On the nature of the infinite fall toward the EH
In summary: The summary is that observers Alice and Bob are hovering far above the event horizon of a block hole. Alice stops hovering and enters free fall at time T_0. Bob waits an arbitrary amount of time, T_b, before reversing his hover and chasing (under rocket-propelled acceleration A_b) after Alice who continues to remain in eternal free fall. At any time before T_b Alice can potentially be rescued by Bob if he sends a light signal. However, once T_b passes, there is no possibility for Bob to rescue her.
  • #351
An interesting intuitive approach for this problem is presented by Epstein in his book "Relativity Visalized". He uses space-propertime embeddings of the Schwarzshild-Metric like this one:
http://www.adamtoons.de/physics/gravitation.swf
"space" : radial Schwarzshild coordinate r
"proper time" : the proper time elapsed along the cyan world line
length of the world line : Schwarzshild coordinate time t
inflation of the "pipe" at certain r : time dialtion of a static clock at that r relative to t
For a BH the funnel would inflate infinitely into a plateau at the event horizon:
The cyan world line here can have an infinite length (coordinate time t) but will still cover a finite angular displacement around the pipe (proper time)
  • #352
grav-universe said:
Just a quick mention that in Schwarzschild coordinates, sqrt(1 - 2 m / r) = K sqrt(1 - (v'/c)^2), where v' is the speed that is locally measured by a static observer at r and K is a constant of motion, with K = 1 for a freefall from rest at infinity, so those two statements would be equivalent in terms of dt and dτ in that case.
Thank you.
As free fall from rest at infinity was in fact the context of the thread I was correct in my understanding then , right??
Am I correct in assuming that K=1 in this case is related to free fall velocity at a particular r being equivalent to the escape velocity at that location, which is the case when starting from v=0 at r=∞?
  • #353
Austin0 said:
Thank you.
Actually, you were correct regardless of where the object falls from or the value of K. K is the constant of motion for freefall here, so with the initial conditions v' = 0 at r = ∞, we get
K = sqrt(1 - 2 m / ∞) / sqrt(1 - (0/c)^2) = 1
and K will then remain constant for any r during freefall, even non-radially, so one can find the speed locally measured by a static observer at some other r with
v' = c sqrt[1 - (1 - 2 m / r) / K^2]
Since SR is valid locally, we have
dτ = dt' sqrt(1 - (v'/c)^2)
= dt sqrt(1 - 2 m / r) sqrt(1 - (v'/c)^2)
= dt (1 - 2 m / r) / K
Only the last statement depends upon the value of K. Vice versely if an object were thrown upward from r with the corresponding speed v' where K = 1, that would be its escape velocity also, right.
  • #354
pervect said:
The underlying thought process here is that there is some physically meaningful way to define a "local rate of time". Relativity doesn't necessarily say this. (I think one can make even stronger claims, but it'd start to detract from my point, so I'll refrain from now).
One can certainly say that Alice appears to freeze according to the coordinate time "t". But is this physically significant?
It might be instructive to consider Zeno's paradox. I'll use the wiki definition of the paradox.
Let's define a "zeno time" as follows. At a zeno time of 0, Achillies is 100 meters behind the tortise.
At a zeno time of 1, Achilles is 50 meters behind the tortise.
At a zeno time of 2, Achillies is 25 meters behind the tortise
At a zeno time of n, Achillies is 100/(2^n) meters behind the tortise.
Then, as n goes to infinity, Achillies is always behind the tortise.
So, in "zeno time", Achilles never does catch up with the tortise, even as "zeno time" appoaches infinity.
Are we therefore justified in claiming that Zeno was right, and that Achilles never catches the tortise? I don't think so, and I'd be more than a bit surprised if anyone really believed it. (I could imagine someone who likes to debate claiming they believed it as a debating tactic, I suppose - and to my view this would be a good time to stop debating and do something constructive).So in my opinion, the confusion arises by taking "zeno time", which is analogous to the Schwarzschild coordinate time "t", too seriously. While it is correct to say that as t-> infinity Alice never reaches the event horizon, just as Achilles never reaches the tortise in zeno time, it still happens. It's just that that event hasn't been assigned a coordinate label.
The analogy is actually quite apt regarding light chasing an accelerating system with only the slight modification that the tortoise has some finite constant acceleration. In which case at and beyond some magnitude of head start Achilles (light) can never catch up.
