How did Heisenberg derive his famous principle?
In summary, Heisenberg's uncertainty relations were based on mathematical principles that had been known for some time, and were later applied to quantum mechanics.
Michio Cuckoo
84
Where
How did he come up with that?
If I'm not mistaken Heisenberg himself didn't 'derive' the principle, he thought experimented it and got [itex]\Delta x \ \Delta p \approx \hbar[/itex]
It was later on that other people found general formulas for uncertanties related with any operators;
[itex]\sigma _A \sigma _B \ge \frac{[A,B]}{2i}[/itex]
And since the commutator (the [A,B] part) for position and momentum is simply [itex]i\ \hbar[/itex] we get
[itex]\sigma_x \sigma_p \ge \frac{i\ \hbar}{2 i} = \frac{\hbar}{2}[/itex]
The mathematical inequality actually follows from Fourier analysis. It's application as a physical result -- to be interpreted as physical uncertainties of measurable quantities -- is generally taken to be an axiom of the theory.
Michio Cuckoo said:
Where
Check out "The Physical Principles of the Quantum Theory". First published around 1935 I think.
This means that a similar principle applies in other areas where we use Fourier analysis. For example, an electrical signal pulse contains a range of frequencies (or wavelengths) that is inversely proportional to the time duration or spatial width of the pulse. Likewise for pulses of electromagnetic radiation (e.g. light).
This has been known since probably sometime in the 1800s, so when physicists started to think of describing particles using waves, and superpositions of them, it was only a matter of time before someone applied this general uncertainty principle to QM.
This is an enlightening observation, imho. The Heisenberg uncertainty relations weren't just plucked from nothing. They have historical, mathematical basis. Heisenberg, like Einstein, Bohr, de Broglie, Jordan, Dirac, et al., was a genius of sorts, but not a magician. Everything to do with the development of the quantum theory has some basis in prior mathematics and classical conceptualization. Or so I like to believe.
I don't really understand the basis for Heisenberg's matrix mechanics, and I don't really understand the basis for Schroedinger's wave equatiion. But those are topics for other threads.
Well, everyone "knew" that QM was about matter waves. Heisenberg was fiddling around with algebra of Hermitian operators that acted on physical states, but what was missing was a wave equation that actually described the evolution of these states. The impetus to develop a wave equation was largely driven by de Broglie's result and the experimental indications of the wave nature of matter.
Thanks bapowell. Every bit of input from certain perspectives helps. But I fear that I might be too old (and too lazy) to ever really understand this stuff.
Schrödinger's invention of his famous equation (1925-26) actually preceded the Davisson-Germer experiment (1927) which as far as I know was the first direct verification of de Broglie's hypothesis (1924) that electrons have wavelike properties.
Schrödinger came up with his equation by making an analogy between mechanics and optics, which has two distinct "pictures"; geometrical or ray optics on one hand, and wave optics on the other. He reasoned that classical mechanics of particles might be analogous to ray optics, and invented a new mechanics which is analogous to wave optics:
https://www.physicsforums.com/showthread.php?p=418069#post418069
The early development of modern quantum mechanics is based on guesses like this. Schrödinger, Heisenberg and others were groping around, trying to come up with something that works. Only gradually did these bits and pieces come together into what you see in today's textbooks.
Huh. I need to refresh my history. I recall reading that Schroedinger and Co. had some inklings that matter had wave-like properties, and that's what directed him to "look" for a wave equation. Were there any other experiments being done at the time that might have provided hints of wave-particle duality?
Hey, a quick question.
Isn't the relation dependent on the method we are using to find the variables (like x and v of electron?
Like on the microscope?
Like for eg if I had superman eyes (i hope this assumption is not an infraction.I am trying to make a point :-) )then I would be able to see the electron move,see exactly where it is and also calculate its exact velocity.No problem would occur.
Nope, it is completely independant of any measuring apparatus although this is commonly used as a way to explain it for the case of the x-p uncertainty before we learn that they are a Fourier transform away from each other.
No matter what your measuring device you will never be able to tell its position and momentum exactly.
Take a dirac delta function (or a wave with one really big spike somewhere), you can tell where it is but you cannot tell it's frequency since it's just one spike. Similarly, take a uniform sine wave, you can tell it's frequency but you cannot tell where it is.
This is more the nature of the x-p uncertainty principle.
If, in the position basis we have a delta function (this just means we know its position exactly) we cannot gain any useful information about its momentum (we cannot tell it's frequency). If we have a delta function in the momentum basis (we know it's momentum exactly) we have a specific frequency (just like the uniform sine wave) and we cannot gain any information about its position.
We can get interesting little 'wave packets' where we can have some information about the position and some about the momentum, the gaussian wavepacket gives us the minimum uncertainty [itex]\sigma_x \sigma_p = \frac{\hbar}{2}[/itex]
Also, going back to your superhuman eyes example, for these super human eyes to be able to give precice information about where the electron is, you need to bombard it with short and shorter wavelength photons which have higher and higher energies. If you bombard it with long wavelengthed photons, you won't disturb it much but you can essentially only know if the electron is in an area of size proportional to the wavelength of the photon.
Oh.Now i get it.
The way they usually talk about in books, led me to think it was an apparatus dependent error.
Thanks a lot for clearing that up :-)
emailanmol said:
Oh.Now i get it.
No problem buddy :biggrin:
1. How did Heisenberg come up with his famous uncertainty principle?
Heisenberg derived his uncertainty principle through a thought experiment involving measuring the position and momentum of a particle. He realized that the more precisely one of these properties is measured, the less precisely the other can be known. This led to the principle that the more we know about one property, the less we know about the other.
2. What is the mathematical equation for Heisenberg's uncertainty principle?
The mathematical equation for Heisenberg's uncertainty principle is ΔxΔp ≥ ħ/2, where Δx represents the uncertainty in position, Δp represents the uncertainty in momentum, and ħ is the reduced Planck's constant.
3. How does Heisenberg's uncertainty principle relate to quantum mechanics?
Heisenberg's uncertainty principle is a fundamental concept in quantum mechanics, which is the branch of physics that explains the behavior of particles on a very small scale. It states that there are inherent limitations to how precisely we can know certain properties of a particle, and this is a key principle in understanding the probabilistic nature of quantum mechanics.
4. Can Heisenberg's uncertainty principle be violated?
No, Heisenberg's uncertainty principle is a fundamental principle of quantum mechanics and has been experimentally verified many times. It is not possible to violate this principle, but it can be applied to our advantage in certain situations, such as in quantum cryptography.
5. How has Heisenberg's uncertainty principle impacted our understanding of the physical world?
Heisenberg's uncertainty principle has revolutionized our understanding of the physical world, especially in the field of quantum mechanics. It has led to the development of new theories and technologies, such as the development of quantum computers and the understanding of the behavior of subatomic particles. It has also challenged our traditional ideas of determinism and causality, and continues to be a topic of ongoing research and debate in the scientific community.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
