- #281
PeterDonis
Mentor
- 45,641
- 22,663
zonde said:The problem here is that coordinates does not give clear picture about this geometry of simultaneity.
Schwarzschild coordinates don't, that's true; that's because their lines of simultaneity (the lines of constant Schwarzschild time t) all intersect at the horizon. But that is not true of other coordinate charts.
zonde said:But I want to check that this geometry of simultaneity is consistent between two coordinate charts (Schwarzschild and Painleve). I have gut feeling that these two geometries are incompatible (they correspond to two physically different situations). And I either want to get rid of that doubt or confirm it.
It depends on what you mean by "physically different situations". Both sets of lines of simultaneity are in the same spacetime--the same global geometry--but they are two *different* sets of lines. The Schwarzschild lines of simultaneity only cover the exterior region of the global geometry. The Painleve lines of simultaneity cover both the exterior region and the interior region, and the horizon.
zonde said:From that reasoning it seems that simultaneities corresponding to of black hole and white hole can not be jointly realized in single coordinate system (when we include region behind EH) and therefore they are mutually exclusive. But the only difference between black hole and white hole is this geometry of simultaneity.
The black hole and the white hole *can* both be "realized" in the same coordinate system: the maximally extended Kruskal coordinates. In those coordinates, the lines of simultaneity in the white hole region and those in the black hole region are "parallel"--they belong to the same global set of lines of simultaneity--but they are different subsets of the global set of lines of simultaneity, that don't overlap.
However, in an actual spacetime where a black hole is formed by the collapse of a massive body, the white hole region is not present; only the exterior, the "future interior" (the black hole region), and the non-vacuum region occupied by the collapsing massive object are present. As far as I know, the full spacetime geometry described by the maximally extended Kruskal chart, which includes the white hole region (and also a second "exterior" region), is theoretical only, and no one claims that any actual physical spacetime contains all the regions that are present in that theoretical spacetime.
zonde said:Of course when we compare Schwarzschild and Painleve coordinate charts we should leave out black hole interior.
Yes, because the Schwarzschild chart (the exterior one) doesn't cover the black hole interior (or the horizon). But even in the exterior region the lines of simultaneity in the two charts are different sets of lines, "pointing" in different "directions".
zonde said:Physical interactions is the thing that is important in physics. Round trip for light to EH is infinite and in Schwarzschild chart forward trip is equal to backward trip. So there can be no physical interactions between interior and exterior of Schwarzschild black hole.
Physical interactions don't require a "round trip" causal influence, just one-way is enough. Causal influences can still propagate into the interior from the exterior.
zonde said:Sorry but your arguments about *geometry* are just hand waving.
If you really can't grasp the geometric way of describing the physics, there are other ways. They take a lot longer to talk about, which is why most physicists prefer the geometric description, at least for GR. But if you're getting hung up on the word "geometry", you're missing the point.