But wrt approaching an EH I think both the paradox and the related theorem that resolves the same kind of unbounded series to a finite value
1/2 + 1/4 + 1/8 + ... = 1
are not validly applicable.
In the first case (Zeno) as the distance incrementally reduces, the velocity of Achilles remains constant. So for each reduction in distance, the time for the next reduction in distance becomes shorter.
So it is obvious, even without a formal mathematical proof, that the difference between an evaluation of some large but finite number of iterations and the self evident ultimate value after an infinite number of iterations effectively disappears.
In approaching the horizon this is not true. Each reduction in distance results in a reduction in speed so increases the time interval for the next distance. Etc etc
As the speed approaches zero nearing the horizon the time approaches infinite which is clearly a whole other ball game. Or at least seems so to me.
Neither the theorem nor the paradox apply.
  • #355
The "speed" that is reduced is just a coordinate "speed". It doesn't have any physical meaning. For example, there is no observer who observes the infalling object moving at this "speed".
  • #356
In Zeno coordinate time the time for the next reduction is constant, by definition. So the Zeno coordinate velocity in fact reduces.
It is the proper time which reduces. And the velocity in some unspecified inertial coordinate system which remains constant.
No, the two scenarios are very closely analogous on this point. Again in SC coordinate time the time for the next reduction is constant, by definition. So as you mention the SC coordinate velocity reduces.
Similarly, the proper time reduces in the SC case, and the velocity in a local inertial frame remains constant. Exactly analogously to Zeno.
  • #357
pervect said:
It could happen. Note, though, that here at PF, we have an educational evnvironment, not a research one. Our goal is not to advance the state of science. While this is of course an important task, it's not our goal.
And ... ? I know that. Why do you think you have to remind me that?
  • #358
Actually I was talking within the context of the original statement of the paradox where the distance was the basis parameter so I didn't look at the specifics of Pervect's Zeno time .
Having done so it appears that it was not explicitly stated that the intervals were equivalent. And in fact they would not correspond to time on any normal clock with a constant rate.
According to such a constant clock the interval between events Zeno t=1 and t=2 would be smaller than between events Zeno t=0 and t=1
Or do you disagree??
So are you talking about an arbitrary clock that speeds up over time ??
Could you explain where you get this "Again in SC coordinate time the time for the next reduction is constant, by definition." In the original, the next reduction was reducing the remaining distance to the horizon by half so how do you get a constant time interval for each of these increments?
  • #359
Yes, he adapted the original paradox deliberately in order to make the analogy with SC time more exact.
I agree completely. Again, the whole point of the analogy is that the exact same thing happens with SC time. For Zeno time, the proper time on Achilles' clock between Zeno t=1 and t=2 is indeed smaller than between Zeno t=0 and t=1. For SC time, the proper time on the free-falling clock between SC t=1 and t=2 is also smaller than between SC t=0 and t=1.
No, I just mean that coordinate time proceeds at a rate of one coordinate second per coordinate second, by definition. It is a simple tautology. If you are using coordinate time as your standard (as the SC proponents want to do) then coordinate time is uniform, by definition, i.e. tautologically.
In SC coordinate time each successive SC coordinate time interval for the free-faller is tautologically constant. In Zeno coordinate time each successive Zeno coordinate time interval for Achilles is tautologically constant. Neither correspond to the proper time on the falling/Achilles' clock.
The analogies diverge quantitatively, but not qualitatively. In SC coordinates each successive SC coordinate time interval does not correspond to half the distance to the horizon, that is a feature of the construction of Zeno coordinates. But in both SC and Zeno coordinates the coordinate distance traveled by the free-faller/Achilles decreases for each successive coordinate time interval. This obviously means that their coordinate velocity is reducing, which you already recognized and pointed out above.
  • #360
As long as v actually is the speed that's locally measured by a static observer, I believe that's correct. I usually use E for K, many sources use ~E.
It wasn't clear to me how v was being defined - I should have asked. I should still ask, because it's still not clear to me how the OP is defining v, and it's very common not to use the correct formula or defintion of v.
The relation between v and the derivatives of the coordinates is moderately messy, but in https://www.physicsforums.com/showpost.php?p=602558&postcount=29
I get (and another poster also gets) in geometric units.
[tex]v= \frac{\sqrt{E^2 - (1 - \frac{2M}{r})}}{E}[/tex](The natural way to do this is via frame fields, but I choose to introduce locally Lorentz coordinates instead. THe intent was to make it easier to follow, I'm not sure how successful it was. But the intent is to use local coordinates rr and tt that agree with the local clocks and rulers.)
