| New Reply |
NAND Logic 4 input circuit with nonstandard output |
Share Thread | Thread Tools |
| Nov25-12, 07:22 PM | #1 |
1. The problem statement, all variables and given/known data
I have a weird boolean algebra expression for which I need to build a circuit using solely the NAND gates. There are 4 inputs A,B,C,D. From the truth table (I do not know how else to approach this question other than constructing the truth table and then trying to fit the output by playing around with gates) it seems that the output is zero unless C and D are both 1's or A and B are both 1's or more than two variables are 1's 2. Relevant equations 3. The attempt at a solution Built the truth table. Aside from looking for tips to solve this, I am also looking to find out if there is some general method or rule of approaching these things. 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Nov26-12, 01:44 AM | #2 |
We don't see any truth table or expression.
| Nov26-12, 06:01 AM | #3 |
Recognitions:
| New Reply |
| Thread Tools | |
Similar Threads for: NAND Logic 4 input circuit with nonstandard output
| Thread | Forum | Replies | ||
| 3 input XOR gate using NAND gate only ( Logic ) | Engineering, Comp Sci, & Technology Homework | 3 | ||
| 3 Input Majority Logic Circuit | Electrical Engineering | 4 | ||
| 3-input AND - NAND equivalent? | Engineering, Comp Sci, & Technology Homework | 14 | ||
| Can the output voltage of a circuit be larger than its input | Electrical Engineering | 9 | ||
| How To Implement This Function With 2 Input Nand without.. | Engineering, Comp Sci, & Technology Homework | 3 | ||
