Why is Mars so easily visible to the naked eye?
  • Thread starter Solon
  • Tags
    Eye Mars
In summary, the conversation discusses the visibility of Mars by eye when it is close to a bright, almost full Moon. The accepted limit of resolution of the eye is 1 minute, but Mars has an angular diameter of less than 1/2 an arc minute. It is explained that for point objects, only brightness matters in visibility, and point objects that are bright can appear large due to blooming or saturation. The conversation also touches on the possibility of calculating the number of photons per second required for an observer to consciously register the planet. The conversation ends with a discussion about the magnitude of the Moon and Mars as seen from Earth and the ISS.
Solon
32
I have been trying to figure out why I can see Mars, by eye, even when it is very close to a bright, almost full Moon. Firstly, Mars at its closest to Earth only has an angular diameter of less than 1/2 an arc minute, while the accepted limit of resolution of the eye is 1 minute. That equates, by my recconing, to seeing a basketball at about 2,000 meters.
With a self luminous body such as a star, I am told it is due to luminosity, but Mars is only reflecting the Suns light. The apparent diameter of Mars, using Celestia, is over 4 minutes, which explains why it is so easily visible, but why is it so apparently large?
Mars has an albedo not much greater than the Moon, averaging about .15, and I have used a Lambertian model of reflection. Total solar irradiance at Mars averages less than half of Earth (and the Moon) value.
Where I have run into difficulties, and can find nobody so far to calculate, is how many photons per second would reach an observer on Earth, and how many per second are required for them to consciously register. I have read that the eye may have single photon sensitivity, but between 150 and 500,000 photon/sec are needed for us to become aware of.
Just wondering if I am missing something obvious here, or if we really don't understand light, vision and perception well enough to be able to fully explain the process?
Astronomy news on Phys.org
Welcome to PF!
"Resolution" is being able to tell two objects apart or being able to see the size of one object. It isn't required for viewing a point object, such as a planet or start. Only brightness matters in visibility.
Point objects that are bright can appear large due to blooming or saturation. Basically, you're seeing extra glare and atmospheric refraction that isn't exactly along the line of sight of the planet, making for a larger apparent diameter.
Well that's where I can't understand this model, as the tiny looking Sun seen from the surface of Mars surely is not lighting Mars to such a brightness that it can be seen so easily from Earth? I'd really like to see some figures, my results fall far short, in fact Mars would only be visible by eye out to about 300,000 miles. Or less.
Fair enough, but Mars is by no means bright by my understanding, that's why I am here, cap in hand, wondering if anyone can provide an end-to-end explanation of the mechanisms, formulas and calculations required to quell the doubts I'm having. I've asked around, no satisfactory responses so far, maybe all the really smart folk hang out on PF?
It would help if we knew how you were calculating this figure so we can correct where you've gone wrong.
how on Earth did you come up with that figure ??
do you realize how big Mars is, say compared to the Moon ?
Do you realize the Moon is ~ 240,000 miles distant from the Earth ?
then consider how huge and bright Mars would be in our sky if it was in the same position as the moon
Dave
drakkith said:
it would help if we knew how you were calculating this figure so we can correct where you've gone wrong.
snap :)
d
To do the calc, I'd start with the moon's magnitude, then ratio the square of the earth-sun to mars-sun distances and earth-moon and earth-mars distances.
Edit: using that method with the numbers pulled out of the air, I get a mag of -1.5, which sounds pretty reasonable. So let's see how your calc compares.
The magnitude as seen from Earth I assume. Than got me to wondering about the magnitude from the ISS say, where there is much less atmosphere to affect the Moonlight. All the images I can find however show the Moon from the ISS in a Moonrise or Moonset position, so looking through a dense column of atmosphere, with a line of sight to the Moon that dips down pretty deep into the atmosphere. I'd like to know how the Moon appears in a mid-day position, looking perpendicular to Earth surface, but can not find such an image. Or an image of Mars at all from the ISS, too bad they don't do any astro-photography from the ISS when it is such a good platform.
The Solar-Solspec experiment has been up and running on the ISS for quite some time now, but it does not seem capable of doing analysis of the Moon, which I think would be interesting seeing as it has a 1 nm resolution. What sunlight wavelengths are absorbed, or created through solar UV emissions? Also, I was hoping there might be a video of the Moon from the ISS from one of the colour cameras on the Canadarm2, but again don't see anything. Would the Moon look the same from there as on a video taken from Earth?
I did find an interesting page about the sky at night being blue, not black, which seems to indicate a Moonlight spectrum the same as Sunlight. So I learned something today, if not the answers I'm looking for.
The Digital Blue Sky at Night(PDF)
http://www.osa-opn.org/opn/media/Images/PDFs/9357_19075_97281.pdf?ext=.pdf
This is the best image of the Moon from the ISS that I can find, but it seems to be a crop of one of the larger images that are taken close to Moonrise or Moonset, with the Earth just out of shot.
http://i.space.com/images/i/000/005/980/i02/moon-watching-night-100916-02.jpg?1294154541
http://www.space.com/55-Earth's-moon-formation-composition-and-orbit.html
Except for being a tiny bit brighter and not having to deal with blurring from the atmosphere, it doesn't look any different from the ISS than it does from the surface of the Earth. Of course if you get really really in depth you could measure the intensity of each part of the spectrum and you'd see a very small difference thanks to atmospheric absorption and scattering, but this is far too little to "see" normally.
1. What is naked eye visibility of Mars?
Naked eye visibility of Mars refers to the ability to see the planet Mars with the unaided eye, without the use of telescopes or other equipment.
2. How often can Mars be seen with the naked eye?
Mars can be seen with the naked eye every 1.6 to 2.1 years, when it is at its closest approach to Earth. This is known as opposition, and it occurs when Mars and Earth are on the same side of the Sun.
3. What factors affect the naked eye visibility of Mars?
The naked eye visibility of Mars is affected by multiple factors, including its distance from Earth, its position in its orbit, and atmospheric conditions such as weather and light pollution.
4. Can Mars ever be as bright as Venus in the night sky?
No, Mars can never be as bright as Venus in the night sky. Venus is the brightest planet in our solar system and can appear up to 100 times brighter than Mars. However, during opposition, Mars can appear as one of the brightest objects in the sky.
5. What is the best time to view Mars with the naked eye?
The best time to view Mars with the naked eye is during opposition, when it is at its closest approach to Earth. This typically occurs every 1.6 to 2.1 years, but can vary slightly due to the elliptical shape of Mars' orbit.
  • Astronomy and Astrophysics
  • High Energy, Nuclear, Particle Physics
  • Quantum Physics
