What exactly is the reactive centrifugal force (split)
In summary: I think that this is the root of my misunderstanding.In summary, the conversation is discussing the use of the term "centrifugal force" in relation to the reactive centrifugal force and the inertial centrifugal force. One person argues that the term is confusing and should not be used, while the other argues that it depends on the reference frame and the direction of the force. They also discuss Newton's third law and its application in determining the reaction force in a system. Ultimately, they agree that the third law is not about tensions, but about equal and opposite forces and changes in momentum.
  • #36
DaleSpam said:
Andrew Mason, please provide a mainstream scientific reference for Newton's 3rd law being as you describe, equal and opposite net forces or equal and opposite changes in momentum.
Do you consider Newton to be mainstream?
Newton's explanation of the third law uses both the concept of a force and of change in motion. He begins by talking of a body pressing on another, the latter pressing back on the first (a finger pressing a stone and the stone pressing back on the finger), and then says:
If a body impinges upon another, and by its force changes the motion of the other, that body also (because of the equality of the mutual pressure) will undergo an equal change, in its own motion, toward the contrary part. The changes made by these actions are equal, not in the velocities but in the motions of the bodies; that is to say, if the bodies are not hindered by any other impediments. For, as the motions are equally changed, the changes of the velocities made toward contrary parts are reciprocally proportional to the bodies.​
It is interesting that Newton speaks of "bodies ... not hindered by any other impediments". One can argue whether he was equating action with "force on an otherwise unimpeded body", but that is not an unreasonable interpretation.
With respect to the astronaut space-station example, the third law says that a body undergoing centripetal change in motion due to contact with another unimpeded body causes that other body to have an equal change of motion in the opposite direction. So if we are talking about the astronaut undergoing a centripetal change in motion due to contact with the space station/other astronaut (taken as one body), the third law "reaction" is a change in motion of the space station/other astronaut in the opposite direction. That change in motion always points to the centre of rotation.
AM
  • #37
stevendaryl said:
Hmm. Let's see if that's true. Suppose you have three objects 1, 2, 3. There are correspondingly 6 forces:
  1. [itex]\stackrel{\rightarrow}{F_{12}}[/itex] = force of 1 on 2
  2. [itex]\stackrel{\rightarrow}{F_{21}}[/itex] = force of 2 on 1
  3. [itex]\stackrel{\rightarrow}{F_{13}}[/itex] = force of 1 on 3
  4. [itex]\stackrel{\rightarrow}{F_{31}}[/itex] = force of 3 on 1
  5. [itex]\stackrel{\rightarrow}{F_{23}}[/itex] = force of 2 on 3
  6. [itex]\stackrel{\rightarrow}{F_{32}}[/itex] = force of 3 on 2
The fact that the situation is static means that the force on any object is zero. So we have:
  1. [itex]\stackrel{\rightarrow}{F_{12}} + \stackrel{\rightarrow}{F_{32}} = 0[/itex]
  2. [itex]\stackrel{\rightarrow}{F_{13}} + \stackrel{\rightarrow}{F_{23}} = 0[/itex]
  3. [itex]\stackrel{\rightarrow}{F_{21}} + \stackrel{\rightarrow}{F_{31}} = 0[/itex]
That's three constraints. I don't see how you can derive that
[itex]\stackrel{\rightarrow}{F_{12}} + \stackrel{\rightarrow}{F_{21}} = 0[/itex]
If it is static, all the forces on each object must sum to 0. So:
[itex]\vec{F}_{12} + \vec{F}_{32} + \vec{F}_{13} + \vec{F}_{23} + \vec{F}_{21} + \vec{F}_{31} = 0[/itex]
You get that from the first law.
If [itex]\vec{F}_{12} + \vec{F}_{32} = 0[/itex] and if 2 is not accelerating then either [itex]\vec{F}_{12} = \vec{F}_{32} = 0[/itex] or there are other forces acting on 2.
In that case you would have to write:
[itex]\vec{F}_{12} + \vec{F}_{32} + \vec{F}_{13} + \vec{F}_{23} + \vec{F}_{21} + \vec{F}_{31} + \sum F_{i(ext)} = 0[/itex], which is again just the first law.
