Finding Initial Velocity with no time or other Velocities
In summary: Try getting them all correct and then we can look at what the final speed might be.Well, the general technique is right, but you keep making mistakes like v instead of 1/v, so it's difficult to say without seeing... the calculations. Try getting them all correct and then we can look at what the final speed might be.
Hypnos_16
153
An Olympic basketball player shoots towards a basket that is 5.52 m horizontally from her and 3.05 m above the floor. The ball leaves her hand 1.52 m above the floor at an angle of 32.0o above the horizontal. What initial speed should she give the ball so that it reaches the basket and hopefully scores?
all i can get out of this is
dx = 5.52m
dy = 3.05 though she's only shooting 1.53m to the basket
Theta = 32 degs
ay = -9.81
I don't know how to get the time out of this problem, nor the velocity
any time i try I'm told it would be easier to merge two equations, though i don't know how.
Please someone help.
Welcome to PF!
Hi Hypnos_16! Welcome to PF! :smile:
(have a theta: θ :wink:)
Call the speed v, and use the x components to find t.
Then use that value of t in the y components to find how high the ball is.
Show us what you get. :smile:
so I've tried writing out the formula. i got this
x = x1 + v1t
5.52 = 0 + v1t
5.52 = v1t
t = 5.52/v1
but i don't know what to do from there, i don't know even if that's right, and if it is where do i plug that into?
x = x1 + v1t
5.52 = 0 + v1t
5.52 = v1t
t = 5.52/v1
(try using the X2 icon just above the Reply box :wink:)
good so far, now your v1 in that equation has to be the initial component of velocity in the x direction, which is v times … ? :smile:
times v by cos of 32 degs! then you get t with a value v that you can use to find v1! okay i think i get it now
t = 5.52/v1cos32
t = 6.51v1
x = x1 + v1t
5.51 = 0 + v1 x 6.51v1
5.51 = 6.51v1^2
v1 = 0.92m/s
i got this, but it doesn't seem right.
i then got a time of 6 seconds, which seems to high.
That's it! :wink:
If you have any difficulty with the rest of the problem, just come back and tell us. :smile:
so i got the v in the x direction as 0.92m/s the time in the air to be 6 seconds but the v in the y direction seems outrageously high. I think i goofed up somewhere.
x = x1 + v1t
5.52 = 0 + v1t
5.52 = v1t
t = 5.52/v1
t = 5.52/v1cos32
t = 6.51v1
x = x1 + v1t
5.51 = 6.51v1^2
v1 = 0.92m/s
t = 6.51(0.92)
t = 6s
dy = y1 + v1t -gt^2
3.05 = 1.53 + sin32v1(6) - 4.9(36)
1.52 = sin32v1(6) - 176.4
177.92 = sin32v1(6)
177.92 = 3.18v1
55.9 = v1
Hypnos_16 said:
x = x1 + v1t
5.52 = 0 + v1t
5.52 = v1t
t = 5.52/v1
t = 5.52/v1cos32
t = 6.51v1
No, the last two lines should be
t = 5.52/vcos32
t = 6.51/v, shouldn't it?
(where v is the total initial speed)
Now use that value of t (ie use 6.51/v ) in an equation for the y direction. :smile:
so after i fill that in for t do i have to work out the result as a quadratic equation?
dy = vy1 + v1t - gt^2
3.05 = 1.53 + sin32(6.51v) - 4.9(6.51v)^2
1.52 = 3.45v - 207.7v^2
0 = 1.52 + 3.45v - 207.7v^2
that's the answer i got.
would finding this result in finding the initial overall speed or are there more steps?
No, it's 6.51/v, not 6.51 times v. :redface:
(and i think you got your 1.53 and 1.52 the wrong way round)
we defined v as the initial overall speed, didn't we? :rolleyes:
so how would you multiply sin32(6.51/v) and 4.9(6.51/v)^2?
uhh? :confused:
it's just (sin32*6.51)/v and (4.9*(6.51)2)/v2.
get some sleep! :zzz:
will do, after i get this one done
so after all that work i got 11.7m/s
does that seem like it would be the right answer?
erm :redface: … I don't mind checking your calculations, but I'm not going to do the work myself! :wink:
No that's fine you don't have to do it for me, i just want to make sure I've done it correctly, make sure the math is right.
Well, the general technique is right, but you keep making mistakes like v instead of 1/v, so it's difficult to say without seeing the whole thing.
I'm off to bed now, anyway …
goodnight! :zzz:​
1. How can initial velocity be calculated without knowing time or other velocities?
The initial velocity can be determined using the equation v = v0 + at, where v is the final velocity, v0 is the initial velocity, a is the acceleration, and t is the time. If the time and other velocities are unknown, then the equation can be rearranged to solve for v0: v0 = v - at.
2. What information is needed to calculate the initial velocity?
In order to calculate the initial velocity, at least two of the following three values are needed: final velocity (v), acceleration (a), and time (t).
3. Can the initial velocity be negative?
Yes, the initial velocity can be negative. A negative initial velocity indicates that the object is moving in the opposite direction of the positive direction chosen in the problem.
4. How does the angle of launch affect the initial velocity?
The angle of launch does not affect the initial velocity, as it only determines the direction of the initial velocity. The magnitude of the initial velocity is determined by the other factors in the problem, such as the acceleration and time.
5. Can the initial velocity be greater than the final velocity?
Yes, the initial velocity can be greater than the final velocity. This can occur in cases where the object is decelerating or slowing down due to a force acting in the opposite direction of its motion.
9K