This expression for v is also what I get when I solve your equation for v/c (which is just v in geometric units as c is assumed to be 1).
  • #361
DaleSpam said:
Definitely. Changing scientists minds is the whole point of doing physics, both theoretical and experimental. Does that surprise you in any way?
It should be experimental results that can change viewpoint of overwhelming majority of the physicists not theoretical arguments. If there are different theoretical arguments they should get balanced support until it is decided from experiments or observations.
Take for example Higgs boson.
Okay there is another possibility when different viewpoints can't be supported at the same time. We can take one viewpoint as a working hypothesis and go with it for some time.
DaleSpam said:
The point is that the opposition to the existence of the interior of a BH is not based on a sound understanding of the theory.
The point is that discussion between position and opposition to the existence of the interior of a BH lacks scientific basis.
DaleSpam said:
It is based on an unsound elevation of a particular coordinate chart to some priveliged status.
We use some coordinate system to order our observations. In order to compare theoretical predictions with our observations we have to express theoretical predictions in a form that is convenient for that coordinate system.
  • #362
Is your view really that the interior doesn't exist or that collapse freezes? In the case of a collapsing mass, there is an interior at all times.
  • #363
My view is is that there is no such thing as runaway gravitational collapse.
  • #364
That much is true. I think that the bulk of the argument stems from a misunderstanding or mistrust of the basic mathematical framework of GR.
I think you have this backwards. The predictions are all invariants, so all coordinate systems agree. We pick a coordinate system so that the calculation of those invariants is easy.
  • #365
What would stop it? I mean, not the singularity, but the horizon.
  • #366
And what stops it for a supermassive BH, where densities are quite low at SC radius? It's clear what you will see from afar (the cluster of stars slowing, effectively freezing, and forming a black object at essentially SC radius). But for someone orbiting one of the stars in the interior, what do you think is experiences? Are we (from afar) not allowed to ask that just because we can't see it?
  • #367
Austin0 said:
I.e. " Both observers will agree on these relative elapsed times and both observers will agree that the faller has not reached the horizon."
SO in principle there is a finite point, short of the horizon, where both observers will agree that the distant clock reads 1012years and the inertial clock reads some relatively short time (in related threads approx. 1 day has been mentioned for freefall proper time to EH) correct?
This is a rational application of the metric as it pertains to and in both frames, agreed?
How do you manage to turn this into an idea that the free faller reaches the horizon in some relatively short time in the real world. I.e. the majority of the universe which is outside the EH and relatively static.
PAllen said:
I'm not sure the context, but a free fall observer will never see something like 10^12 years on distant clock. As I've explained, if they start free fall from relatively far away, they will see the distant clock fall behind theirs (but not by a lot).
Taking it as given that we are not talking about visually seeing but rather calculating through the metric, how do you calculate that the distant static clock falls behind the inertial clock approaching the horizon?
Could you explain your statement above regarding time on the static clock at infinity??
DO you think that the geometry that the falling clock is passing through has no effect on the periodicity of this clock??
That it would not be red shifted relative to the distant clo9ck equivalent to a proximate static clock?
That the integrated proper times of the relative clocks would not be related by the metric?
That dt=d[itex]\tau[/itex]/(1-2M/r)1/2(1-v2/c2 would not apply?
I was under the impression that it was an implicit assumption of valid coordinate systems that relative velocity was symmetric and reciprocal.
That the velocity of the faller relative to the distant observer is the same as the velocity of the distant observer relative to the faller.
Does this not hold in Sc coordinates?
  • #368
Within limits, we are talking about seeing. In the case of supermassive BH, conditions on event horizon crossing are not extreme in any way.
For a supermassive BH, there is minimal curvature at the horizon.
In the above, you have two limits competing. Remember, v is relative to an adjacent static observer. For any infaller, v->c as horizon is approached. The limit of the product is always finite, and for free fall from infinity represents a redshift at the horizon. Inside the horizon, this formula loses all validity because there are no static observers. However, there is a uniform approach to redshift and clock comparison that I have explained several times on this thread. Using the general method (aside: it is never necessay to use gravitational redshift - that is computational convenience for the very special case of static spacetime - which doesn't exist inside the horizon; it also doesn't exist for to co-orbiting neutron stars), redhshift perceived by an inside horizon observer remains finite, and (for free fall from far away from BH) reshifted up to singularity.