Take a simpler case of a magnet (body 1) and an iron bar (body 2) stuck to it by the magnet's magnetic force. The total force of the magnet on the bar is 0 and the total force of the bar on the magnet is 0. If it were otherwise, there would be acceleration.
AM
  • #38
A.T. said:
It is the interpretation of Newton's third that you will find in every modern physics book. It doesn't matter how you call this Law ("3rd law" or "generalized 3rd law"). All your hand waving cannot change the fact that:
- It is a law of physics.
- It states two equal but opposite forces.
- It applies to static cases too.
- It means that my astronauts exert a centrifugal reaction force on the station
We agree that there is a force exerted on the space station by the astronaut that is a reaction to the force of the space station causing the astronaut to experience centripetal acceleration. All I am saying is that that reaction force causes the space station centre of mass to undergo centripetal acceleration toward the centre of rotation. So the reaction to the centripetal change of motion of the astronaut is a centripetal change of motion of the thing that is acting on the astronaut. And that is what the third law says must occur.
AM
  • #39
stevendaryl said:
I agree with you that thinking of equal and opposite forces works better than thinking of equal and opposite changes of motion, but in the case you are talking about, the change in momentum of one of the masses is equal and opposite to the vectorial sum of the changes of momentum of the other two masses. That might be what AM meant.
Exactly. See my post #135 above.
AM
  • #40
DaleSpam said:
Yes, this is correct. Note that the gravitational force (mg) is not equal to the change in momentum (ma=0). So your correct statement here contradicts your own incorrect statement elsewhere.
The reason there is no change in momentum is because the body and the Earth are each exerting a total force of 0 on each other. If it were otherwise, there would be an acceleration.
Consider three identical masses, each connected by identical springs of neglible mass to both of the others and starting at rest from a position where the springs are all equally stretched. Each object is experiencing a change in motion and there is no other body experiencing an equal and opposite change in motion.
True, but there is a change in motion of the other two that combines to be equal and opposite to the change in motion of the first. The third law says that you cannot have just one body changing its motion. See my post #135 above.
AM
  • #41
That phrase seems to contradict your position and support the mainstream interpretation. I do not think that this reference supports your interpretation.
Also, this may be a translation error. Other translations are pretty clear on the standard interpretation. "Whatever draws or presses another is as much drawn or pressed by that other. If you press a stone with your finger, the finger is also pressed by the stone. "
http://www.marxists.org/reference/subject/philosophy/works/en/Newton.htm
Do you have any mainstream scientific reference that clearly supports your unorthodox stance? To ensure clarity, it would be best if it expressed the law mathematically. I.e. the usual version is something like [itex]F_{12}=-F_{21}[/itex] but your version would be something like [itex]dp_1/dt = - dp_2/dt[/itex]. Can you find a reference that actually expresses the third law that way?
Here are some clear references for the usual way:
http://en.wikipedia.org/wiki/Newton's_laws_of_motion#Newton.27s_third_law
http://www.phy6.org/stargaze/SNewton3.htm
http://www.ck12.org/concept/Newtons-Third-Law/?ref=/concept/Newtons-Third-Law/
  • #42
Agreed. Since the total force is zero then, according to your interpretation, there is no third law pair for either the normal force or the gravitational force.
But that isn't what the third law says, even in your interpretation as expressed above. The Newton quote certainly doesn't lend support to this weird three-body version of the third law. You are just making things up as you go along, and contradicting yourself and your sources.
  • #43
And you are wrong as usual. The space station centre of mass has no acceleration toward the centre of rotation. The space station centre of mass is static at the centre of rotation.
Needless to say that even if you were right, it would be still irrelevant. It would not change the fact that the contact force Frcf acts centrifugally on the wall.
  • #44
Your interpretation of Newton is not mainstream.
But even if you were right about what he initially meant centuries ago in his Latin prose, it would still be irrelevant. Laws of physics are often generalized over the course of time. Today we have a 3rd law that applies to forces regardless of accelerations.
