Just recently I discovered the world of the superfluids and I am
  • Thread starter Hut
In summary, the conversation discusses the behavior of Helium II in a container and how it relates to the law of conservation of energy. It is explained that the liquid climbs in the container due to capillary attraction and gains potential energy. The conversation also touches on the phenomenon of second sound, which is a density fluctuation in the gas of phonons. The conversation also discusses the concept of the Rollin film, which covers the walls and interior of the container and can cause helium to escape if not properly managed.
Hut
Just recently I discovered the world of the superfluids and I am astonished by the characteristics of Helium II. Even after researching for hours there a still a few questions which I wasn’t able to answer myself.
Rollin Film:
If a container is filled with helium II are the walls and the ceiling of this container going to be covered without any further impact from the outside after a few hours have passed by? How does this phenomenon go along with the law of the conservation of energy? The liquid climbs in the container so it gains potential energy.
For the fountain effect to happen you have to heat up the superfluid in order for it to change back to the helium I state.
How can you heat up a superfluid if is capable of transporting heat like waves to other places (“2nd sound”) ?
Thanks in advance.
Regards
Capillary attraction between the film and the container wall reduces the energy.
Second sound, also called temperature waves or entropy waves, is a density fluctuation in the gas of phonons. Its propagation requires a sufficient amount of energy-conserving phonon-phonon interactions. You can generate a wave of second sound with a temperature pulse. Heating by comparison is like a d.c. signal.
Thanks for your quick answer.
But that would also mean that the capillary attraction gets stronger the higher the container is. I am having a hard time picturing that.
Since I couldn't find enough reading material regarding the rollin film I don't know how to to imagine at.
If the Helium II sits at the bottom of a container will it creep up walls until everything is fully covered by a 30nm thick layer?
No, he helium can only "escape" if there is already a film covering the wall AND the film is continuous on the outside wall all the way down to a point BELOW the starting point.
If you do this experimentally (I used to to this experiment when I was a TA) you normally use a small "bucket" which is first dunken in the superfluid, this ensures that there is a film covering the whole bucket, when you lift the bucket out of the liquid any helium that is still inside the bucket will start to creep out and form droplets at the bottom of the bucket, which then falls back into the main bath.
Thanks for your answer f95toli.
Te captation of Fig.4 on the wikipdia page states following (http://en.wikipedia.org/wiki/Superfluid_helium-4)
Fig. 4. Helium II will "creep" along surfaces in order to find its own level – after a short while, the levels in the two containers will equalize. The Rollin film also covers the interior of the larger container; if it were not sealed, the helium II would creep out and escape.
Since you said that:
Does ist mean that the extract from the wikipadia page is simply wrong or is it just misleading? I am wondering because then there would be no reason for "the Rollin film to cover the interior of the larger container".
No, what I wrote agrees with the wiki. In the illistration the level inside the bucket is lower than the outside so helium will flow INTO the bucket, I described a different situation with a bucket ABOVE the main bath which means that the liquid will LEAVE the bucket.
Also, the situation described in the wiki does require there to be a He film to start with, which tends to be the case in just about every practical situation you can think of. If you separate the film into two nothing can flow.
The Rollin film can be a problem when designing cryostats (although it is rarely a problem in modern designs), and then heaters or knifeedges are used to "cut" the film into two at the top of the bucket in order to prevent the He from escaping.
1. What are superfluids?
Superfluids are a state of matter in which a fluid has zero viscosity and flows without any resistance or loss of kinetic energy. They also exhibit unique properties such as the ability to climb walls and flow through tiny spaces without any turbulence.
2. How are superfluids different from regular fluids?
Superfluids differ from regular fluids in two major ways: zero viscosity and the ability to flow without any resistance. This is due to the formation of a Bose-Einstein condensate, which is a state of matter where particles are in the same quantum state and behave as one entity.
3. How are superfluids created?
Superfluids are typically created by cooling certain fluids, such as helium-4, to extremely low temperatures, close to absolute zero. This causes the particles to slow down and form a Bose-Einstein condensate, resulting in the unique properties of superfluids.
4. What are the practical applications of superfluids?
Superfluids have many potential applications, including in cryogenics, as coolant in superconductors, and in medical imaging. They are also being studied for potential use in quantum computing and as a model for understanding other complex systems.
5. What are some current areas of research in superfluids?
Some current areas of research in superfluids include studying their behavior at different temperatures and pressures, as well as their interactions with other materials. Researchers are also investigating ways to control and manipulate superfluids for potential practical applications.
  • Other Physics Topics
13K
  • Beyond the Standard Models
  • Materials and Chemical Engineering
  • General Engineering
