Correct Representations of the Momentum Principle
In summary: I was able to answer it by myself. I may have gotten a few wrong but I think I got most of them right. I'm not going to post my answer here though as it would likely be too similar to the other answer posted.
The Wanderer
There are two parts to this question...
a)Which of the following are correct representations of The Momentum Principle? (assuming a small-enough Δt whenever it shows up)
1) [itex]\frac{Δ\vec{p}}{Δt}[/itex] = [itex]\vec{F}[/itex]|| + [itex]\vec{F}[/itex]
2) For every action there is an equal and opposite reaction.
3) pf, y = pi, y + Fnet, yΔt
4) [itex]\frac{d\vec{p}}{dt}[/itex] = [itex]\vec{F}[/itex]net
5) [itex]\vec{p}[/itex]f = [itex]\vec{p}[/itex]i + [itex]\vec{F}[/itex]netΔt
6) [itex]\vec{p}[/itex] = [itex]\vec{F}[/itex]netΔt
7) pf, x = pi, x + Fnet, xΔt
8) pf, z = pi, z + Fnet, zΔt
9) [itex]\vec{r}[/itex]f = [itex]\vec{r}[/itex]i + [itex]\vec{v}[/itex]avgΔt
10) [itex]\vec{F}[/itex]=m[itex]\vec{a}[/itex]
11) The momentum of a system is conserved.
12) The rate of change of momentum of a system is proportional to the net external force on the system.
b) Which of the following are true statements? (again, assuming a small-enough Δt)
1) [itex]\vec{p}[/itex] = [itex]\vec{F}[/itex]netΔt
2) [itex]\vec{p}[/itex]f = [itex]\vec{p}[/itex]i + [itex]\vec{F}[/itex]netΔt
3) The rate of change of momentum of a system is proportional to the net external force on the system.
4) For every gravitational and electrostatic force that one object exerts on another, there is an equal and opposite reaction force from the second object on the first.
5) pf, z = pi, z + Fnet, zΔt
6) pf, x = pi, x + Fnet, xΔt
7) [itex]\vec{r}[/itex]f = [itex]\vec{r}[/itex]i + [itex]\vec{v}[/itex]avgΔt
8) [itex]\frac{d\vec{p}}{dt}[/itex] = [itex]\vec{F}[/itex]net
9) For every action there is an equal and opposite reaction.
10) [itex]\frac{Δ\vec{p}}{Δt}[/itex] = [itex]\vec{F}[/itex]|| + [itex]\vec{F}[/itex]
11) [itex]\vec{F}[/itex]=m[itex]\vec{a}[/itex]
12) pf, y = pi, y + Fnet, yΔt
13) The momentum of a system is conserved.
Relevant equations are basically listed above.
My first attempt was this...
a) 3,5,6,7,8,11,12
b) 1,2,3,4,5,6,9,12,13
My second attempt is this...
a) 2,3,4,5,6,7,8,11,12
b) 1,2,3,4,5,6,7,8,9,11,12,13
both of which are wrong. I'll talk about why I don't think it is the ones I didn't choose as that will be easier.
1a - I didn't think that all of the forces or the net force can be summed up as the sum of the parallel forces and the perpendicular forces.
9a - I didn't think that equation is a correct representation of the Momentum Principle as that has to do with velocity not momentum (more precise it is the velocity update formula)
10a - I wasn't sure if the equation for Force was a representation of the Momentum principle.
10b-Again I didn't think that all of the forces or the net force can be summed up as the sum of the parallel forces and the perpendicular forces.
Any help would be appreciated in explaining why I am wrong as I only get three submissions and I've used two already haha. Thanks.
Those lists are much too long for us to comment on them one by one. You will have to list the ones you want to discuss, and for each one, attempt to explain why it should or shouldn't be included in your answer.
I started answering b10 because I thought the ones you listed at the end were the ones you wanted help with. This is a partial answer for b10: (We can't give you complete answers in the homework forum).
dp/dt is the force. Do you understand why? So the statement is just saying that the force can be split up into two component vectors that are orthogonal to each other. Can you come up with a reason why this should or shouldn't be possible?
Edit: OK, so you probably saw the much too complete answer I gave you for b10 before I realized my mistake and replaced it with the hints above.
Likes 1 person
Okay so I was wrong on b10 and a1 haha. I was looking at it wrong I was thinking it was saying all forces are either parallel or perpendicular to the momentum but what it is saying is all the component vectors can be split into those two pairs which makes sense to me. Really you don't have too look at them all but mostly a9 and a10 as I am quite confident the ones I did choose as correct are correct but I wasn't sure on a1, a9, a10, and b10, but you answered b10 and a1.
OK, so the ones you listed at the end are the ones you want help with. That's good to know. Unfortunately I don't have time right now, so I'm leaving it for someone else.
Yeah maybe I should have made that more clear. Thank you very much for your help.
How did you answer this question? I have the same one and I'm struggling on it.
Thread closed temporarily for Moderation...
What is the Momentum Principle?
The Momentum Principle, also known as the Law of Conservation of Momentum, states that in a closed system, the total momentum of the system remains constant. This means that the total momentum before an event or interaction is equal to the total momentum after the event or interaction.
Why is the Momentum Principle important?
The Momentum Principle is important because it allows us to predict and understand the motion of objects in a system. It also helps us to analyze and explain various physical phenomena, such as collisions and explosions.
How is the Momentum Principle related to Newton's Laws of Motion?
The Momentum Principle is closely related to Newton's Laws of Motion. Newton's First Law states that an object will remain at rest or in motion at a constant velocity unless acted upon by an external force. The Momentum Principle explains this concept by stating that the total momentum of an object will remain constant unless acted upon by an external force.
What are some real-life examples of the Momentum Principle?
Some real-life examples of the Momentum Principle include: a billiard ball colliding with another billiard ball, a car crash, a rocket launching, and a ball bouncing off a wall. In each of these situations, the total momentum before the event is equal to the total momentum after the event.
How can the Momentum Principle be applied in engineering and technology?
The Momentum Principle is used in various engineering and technological applications, such as designing car airbags, creating efficient rocket propulsion systems, and developing safety devices for amusement park rides. It is also used in sports equipment, such as helmets and padding, to help reduce the impact of collisions. By understanding and applying the Momentum Principle, engineers and technologists can design safer and more efficient systems.