  • #45
Expressed that way, it would be a rather useless law, that applies only in a special case where no other forces are acting (or cancel exactly). It would not be a law, but rather a case specific rule. A law in physics is usually a generally applicable rule.
I'm sure many school books use the simplest possible example (two bodies, one interaction) to introduce the 3rd Law. But if Andrew goes a few pages further, he should find examples where there are more forces acting.
  • #46
Are you including both astronauts in the space station? The space station I refer to includes only the other astronaut. Read my #136 post:
"With respect to the astronaut space-station example, the third law says that a body undergoing centripetal change in motion due to contact with another unimpeded body causes that other body to have an equal change of motion in the opposite direction. So if we are talking about the astronaut undergoing a centripetal change in motion due to contact with the space station/other astronaut (taken as one body), the third law "reaction" is a change in motion of the space station/other astronaut in the opposite direction. That change in motion always points to the centre of rotation."​
Here is a simple question: If the reaction force to the centripetal acceleration of astronaut 1 is a centrifugal static force (ie it does not result in any contrary change in motion of the thing that is accelerating astronaut 1) what is the force that causes the centripetal acceleration of the centre of mass of the space station/other astronaut?
We agree on the force and we agree on the direction. And all I am saying is that since this force causes the rest of the mass to which the astronaut is connected to undergo acceleration toward the centre of rotation, it is a true centripetal force. Calling it centrifugal is a misnomer.
AM
  • #47
It is not a weird three-body version of the third law. Body A exerts forces on both Body B and Body C. Body C and Body B exert equal and opposite forces on Body A. But in order to analyse the interaction using forces you need to know the instantaneous direction and duration of these forces and whether the bodies are rigid or deform during the interaction etc. It is not easy to analyse using forces.
The third law says that the action (which we can take to be A's action on B and C) is accompanied by an equal and opposite reaction (the action of B and C on A). So we can say that the change in motion of A is accompanied by equal and opposite changes in motion of B and C. This is true at all times before during and after the interaction.
AM
  • #48
I don't get that, at all. From [itex]\vec{F}_{12} + \vec{F}_{32} = 0[/itex], you get [itex]\vec{F}_{12} = - \vec{F}_{32}[/itex], not that
The fact that 2 is not accelerating is what tells us that [itex]\vec{F}_{12} + \vec{F}_{32} = 0[/itex].
  • #49
Nice try. Why not include both astronauts in the space station, so we have just one object, no interactions and finally no reactive centrifugal force.
Sorry, you don't get to decide how people divide the system into parts. In my example there are 3 objects: station & 2 astronauts. This is a perfectly valid way to analyze the scenario. So deal with it, and don't try to change it.
Andrew Mason said:
...acceleration...
Irrelevant. The force is there, regardless of acceleration. In the rotating frame there is no acceleration at all, but there still is a force on the wall pointing outwards: centrifugal.
  • #50
But with the "force" interpretation of the third law, it is easy to analyze the interaction, at least in the special case (which is most relevant in most applications of Newton's laws) in which all forces are either (1) instantaneous two-body interactions, or (2) contact forces.
As I said, in a three-body problem, there are 6 two-body interaction forces:
[itex]\vec{F_{12}}, \vec{F_{21}}, \vec{F_{13}}, \vec{F_{31}}, \vec{F_{23}}, \vec{F_{32}}[/itex]
where [itex]\vec{F_{IJ}}[/itex] means the force of object [itex]I[/itex] on object [itex]J[/itex]. If it's a static situation, the sum of the forces on each object is zero. So we conclude:
[itex]\vec{F_{12}} = -\vec{F_{32}}[/itex]
[itex]\vec{F_{13}} = -\vec{F_{23}}[/itex]
[itex]\vec{F_{21}} = -\vec{F_{31}}[/itex]
Then Newton's third law (interpreted in terms of equal and opposite forces) implies
[itex]\vec{F_{12}} = -\vec{F_{21}}[/itex]
[itex]\vec{F_{13}} = -\vec{F_{31}}[/itex]
[itex]\vec{F_{23}} = -\vec{F_{32}}[/itex]
These 6 equations have the solution
[itex]\vec{F_{12}} = \vec{F_{21}} = \vec{F_{13}} = \vec{F_{31}}= \vec{F_{23}} = \vec{F_{32}} = 0[/itex]
But I don't see how you can get that conclusion without invoking the force version of the 3rd law.
