New Reply
offset voltage with bipolar transistor
Share Thread
Feb27-13, 02:14 PM   #1
I have a few questions about offset voltage for a bipolar transistor...
A. Why is this value not specified on datasheets? My EE book says it is usually between 0.6 and 0.7 for silicon, and provides its exact value in textbook problems. Besides experimental measurement, how could I know this from a datasheet?
B. Does this value change depending on operating region? Does this offset voltage even exist during cutoff?
Thanks.
PhysOrg.com engineering news on PhysOrg.com
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
>> Faster, more precise airstrikes within reach
>> How smart technology could change public transit
Feb27-13, 02:27 PM   #2
The value varies with bias current and temperature and probably with the doping of each particular batch of transistors. The reason it isn't specified is that 1. the chances that your circuit will use precisely the same current and temperature as the test circuit are nil and 2. it's not really important anyway. It is easy to design around a small variation in that voltage. I'm sure the values used in textbooks are arbitrary values.
I measured a few small signal transistors and found that the voltage varied from about 0.55 V at 55 C to about 0.73 at -30 C with 0.65 C being fairly normal for room temperature.
New Reply
Similar discussions for: offset voltage with bipolar transistor
Thread Forum Replies
Can a bipolar transistor work with Ib < 0? Electrical Engineering 13
β on NPN bipolar transistor Introductory Physics Homework 2
bipolar transistor question.. Electrical Engineering 1
Bipolar Junction Transistor Engineering, Comp Sci, & Technology Homework 3
bipolar transistor amplifier Electrical Engineering 4
