Absorption line spectra and emission line spectra
In summary: In many cases they would, although it depends on what transition you're talking about, but anyhow.. In general, if you want to measure an emission spectrum, you do so at a 90 degree angle from your excitation source, so that those photons don't enter your detector. The re-emitted photons go in all directions.Thanks for your help.
Zman
96
Why don’t emission and absorption properties of an atom cancel out such that no such spectral lines are seen.
If electrons in atoms are excited from level 1 to level 2 and absorb energy at some specific frequency, why don’t they then emit that same frequency when they fall back down to level1 and cancel out the absorption lines with the emission lines.
Thanks
Imagine a dense gas cloud. You look at a star through it. The resonance photons are obsorbed in the gas and then the excited atoms/molecules collide and transform the excitation energy into heat. Then the cloud will absorb this spectral line.
If there is no non-radiative loss mechanisme, then the cloud will diffuse the absorbed light to all directions which is somewhat similar to partial absorption.
Hi Zman-
I have looked at the sodium doublet (yellow)D-lines with a ruled grating spectrometer. The sodium arc is a lot hotter than the surrounding cool sodium gas. The cooler gas absorbs the emission lines in the center of each sodium line, so that the resultant sodium D-lines each have a narrow absorpton notch in the center.
Bob S
A valid question. In many cases they would, although it depends on what transition you're talking about, but anyhow.. In general, if you want to measure an emission spectrum, you do so at a 90 degree angle from your excitation source, so that those photons don't enter your detector. The re-emitted photons go in all directions.
Thank you for your helpful responses.
What would you see if placed the detector head on instead of 90 degrees.
Would the absorption lines just be reduced?
If a photon is absorbed by an atom, presumably the direction of the subsequent emission is not necessarily related to the original direction of the photon.
Is this emission direction random or maybe even like a diffraction pattern?
It would make sense that it was something like this from what has been said. The absorption spectra would seem to require it.
And yet with a mirror the incident direction of the photon is related to the emission direction of the photon. But presumably the photons here are not being absorbed and there is a different rule at work.
Would the absorption lines just be reduced?.
Hi Zman-
If the absorber were placed directly in between the (thermally hotter) source and the (colder) absorber, you would see a dark band in middle of the source emission line(s). It is very educational to look at the sodium D lines (about 5880 Angstroms) with a diffraction grating. You will see the two 3P to 3S lines, each with a dark absorptin band in the middle.
Bob S
1. What is the difference between absorption and emission line spectra?
The main difference between absorption and emission line spectra is that absorption spectra show dark lines against a continuous spectrum, while emission spectra show bright lines against a dark background. This is because absorption spectra occur when light passes through a medium and certain wavelengths are absorbed, while emission spectra occur when a medium emits light at specific wavelengths.
2. How do absorption line spectra and emission line spectra help scientists study matter?
Absorption and emission line spectra are important tools for scientists to study matter because they provide information about the elements and compounds present in a sample. Each element or compound has a unique set of absorption and emission lines, which can be used to identify and analyze the composition of a sample.
3. What causes the dark and bright lines in absorption and emission line spectra?
The dark and bright lines in absorption and emission line spectra are caused by the transitions of electrons between energy levels in atoms or molecules. When an electron absorbs energy and jumps to a higher energy level, it creates a dark line in the absorption spectrum. On the other hand, when an electron emits energy and falls to a lower energy level, it creates a bright line in the emission spectrum.
4. Can absorption and emission line spectra be used to determine the temperature of a star?
Yes, absorption and emission line spectra can be used to determine the temperature of a star. The intensity and width of spectral lines can provide information about the temperature of the star's surface. Hotter stars have broader and more intense lines, while cooler stars have narrower and less intense lines.
5. Are absorption and emission line spectra only found in visible light?
No, absorption and emission line spectra can be found in various regions of the electromagnetic spectrum, including radio waves, microwaves, infrared, visible light, ultraviolet, X-rays, and gamma rays. Each region can provide different information about the composition and temperature of a sample, making them valuable tools in scientific research.
  • Other Physics Topics
16K
  • Astronomy and Astrophysics