  • #51
I am not changing anything. Are you saying that the presence of the other astronaut does not affect the force that the space station applies to the first? Since it does, then you have to include it as part of the "other body" that is interacting with the first astronaut.
Every atom in that space station/2 astronaut example is accelerating. There are a gazillion tension forces. The total force on each atom is the atom's mass multiplied by its centripetal acceleration.
There is an apparent force in the rotating frame. The real forces are causing accelerations toward the centre.
AM
  • #52
It is clear that you know that the usual formulation of the 3rd law is correct. Whether or not it is easy is irrelevant. There are lots of laws of physics that are not easy.
This isn't going to work. Not only are you trying to peddle the idea that in "to every action there is an equal and opposite reaction" the word "action" refers to changes in momentum; you are now trying to say that the third law is "to every action there is an equal and opposite sum of reactions". Good luck finding some authoritative support for that. It certanily isn't what Newton said above, and I have never seen it expressed that way.
Please find a clear reference. Now the mathematical expression you are looking for is [itex]dp_i/dt=\Sigma dp_{j \ne i}/dt[/itex]. You need to find somewhere that states not just that this expression is true, but that this is Newton's 3rd law.
  • #53
Yes you are. The definition of the objects is part of the example, to demonstrate reactive centrifugal forces. You don’t get to change my example, just because it proves you wrong.
And a real centrifugal force on the wall Frcf. It exists in every frame.
There is no acceleration in the rotating frame. It is all static. But there still is a real centrifugal force on the wall, exerted by the astronaut. Accelerations are irrelevant to this.
  • #54
Ok. It is a centrifugal force that has as its only physical effect the acceleration of the centre of mass of the rest of the system toward the centre of rotation. Is that how you want to explain this to students?
It is rotating. Everything is accelerating. We use the inertial frame to analyse forces. The absence of apparent acceleration in the non-inertial frame is not real. Why are you even referring to this? This makes it very difficult for the student to distinguish between the apparent centrifugal force and the real reaction force (which you say is a static centrifugal force and I say is a non-static centripetal force).
AM
  • #55
Wrong and irrelevant. It can have other physical effects, like creating a dent in the wall. But the physical effects of the force are irrelevant to the fact that it acts centrifugally.
Andrew Mason said:
Static?! You can't be serious.
Yes, static. Nothing moves in the rotating frame of my scenario.
Andrew Mason said:
It is rotating.
Not in the rotating frame.
  • #56
Andrew Mason said:
Take the simplest example of the three masses in a straight line: 1, 2, 3. None are accelerating. So:
(1)[itex]\vec{F}_{12} + \vec{F}_{32} = 0[/itex] and
(2)[itex]\vec{F}_{21} = 0[/itex] and
(3)[itex]\vec{F}_{23} = 0[/itex].
But [itex]\vec{F}_{23} = -\vec{F}_{32}[/itex] and [itex]\vec{F}_{21} = -\vec{F}_{12}[/itex]
So that means:
The same thing applies if they are arranged in a triangle or any other shape.
AM
No, it doesn't. Dale gave a counterexample. Here's a different one: You have three particles 1, 2, and 3. For simplicity, let them be in a straight line, so we only need consider the x-component of the forces. Let
[itex]F_{12} = 0[/itex]
[itex]F_{32} = 0[/itex]
[itex]F_{13} = 1[/itex]
[itex]F_{23} = -1[/itex]
[itex]F_{31} = 2[/itex]
[itex]F_{21} = -2[/itex]
That satisfies Newton's first law, but not the third.
  • #57
A dent in the wall would require a momentary reduction in the centripetal force being applied by the space station to the astronaut (at the given rotational speed) and a corresponding reduction in the astronaut's reaction force. If you say this reaction force is a centrifugal force it is very strange that it only causes an outward effect when it is reduced.
