Knowledge required for a research project using Kelvin Probe
In summary, the conversation discussed the use of a Kelvin Probe in a research project and the necessary background knowledge for understanding its operation. The individual asking the question has a year of introductory physics but needs to learn about solid state physics, work function, Fermi level, and energy bands for metals, semiconductors, and insulators. They also need to familiarize themselves with the physics and operations of the Kelvin Probe. The experiment involves finding surfaces with inhomogeneous work functions and will primarily be done on metals using a dedicated Scanning Kelvin Probe. The individual also asked for recommended resources for learning the necessary material.
ahsanxr
350
Alright so a professor took me up for a research project which makes use of a Kelvin Probe. However I only have a year of introductory Physics under my belt (Mechanics and Waves & Oscillations). I started studying some of E&M which I assumed I needed to know, this summer but didn't get too far, only the first 3 chapters (Forces & Fields, Gauss' Law, and Electric Potential). I want to know what are the topic I should be focusing on in order to understand what I'm doing with the probe. I realize that ideally I should have a good mastery of E&M but I'm going to start using the probe on Monday so I don't really have time to do that. The experiment has to do with finding surfaces with inhomogeneous work functions or something of the like. Thanks for answering.
You need to learn a bit of solid state physics. You need to know the meaning of work function, Fermi level (or energy), the energy bands for metals, semiconductors, insulators, etc. It gets a bit more involved depending on what you are using. You didn't indicate if you will be using a dedicated Kelvin probe, or if you are using something like an STM or AFM that can be converted into the Kelvin probe mode. You also didn't say on what material you will be measuring, or if you have to do your own calibration of the Kelvin probe tip. A measurement done on metals will give you directly the work function, whereas a measurement on a semiconductor will give you the Fermi level.
Of course, you should also learn about the physics and operations of a Kelvin Probe. Look at this article if you haven't seen it:
http://arxiv.org/abs/1105.4644
Zz.
Zz.
Well the one we're using is called a Scanning Kelvin Probe (so its dedicated) and the first measurement we tried to do was a material with gold coating (we weren't able to do it because the tip wasn't oscillating for some reason, its fixed now). I think we're going to be doing most of the measurements on metals. And we're using a software to control the tip, i.e the amplitude of oscillations. Also are there any prereqs for learning the material you stated and furthermore are you aware of any good resources which teach them (online or textbooks)? I would greatly appreciate it.
Bump?
I would recommend focusing on the following topics in order to understand the use of a Kelvin Probe in your research project:
1. Electric fields and potential: Understanding the concept of electric fields and how they relate to electric potential will be crucial in using the Kelvin Probe. This includes understanding how electric fields are created and how they can be measured.
2. Work function: The principle behind the Kelvin Probe is based on measuring the work function of a material. It is important to have a basic understanding of this concept in order to interpret the results of your experiment.
3. Surface topography: The Kelvin Probe is used to map the surface topography of a material, so having a basic understanding of surface topography and how it can affect work function measurements will be helpful.
4. Inhomogeneous materials: Your experiment involves finding surfaces with inhomogeneous work functions. It would be beneficial to have a basic understanding of inhomogeneous materials and how they can be characterized using the Kelvin Probe.
I understand that you may not have enough time to fully master these topics before starting your experiment, but I would recommend focusing on these areas and seeking guidance from your professor or other resources as needed. It is important to have a solid understanding of the underlying principles in order to effectively use the Kelvin Probe and interpret your results. Good luck with your research project!
1. What is a Kelvin Probe?
A Kelvin Probe is a scientific instrument used to measure the contact potential difference between two conductors or semiconductors. It can also be used to measure the work function, which is a measure of the energy required to remove an electron from a material's surface.
2. What types of materials can be studied using a Kelvin Probe?
A Kelvin Probe can be used to study any conductive or semiconductive material, including metals, semiconductors, and thin films. It is also commonly used to study surface properties of materials, such as work function, electron affinity, and surface potential.
3. What knowledge is required to operate a Kelvin Probe?
To operate a Kelvin Probe, knowledge of basic electronics and principles of surface science is required. This includes an understanding of voltage, current, and capacitance measurements, as well as knowledge of surface properties and their effects on the measurements.
4. How is a Kelvin Probe different from other surface analysis techniques?
A Kelvin Probe is unique in that it measures the work function of a material, which is not typically measured by other surface analysis techniques. It is also a non-destructive technique, meaning it does not damage the sample being studied.
5. What are some applications of a Kelvin Probe in research projects?
A Kelvin Probe can be used in a variety of research projects, including surface analysis of materials, investigation of semiconductor properties, and evaluation of surface treatments or coatings. It is also commonly used in the study of corrosion, adhesion, and catalytic reactions on surfaces.
  • STEM Academic Advising
