atwood machine, and how could these masses even accelerate? I.e. I'm imagining that since one weight pulls down with Mg and the other mg, tension will just pull back on each side with an equal force that's respective to each mass. Why isn't this the case?
Yeah so now I think I understand what you're asking.
Think of this:
Two weights, each of mass M, connected through pulleys. If the situation is totally stationary then would you agree or disagree that each half of the system is identical to a system with no pulley and the mass M just dangling from a fixed rope?
I would agree to that.
Your mistake is assuming that the the mass pulls down on the rope with a force equal to mg (its weight). But that is incorrect. Realize that mg is the force that the Earth pulls on the mass, not the force that the mass pulls on the rope. The actual force that the mass pulls on the rope depends on the mass on the other end of the rope. (For example, remove that other mass and the tension in the rope goes to zero.) Regardless, in the massless rope approximation, the tension will be the same on both ends of the rope.
Also: If the mass pulled the rope with a force equal to its weight, then by Newton's 3rd law the rope would have to pull up on the mass with an equal force. That would make the net force on the mass always equal to zero! (Of course, if the two masses are equal then the tension would equal their weight. But that's a special case.)
Likes 1 person
Okay, so Doc Al has already explained what I was going to say. :smile:
Likes 1 person
If it did the acceleration would be infinite. Although it is an approximation, it is usually a good approximation to think about. In real life, if a rope is not massless but is very light compared to the masses of the other bodies, then the difference in the forces will be close to zero.
For example, in your 200 N astronaut and 100 N astronaut example, by Newton's 3rd law the net force on the rope would be 100 N. If the rope weighed 10 grams then it would accelerate at 10000 m/s^2.
Presumably it would be difficult for an astronaut to accelerate a rope at that rate, so using the massless approximation and ensuring that the forces are equal helps catch little mistakes.
And would you say the rope in an atwood machine is accelerating? (the rope is massless and unequal masses hang on both sides). Also: Why is the tension in a massless string assumed to be constant all throughout even if its moving like in the case of the atwood pulley?
What is the rate of change of the momentum of a section of massless rope?
How does the net force on a section relate to the rate of change of momentum in that section?
Yes, the rope in an Atwood machine is accelerating. Since the mass is zero it doesn't require any net force to accelerate.
In reality, of course, it will have some weight, but if it is small relative to the other masses then it is negligible and using the massless approximation (equal tension) won't be too big of an error.
Likes 1 person
I guess the rate of change of momentum = 0 given that the rope is massless. If the net force on a section is 0, then the rate of change in momentum is 0 too. But the rope is accelerating in atwood pulley problems!
DaleSpam: and why is the tension assumed to be equal throughout, what's the rationale here? Thanks.
The net force on any segment of the massless rope must be zero. That implies that the tension is the same throughout.
Then how is it accelerating in an atwood pulley problem (if there's no net force)?
It's just an approximation. If the rope is treated as massless, then no net force is required to accelerate it. It just goes along for the ride.
Likes 1 person
:uhh:
Draw a free-body diagram for any segment of the rope. Since ∑f=ma and since m=0 we have that ∑f=0 regardless of a. Therefore the force is the same on each end of any segment, therefore the tension is constant.
You have two bodies, M and m. Gravity is pulling (down) with force -Mg on the one and -mg on the other. Between them is a rope that pulls (up) on each with tension T.
If M = m then the entire system is not moving, so it must be true that the net force T - Mg = 0 and therefore T = Mg.
If M > m, then you expect that the larger weight to fall and the smaller weight to rise. This happens if mg < T < Mg. Then there's a net force on each body: T < Mg (hence the M weight falls) and similarly T > mg (hence the m weight rises).
You can work out the acceleration since it has to be the same throughout the system: the two weights and the rope all move together.
1. What is Newton's third law?
Newton's third law states that for every action, there is an equal and opposite reaction. This means that when an object exerts a force on another object, the second object will exert an equal and opposite force back on the first object.
2. How does Newton's third law apply to ropes and tension?
In the case of ropes and tension, when a force is applied to one end of a rope, the rope will exert an equal and opposite force on the object at the other end of the rope. This is known as tension. The object at the other end will also exert an equal and opposite force on the rope, keeping it taut and preventing it from breaking.
3. Can Newton's third law be observed in everyday life?
Yes, Newton's third law can be observed in many everyday situations. For example, when you push a door open, the door exerts an equal and opposite force back on you. In the case of ropes and tension, you can see this law in action when you pull on a rope and it pulls back on you with the same amount of force.
4. How does the mass of an object affect Newton's third law in ropes and tension?
The mass of an object does not affect Newton's third law in ropes and tension. This law applies to all objects regardless of their mass. However, the mass of an object can affect the amount of tension in the rope. A heavier object will require more force to move, resulting in greater tension in the rope.
5. Are there any exceptions to Newton's third law in ropes and tension?
No, there are no exceptions to Newton's third law in ropes and tension. This law is a fundamental principle of physics and applies to all objects and forces, including those involved in ropes and tension. It is a universal law that has been observed and tested in countless experiments.
  • Thermodynamics
  • Thermodynamics
  • Classical Physics
  • Thermodynamics
  • Mechanics