You were posting as I was editing. I added:
It is rotating. Everything is accelerating. We use the inertial frame to analyse forces. The absence of apparent acceleration in the non-inertial frame is not real. Why are you even referring to this? This makes it very difficult for the student to distinguish between the apparent centrifugal force and the real reaction force (which you say is a static centrifugal force and I say is a non-static centripetal force).​
We don't analyse real forces in the rotating frame.
AM
  • #58
There is no need for a reduction in the centripetal force in order to cause a dent. You are again taking one specific scenario and making a mistaken generalization.
Yes, we do. We also analyze fictitious forces there, but real forces are not ignored.
I note that you have not found a reference that writes a clear mathematical expression corresponding to your version and calls that the third law. All you have is an ambiguous translation that cannot be said to clearly contradict your approach.
  • #59
What is strange about this?
When you sand on a table, you exert a downwards force on the table. When that downwards force starts deforming the table downwards, there eventually will be a momentary reduction in that downwards force. Do you find it strange to call it a downwards force, because it creates a downwards effect when it is reduced?
Who is "we"? I show the forces in both frames in the diagram.
  • #60
I suppose someone could soften the floor so the astronaut made a dent. Is that what you mean? The process of making the dent still involves an increase of the distance from the centre of rotation, which reduces the centripetal force and the reaction to that force.
I gave you Newton's explanation of the third law. You don't accept that? The translations from the latin are correct. Any ambiguity is Newton's not the translator's.
Acceleration is the second time derivative of the body's displacement vector relative to an inertial point. If you use as your reference a non-inertial point whose acceleration is constantly changing, how would you measure real acceleration?
AM
  • #61
Suppose the top 10 cm of the floor of the space station was softened so that the astronaut's feet and centre of mass move 10 cm farther from the centre and cause a 10 cm dent in the floor. Is this dent caused by the reaction force to centripetal acceleration or is it the inertial effect of the reduction in centripetal force due to the softening of the floor? There is a big difference: one is a real force and the other is not. If one calls both forces (the real reaction force of the astronaut on the space station and the fictitious centrifugal force observed only in the rotating frame) centrifugal it gets very confusing. Even Newton was confused by centrifugal force.
AM
  • #62
There is no ambiguity in physics books today. The law deals with forces and accelerations are irrelevant.
  • #63
Andrew Mason said:
Is this dent caused by the reaction force to centripetal [STRIKE]acceleration[/STRIKE] force
Yes. But don't confuse forces and accelerations.
  • #64
Why is it not caused simply by the astronaut's inertia due to the inability of the floor to provide the needed centripetal acceleration? Why is it so fundamentally different if that 10 cm of the floor just momentarily dissolved?
By the way, I put it that way because you insist that one can have a force that produces no acceleration as a third law reaction to one that does produce acceleration. There is nothing wrong or confused in saying the force is related to an acceleration.
AM
  • #65
No, the centripetal force is [itex]mr\omega^2[/itex], it increases as the distance from the center increases.
Then Newton was ambiguous. I read it and to me it seems to be talking about forces. You read it and to you to you it seems to be talking about changes in momentum. It does not clearly support your position (nor does it clearly support mine).
EDIT: Actually, after having read the entire quote in context it seems quite clear that Newton is not supporting your view. The part of the quote you cited is not the law, but the last of three examples. First he gives the "action-reaction" formulation of the law. Then he clearly talks about forces, not accelerations, in an example of a finger pressing a stone and second example of a horse drawing a stone. Then he introduces a third example, this one clearly indicating the special case of two bodies with no other forces acting so that the force is equal to the change in momentum (by his second law). In that case your formulation is equivalent to the usual formulation, but in all of the other examples he clearly intended the usual formulation, not yours.​
That is why I prefer sources that use math which is clear and unambiguous. All of those that I have seen clearly contradict your position. Can you provide any unambiguous (with math) support for your position? I provided unambiguous (with math) support for mine, so I don't think it is unreasonable to require the same from you.
