Which is the correct answer for 48÷2(9+3): 2 or 288?
  • Thread starter RJS
In summary, there is confusion about whether the answer to the equation 48÷2*(9+3) is 2 or 288. Some argue that 288 is the correct answer, following the order of operations (PEMDAS), while others say 2 is the correct answer because they believe multiplication should be performed before division. However, according to the order of operations, multiplication and division are at the same level of precedence and should be evaluated from left to right. Therefore, the correct answer is 288. The confusion may stem from the use of the ÷ symbol, which can be interpreted differently.
What is the answer?
  • 2
    Votes: 25 50.0%
  • 288
    Votes: 25 50.0%
  • Total voters
    50
  • #106
oraclelive said:
I think by using or applying the rule of BODMAS this could be better understood and solved well whelther with a calculator or not. That is; 48/(9+3)*2 = 48/(12*2) = 2.
You are misinterpreting the rule. Division does not have precedence over multiplication.
This question was answered on the first page. The correct answer to 48÷2(9+3) is 288. An even better answer is that this is a stupid question. When writing a mathematical expression, the number #1 rule is to leave absolutely no doubt about how the expression is to be interpreted.
Some calculators do indeed perform this incorrectly, particularly graphing calculators from the previous millennium. TI led the charge in this regard. Their TI-80, 81, 82, and 85 calculators gave implied multiplication a higher precedence than explicit multiplication. TI reversed this decision in the late 1990s. Their TI-83, 84, 89, 92, and later calculators give the same precedence to implied and explicit multiplication.
Mathematics news on Phys.org
  • #107
[URL]http://shareimage.ro/images/n10moj7k3larya94uc4o.jpg[/URL]
http://www.zazzle.com/48_2_9_3_tshirt-235882834792365529
  • #108
the answer is two
  • #109
1 - 2 + 3 = ?
a) -4
b) +2
  • #110
Xitami said:
1 - 2 + 3 = ?
a) -4
b) +2
The only way to get that to -4 is to ignore the rules.
Addition and subtraction are equal weight and evaluated left to right.
Only if it was written as 1 - (2 + 3) would it equal -4.
  • #111
48 ÷ 2(9 + 3) Can be also written: 48 x ½(9 + 3)
48 x ½(9 + 3)
^Will not have any problems finding the right answer, 288.
  • #112
It can be written that way if you assume a particular meaning- but the expression as given is ambiguous and cannot be correctly evaluated without assuming something not given.
You, basically, assumed the "correct" answer was 288 and, no surprise, arrived at that answer.
  • #113
I think we should create a new option on the poll: "Ban the notation ÷" That would have my vote...
  • #114
48 x ½(9 + 3)
that doesn't help at all, since half of the people here are arguing that 48 ÷ 2(9+3) should be interpreted as [tex]48 \times\frac{1}{2(9+3)}[/tex].
I think the best answer to this question was actually given by my professor. Some students asked this yesterday after class and he immediately answered that it was ambiguous. Which by looking at this discussion, I think is fair to say it is the case. Funny how it made it all over the interwebs though.
BTW, how were some of you able to plug this in Python or C++ ? I tried in both but failed because they both interpreted the "2(9.0+3)" as an attempt to call a function named 2. Also, my Sharp EL-W516 gives 2 for an answer.
EDIT: Maple gives 288, and MATLAB refuses to do anything with the ÷ symbol. Or with 2(9+3) without an operator after 2, for that matter.
  • #115
I like how 2 is currently winning. :rofl:
  • #116
Matlab is not saying 288 its giving an error.
personally if you got this question in a 7th grade math test and wrote 2 you would get the answer wrong.
so its clearly 288.
  • #117
Grar, stop arguing over which end to crack your eggs. :tongue:
The standard is that multiplication/division have same precedence, and are done left to right. Similarly for addition and subtraction.
However, some people drop parentheses around the divisor as short-hand, and others simply get it wrong.
The practical effect is that you should never write an expression like [itex]1/2x[/itex] unless you are sure it won't generate any confusion -- e.g. if you can be certain your audience will infer from context whether you mean [itex](1/2)x[/itex] or [itex]1/(2x)[/itex].
Sometimes, you will face an author/teacher who uses the standard convention. If you prefer a different convention, then you're going to have to learn to read the wrong convention, and avoid writing anything that would be different amongst the two conventions.
The same advice applies to someone who prefers the standard convention, but is faced with a book/teacher that uses a different one.
There's a general style guideline here -- if there is a reasonable chance of ambiguity, use parentheses. :tongue:
For the record, on more than one occasion, I've seen a student who doesn't put parenthesis around divisors make arithmetic mistakes because he wrote an expression intending some operation to happen in the divisor, but later read the expression differently (and others make mistakes in the other direction). So I pretty much always insist on parentheses, no matter what convention the student wants to use.
27K
  • General Math