Relative velocity at a distance is undefined in GR. Only relative velocity for nearby observers is defined. Coordinate velocity is not relative velocity. It is a purely arbitrary convention.
There is no such thing as relative velocity for distant observers in GR, at all. The basic issue is that if you bring one 4-velocity over a distance to another, you get a different result depending on what path you choose. That is at the core of the definition of curvature. There is no physical basis to choose one path over another. Thus curvature precludes giving meaning to relative velocity at a distance.
  • #369
stevendaryl said:
Sure.
Near the surface of the Earth, the metric can be described approximately using the line element [itex]ds^2 = (1+gX)^2 dT^2 - dX^2[/itex] where [itex]X[/itex] is the height above the surface, and [itex]g[/itex] is the acceleration due to gravity.
In these coordinates, we can compute the "rate" [itex]\dfrac{d \tau}{dT}[/itex] for a clock at rest at height [itex]X[/itex]:
[itex]\dfrac{d \tau}{dT} = (1+gX)[/itex]
So higher clocks (larger [itex]X[/itex]) have a higher rate. In particular, if an observer at sea level sends a signal once per millisecond (according to his clock) toward an observer on top of a mountain, the arrival times for the signals will be slower than one per second, according to the clock at the top of the mountain.
Now, transform coordinates to free-fall coordinates [itex]x,t[/itex] defined by:
[itex]x = (1/g + X) cosh(gT) - 1/g[/itex]
[itex]t = (1/g + X) sinh(gT)[/itex]
In terms of these coordinates, the metric looks like:
[itex]ds^2 = dt^2 - dx^2[/itex]
This is the metric of Special Relativity. In these coordinates, there is no "gravitational time dilation". The locations of clocks have no effect on their rates. In particular, a clock at sea level will have the same rate as a clock on top of a mountain. Initially.
So, how, in terms of these coordinates, does one explain the fact that signals sent once per millisecond from an observer at sea level arrive on top of a mountain at a rate lower than that? Well, in the free-falling coordinate system, the two observers are accelerating upward. Each signal sent by the observer at sea level must travel farther than the last to reach the observer on the mountain. So the free-falling coordinate system attributes the difference in send rates and receive rates purely to Doppler shift, not to time dilation. (At least initially.)
Interesting. Wouldn't you agree that free falling (inertial ) systems of more than very limited radial extent are highly problematic for various reasons.
EG. The Born rigidity question rears its head. Differential acceleration and velocities at separated locations etc.
But ignoring these considerations for a moment:In principle measurements of static clocks at two heights could be accomplished by falling observers without necessity of signal exchange between the static clocks. Comparing elapsed times on two separated clocks for extended intervals which is what is required to measure rate which is not instantaneously determinable.
So it would seem that to the extent that observations from an infalling frame aren't too ambiguous to be meaningful they support the validity of gravitational dilation as an independent local effect of mass.
Regarding the EP ,,,I certainly consider it one of the most brilliant and productive abstract bootstraps in scientific history. And the result, the relativity of time flow due to gravity is beyond question at this point. That being said I think that it is somewhat abused in certain cases and that there are limits to its validity as an analogy .
SO the difference in local rates can be empirically demonstrated simply by relocation without need of a coordinate system beyond identical uniform rate parameterization. This is a physical fact or as close to a fact as any of our physics gets so what does it really mean to say that it is "as if" the clocks were actually moving radially upward under impulse and so the dilation isn't really due to gravity but is from relative motion as you are suggesting here?
  • #370
For supermassive BH, these issues are non-existent at horizon. There is no more tidal forces than at the Earth's surface.
  • #371
That is fine but is not relevant to his post which was regarding time dilation of clocks at differing altitudes . I.e not both near the surface.
I trust you are not suggesting that surrounding such a BH that an extended bar would not be subjected to stresses from the difference in g at the top and bottom?
  • #372
For a supermassive black hole, something as big as the Empire State building would have no more stresses at the horizon than it does on the Earth's surface (could be made arbitrarily small, actually). The horizon is not intrinsically related to any particular amount of local curvature, stresses, etc. Only the singularity is. For stellar black holes, extreme stresses and tidal forces occur long before the horizon - e.g. approaching a neutron star.
  • #373
But the e.p. suggest gravitational time dilation can equally be considered the same as acceleration in SR. And acceleration of two rigidly connected clocks in SR, observed in an inertial frame, differ in clock rate purely due to speed difference between the front and the back. Thus the EP says gravitational time dilation is equally subject alternate, coordinate dependent interpretations.
