Drivetrain efficiency is a function of what?(gear ratio,eng.speed )
In summary: Modern autos lock up at very low rpm so are much better. Autos also require oil pumps for hydraulics.Chrisxx is spot on as usual.In summary, the conservation of energy states that no matter what gear ratio 'i' I choose, P_out=P_in. The drivetrain efficiency is a function of engine speed and engine torque, but is also a constant.
marellasunny
255
By the conservation of energy, P_in=P_out
So,no matter what gear ratio 'i' I choose, P_out=P_in, since the gear ratio 'i' term would get canceled at the numerator and denominator.
$$P_{eng}= ω_{eng} M_{eng}= i . ω_{out} \frac{M_{out}}{i}$$
hence P_in=P_out
But, what is the drivetrain efficiency a function of? Is it a function of gear ratio and engine speed and engine torque? Or is it a constant always?
2.And why is the drivetrain efficiency of automatic transmissions 10% lesser than manual? [source page 417:Advanced Direct Injection Combustion Engine Technologies and Development ...
edited by H Zhao]
Making the assumption that P_out = P_in
Its P_out = P_in - P_losses
The key is what are the losses? Off the top of my head:
Bearing drag
Oil windage
Misalignment
Transmission error
Etc
Obviously friction related losses will increase with speed.
Traditionally the majority of automatic efficiency loss is due to slip in the torque converter. Modern autos lock up at very low rpm so are much better. Autos also require oil pumps for hydraulics.
Chrisxx is spot on as usual. I would add that unless you are working in a vacuum ( sick pun) you also have to look at Aerodynamic Drag.
There is a basic equation for the force it takes to push something through air:
Aerodynamic drag = 1/2 D x A x V squared
In this equation, D is the density of the air, A is the frontal area of the moving shape, and V is its velocity relative to the air
For real body shapes, air at standard conditions, A in square ft., V in mph, and drag in pounds of force, this equation becomes:
Drag = 1/391 x Cd x A x V squared
This equation shows that to calculate drag you need to know three things: Cd, the drag coefficient; A, the frontal area of whatever you’re driving through the air; and the speed of air past it. This equation shows an important point—aerodynamic forces are proportional to the square of the speed. That means you quadruple the drag or lift when you double the speed.
Note that the power needed to push an object through a fluid increases as the cube of the velocity. A car cruising on a highway at 50 mph (80 km/h) may require only 10 horsepower (7.5 kW) to overcome air drag, but that same car at 100 mph (160 km/h) requires 80 hp (60 kW). With a doubling of speed the drag (force) quadruples per the formula. Exerting four times the force over a fixed distance produces four times as much work. At twice the speed the work (resulting in displacement over a fixed distance) is done twice as fast. Since power is the rate of doing work, four times the work done in half the time requires eight times the power. It's important to value the rolling resistance in relation to the drag force. Rotational weight of drive line components and parasitic drag must be considered too.
If you think about the manual transmission vs automatic trans. thing the manual trans set up is straight line to the differential. Usually is lighter than the automatic. The automatic trans is converting mechanical power to fluid power than back to mechanical power with heat being the culprit for power loss by thee conversion process. It is a trade off for smoother drive and automatic gear changing but is heavier and required additional oil cooler, more trans fluid, adds heat and weight.
To add to Ranger_Mike's automatic info...even with a lock-up converter, you're still driving the transmission pump.
1. What is drivetrain efficiency?
Drivetrain efficiency refers to the ability of a vehicle's drivetrain system to transfer power from the engine to the wheels with minimal energy loss.
2. How is gear ratio related to drivetrain efficiency?
Gear ratio is the ratio of the number of teeth on the driving gear (such as the engine) to the number of teeth on the driven gear (such as the wheels). It directly affects the amount of torque and speed that can be transferred to the wheels, thus impacting drivetrain efficiency.
3. How does engine speed affect drivetrain efficiency?
Engine speed, or revolutions per minute (RPM), is the rate at which the engine is rotating. Drivetrain efficiency is affected by engine speed because it determines the amount of power and torque that the engine is producing, which is then transferred to the wheels.
4. What factors can affect drivetrain efficiency other than gear ratio and engine speed?
Other factors that can affect drivetrain efficiency include friction, weight of the vehicle, and the condition of the drivetrain components, such as the transmission and axle.
5. How can drivetrain efficiency be improved?
Drivetrain efficiency can be improved by using higher quality components, reducing friction through proper lubrication and maintenance, and optimizing gear ratios and engine speed for the specific vehicle and its intended use.
  • Mechanical Engineering
  • Poll
24K
10K