What is "real acceleration"? I would measure "coordinate acceleration" as the second time derivative of my coordinate location. I would measure "proper acceleration" with an accelerometer. I don't know what "real acceleration" is.
  • #66
It is caused by the centrifugal reaction force. It is certainly not caused by anything related to "the reduction in centripetal force" since the centripetal force does not reduce but instead increases.
  • #67
? The reaction force completely disappears if the centripetal force disappears, which is what happens when the floor completely dissolves. So how can the reaction force cause the outward motion?
I know it seems counter-intuitive, but with no external torque the centripetal force decreases as r increases. We see this from the fact that gravity, which supplies the centripetal force for orbiting bodies, varies as 1/r^2.
AM
  • #68
Yes, but ω decreases as 1/r (L = constant) so the centripetal force decreases as 1/r: [itex]F_c =mr\omega^2 = L^2/mr[/itex]
It is an interesting question, I'll grant you that.
I found this commentary which wrestles with this very issue.
I know what you are saying but the real problem I have is that Newton talks about force in his first two laws but talks about action and reaction in his third and does not mention force. The first two laws are quite straight forward and unambiguous. But the third is not, due to his use of undefined terms. That said, we should not be too critical of any confusion Newton may have had or caused by his statement of this law. Newton's laws are a truly remarkable achievement when one considers the state of physical science at the time.
I don't think it is a matter of contradicting "my position" because I am just saying that Newton's third law is a statement about conservation of motion (momentum) and I don't think conservation of momentum can be contradicted.
"Real acceleration" is a non-zero second derivative with respect to time of a body's displacement from a fixed point in an inertial reference frame. It does not matter what inertial reference frame you select. It is the same in all (in Galilean relativity).
AM
  • #69
Why is it not caused by the Big Bang due to the fact that without the Big Bang there would be no astronaut and space station in the first place? You can always construct endless cause-effect chains. But usually we consider forces acting on the object as the direct cause of the objects deformation. Therefore only a force acting on the wall can be a direct cause of the wall's deformation.
But keep in mind that the whole causation reasoning about forces is often more fuzzy intuitive mythology, than physics. It doesn't affect the quantitative results. The action doesn't cause the reaction in the 3rd law. They both happen simultaneously, and physics just says they are equal but opposite. The same is true for net force and acceleration in the 2nd law. Although we often say that the net force causes the acceleration, they both happen simultaneously, and physics just says they are proportional.
  • #70
By insisting on your interpretation of Newtons 3rd you are contradicting modern mainstream physics. That is because the mainstream interpretation is more general than your interpretation. So you are basically saying that Newtons 3rd doesn't apply to all those cases, where mainstream physics says it does apply. See also my remarks in post #145.
<h2>1. What is the reactive centrifugal force (split)?</h2><p>The reactive centrifugal force (split) is a fictitious force that appears to act on an object moving in a circular path. It is a result of the object's inertia and its tendency to resist changes in its motion.</p><h2>2. How is the reactive centrifugal force (split) different from the centrifugal force?</h2><p>The centrifugal force is a real force that acts on an object moving in a circular path, pushing the object away from the center of rotation. The reactive centrifugal force (split) is a fictitious force that appears to act on the object in the opposite direction, towards the center of rotation.</p><h2>3. What causes the reactive centrifugal force (split) to appear?</h2><p>The reactive centrifugal force (split) is a result of the object's inertia and its tendency to resist changes in its motion. As the object moves in a circular path, its inertia causes it to continue moving in a straight line, resulting in the appearance of the reactive centrifugal force (split).</p><h2>4. Is the reactive centrifugal force (split) a real force?</h2><p>No, the reactive centrifugal force (split) is a fictitious force and does not have a physical origin. It is simply a mathematical construct used to explain the motion of objects in circular paths.</p><h2>5. How is the reactive centrifugal force (split) related to Newton's laws of motion?</h2><p>The reactive centrifugal force (split) is a result of the first law of motion, also known as the law of inertia. It explains how objects tend to resist changes in their motion and how this resistance results in the appearance of fictitious forces, such as the reactive centrifugal force (split).</p>
  • Mechanics