  • #374
Quote by Austin0
I would say in an attempt to make it appear to apply ;-)
Quote by Austin0
Quote by Austin0
While I tend to think that the term "by definition" means literally by explicit prior statement I certainly agree that your "coordinate time proceeds at a rate of one coordinate second per coordinate second," is a tautology. So essentially applies to all times. Time is uniform unless stated differently.
On the other hand, there is , in Pervect's stated conditions, absolutely no foundation or justification for an inference or assertion that Achilles' clock does not run at the same rate as Zeno's.
So your statements ---"Neither correspond to the proper time on the falling/Achilles' clock" and " For Zeno time, the proper time on Achilles' clock between Zeno t=1 and t=2 is indeed smaller than between Zeno t=0 and t=1" are both simply unwarranted assertions without validity. Simply entering the desired conclusion as an assumption
Explicitly as Zeno time goes to infinity so does Achilles'
Quote by Austin0
Yes their coordinate velocity is reducing but in the Zeno system a la Pervect there is no reason that Achilles proper velocity would not also decrease.
SO I will again state my opinion that the analogy doesn't really apply. Zeno time does not demonstrate a small finite time on Achilles clock. Do you still disagree??
  • #375
I was not suggesting any special significance to BH's or the vicinity of the horizon. I understood Mike_Holland's statements regarding g dilation as being general so took Steves post in the same context..
Are you suggesting that with a system accelerating under thrust we just disregard Born rigidity and acceleration if the system is smaller than the Empire State building?
Joke. ;-)
  • #376
Joke. ;-)
I'm just suggesting that to the extent we assume rigidity in practice for relativity large objects is achievable for modest tidal forces and accelerations, then rigidity to a similar extent may be assumed for an appropriately chosen event horizon (for free fall). [Edit: for a static observer near a horizon, proper acceleration approaches infinity, so rigidity is impossible for a static object. But for free fall, it is easy. Remember, it is the static observer that is analogous to the accelerating observer in SR.]
  • #377
I can calculate it explicitly if you like, but it is exceedingly well-founded.
See above. It isn't an assumption. It falls out of the math quite naturally.
No, Achilles' proper time is finite as Zeno coordinate time goes to infinity. I thought that it would be obvious, but apparently it isn't.
Achilles' proper velocity is clearly constant.
Yes, I disagree. I think that the math is so unfamiliar to you that you have a whole bunch of mistaken beliefs about how this works out. To me it is pretty obvious that none of the claims you made in your previous post are correct.
  • #378
Very nice in theory, but it doesn't work in practice if you believe that physics is universal. How is that free-fall observer, using Rain coordinates, going to explain that contracting mass that is accelerating towards him while he is motionless? Where are the rockets that are making it accelerate?
Gravity and acceleration may give the same answers, but if there is a heavy mass present, then gravity wins over acceleration.as an explanation - or at least as part of the explanation where both are involved.
  • #379
The principal of equivalence is local. It will show, for example, that within a moderately large capsule in free fall, physics is the same as in 'empty space'. Or that from top to bottom of building on a planetary surface, you have the same behavior as an accelerating rocket. If you go global, it doesn't apply in GR because there are neither extended uniform gravitational fields, nor global inertial frames.
However, the coordinate dependence of gravitational time dilation is shown by something like Lemaitre coordinates, which reproduce all measurements of any other coordinates, but display no gravitational time dilation (in the sense of dilation as a function of position). The key physical point is that measured time dilation is always done between two clocks; or between an emitter and receiver. It is thus a feature of two world lines and signals between them. The measurements are coordinate independent, and gravitational redshift or time dilation are not necessary to compute any such measurement.
Note also that the general way to define clock and redshift comparison between two world lines applies perfectly well to the vicinity of co-orbiting neutron stars. Meanwhile, there is no way to even define gravitational time dilation for such an inherently non-static field.
Gravitational time dilation is a useful concept for static spacetime - but it is not a general feature of GR, and it is never necessary to use. J. L. Synge, in his classic book on general relativity, argued against using it at all - because one universal method may be used in all cases (kinematic, cosmologic, and in strong, non-static geometry) instead.
  • #380
I was talking about scientific method, not about math.
You see the problem is that our observations are not expressed as invariants but as coordinate dependant physical quantities instead. So if you want to compare predictions with observations you would have to convert your invariants into coordinate dependant physical quantities.
