- #281
- 10,302
- 1,472
I'd say we've responded at length. It's just that the explanations have to all appearnces not been understood. Is it worth another try? I don't know for sure, but I'll give it One More Go.Austin0 said:So everyone agrees on infinite coordinate time on a static clock at infinity for BH formation or infalling approach to EH but you all keep reiterating that this coordinate time has no physical meaning and that any of us who think there are questions here are attributing incorrect meaning to this evaluation.
That the proper time of the falling clock is a finite value.
But are you not attributing equal physical meaning to the subjective time of the infaller??
Time dilation is inherently a relative evaluation. What difference does it make what the elapsed time on the falling clock is.
The reading on a clock is a physical measurement. It's something you can observe directly. It's about as simple as you get. It's a good thing to take as a primitive axiomatic element, one that you can't make simpler.
One probably does idealize things a tiny bit to assume there is such a thing as a "perfect clock". Or if not "perfect", at least one "good enough" so that you can take any given measurement you desire to whatever accuracy you desire. Possibly there are hidden deep waters here (especially if you start to drag QM into the picture rather than try to view the whole affair classically) but it's really not a terribly demanding assumption.
An "observer" is a much more complicated mental construct. You not only have one physical clock (which you still assume keeps perfect time, or at least good enough time, as above), but you start imagining a whole network of virtual clocks. These clocks don't actually exist, but you imagine them as if they do. It's much more demanding assumption than assuming basically that "clocks exist, and you can use them to measure time".
You also typically assume that all the clocks are "not moving" with respect to one another. So now you imagine imaginary rigid bars connecting all the imaginary clocks.
Then you imagine that you synchronize all these clocks. Well, you immediately run into the problem that they don't all run at the same rate. You can see this from actual measurements here on Earth (as well as theoretical predictions form GR). So you start adjusting the actual clocks reading in such a way that you can synchronize them, according to some agreed-upon scheme (which generally boils down to the Einstein clock synchronization convetion) and start calling this adjustment that you need to impose "time dilation".
And you call this mental construct "reality". But it's really a rather complex structure that you've built up in your mind. And there are a lot of assumptions that go into making it all work an hang together.
When you start assuming that this mental structure is "more real" than the reading you can take on what you can imagine as a single, physical, clock, is where you start to get into trouble. One way that happens is when you start taking the "time dilation" that you had to posit to account for the fact that the clocks all ticked at different rates, as being "real" , "more real" than the actual clock reading somehow. But actually, the time dilation depends on a lot of tiny little details, involving how you set up your infinite array of non-existent mentally imagined clocks in the first place. It depends on how you set up your mental construct, it's a property of the map of reality you're trying to construct, it depends on your choice of coordinates.
But if you step back and look at the bigger picture, at least one of the implicit properties (that you can create a rigid structure of imagiary clocks that fill all of space),a property that you've just ASSUMED can be satisfied, isn't satisfied by black holes.
We've said this before, but it mostly gets ignored. Possibly because of the language used.
So, I'll repeat it with emphasis, in the hope it get's through. (Though if the problem is linguistic, rather than one of attention in such a huge, meandering thread) the emphasis might not help.
There are no static observers at the event horizon of a black hole
So, you really can't extend the "infinite stationary clocks connected by rods" sort of mental structure to encompass a black hole. The mental structure isn''t compatible.
But, having (apparently) given this rather complex mental structure "reality", the nay-sayers put it, beyond reproach, and don't think about it's flaws. And thus they say - there is no reality at the event horizon.
Some of us / many of us point out that the more primitive structrues - the idea that clocks "exist" and you can measure time with them - doesn't have any such problems, but this observation just gets pushed aside. How, I don't know. Wishful thinking is my diagnosis, to be honest.
So in short people wind up so attached to their big, complicated mental sturcture underlying the idea of "an observer" that they throw out the much simpler point about being able to use clocks to measure time, and ignore the simpler results (that don't need any such big assumptions) as being in conflict with what they want to believe.
Furthermore, the fact that you can't "see" beyond the event horizon has a significance that's generally overstated. If you can take the limit of a function you can exactingly say "the limit of proper time as you approach the event horizon is finite and can be measured by an external observer - but only in the limit".
Anyway, this turned out to be longer than I thought. I hope writing it is not as big a waste of my time as I fear it might be.