As far as my understanding of GR goes this is out of scope of GR.
  • #381
The math is what the theory uses to make testable predictions for the scientific method. If you do not understand the math then you do not understand the theory well enough to address it with the scientific method. Hence the disagreements.
This is simply false. All experimental measurements are invariants. If they were not invariant then you could always construct a paradox of the form "Dr. Evil builds a bomb which is detonated iff device X measures Y, device X measures Y under coordinate system A, but Z under coordinate system B. Therefore the bomb explodes in one coordinate system but not in the other."
Two different coordinate systems may disagree on the meaning of the measurement, e.g. they may disagree whether or not the rod is accurately measuring length, but they must agree on what value is measured.
OK, so considering all other mainstream physics theories as well. What would prevent the formation of a horizon?
  • #382
Stellar black holes are formed in violent explosions - this is quite close to direct observation.
What you are telling is (mainstream) speculation. The closest thing to something like that as I can imagine is galactic collisions.
You can ask of course. But it does not mean you can get testable answer.
I for example can ask what people experience when they die. So what?
As I see speculations about BHs relies on one important thing that GR takes as a postulate. That is that laws of physics are independent of (Newtonian) gravitational potential. If we assume that this assumption holds without bonds then we have no reason to assume that anything will happen with a clock falling into the hypothetical BH.
But I don't buy the idea about assumptions holding without bonds. And that takes it out of domain of GR.
  • #383
No, galaxies are believed to contain supermassive central black holes, 10 billion or more sun's worth in some cases.
True, but this is not the the only case of physical theories including untestable predictions. To better understand a theory (and its limits), it is useful to understand what a theory predicts for such things. GR + known theories of matter (classically) predict continued collapse. GR must be modified in some way to avoid this.
Fine - you agree that GR must be modified to get the result you want. What you call laws being affected by something like Newtonian potential is a fundamental violation of the principle of equivalence, which is built in (as a local feature) to the math and conceptual foundations of GR. Note, for gravity to be locally equivalent to acceleration, a direct consequence is that free fall must have locally the same physics everywhere. (Otherwise, observing what happens inside a (small) free falling system would locally distinguish gravity from corresponding acceleration.)
  • #384
There's growing experimental evidence for the existence of event horizons. Basically, black hole candidates are very black, and don't appear to surface features.
WHen matter falls onto a neutron star, the surface heats up and re-radiates. The spectra signature is rather distinctive, also there are "type 1 x ray bursts".
Black hole candidates do not appear to have any such "surface" features, and it's already very difficult to explain by any means other than an event horizon how they can suck in matter without , apparently re-radiating anything detectable.
For the details, see
See for instance http://arxiv.org/pdf/0903.1105v1.pdf
and check for other papers by Naryan in particular.
  • #385
Quote by pervect
Quote by Austin0 View Post
Well this whole post of yours is nothing more than a repetitive bald assertion that you are right and I am wrong without content or justification so yes some hint as to the math you are referring to would be appropriate.
Where in the stated parameters :
is the mathematical basis for the derivation of time dilation . I.e. justification of its insertion into a classical scenario?
<h2>What is the "nature" of the infinite fall toward the EH?</h2><p>The "nature" of the infinite fall toward the EH refers to the behavior and characteristics of objects as they approach the Event Horizon (EH) of a black hole. This includes the effects of strong gravitational forces and the distortion of space and time.</p><h2>What is the Event Horizon (EH) of a black hole?</h2><p>The Event Horizon (EH) of a black hole is the point of no return, beyond which the gravitational pull is so strong that nothing, including light, can escape. It is the boundary that marks the point of infinite fall toward the black hole.</p><h2>How does the infinite fall toward the EH affect objects?</h2><p>The infinite fall toward the EH can have a variety of effects on objects, depending on their size, mass, and distance from the black hole. These effects can include extreme stretching and compression, tidal forces, and time dilation.</p><h2>Can anything escape the infinite fall toward the EH?</h2><p>Once an object has crossed the EH, it is impossible for it to escape the infinite fall toward the black hole. However, objects that are far enough away from the black hole may be able to resist the pull of gravity and avoid falling into the EH.</p><h2>What happens at the singularity of a black hole?</h2><p>The singularity of a black hole is a point of infinite density and zero volume. It is the center of the black hole where all matter and energy is thought to be concentrated. The laws of physics as we know them break down at the singularity, making it impossible to predict what happens there.</p>
