Question: Space Vector PWM in Matlab/Simulink & 5V-15V Interface circuit
In summary: Your Name]In summary, Ken-ji is seeking help with designing a Space Vector PWM circuit block connected to his DS1102 PWM hardware block in Simulink. He has received advice from dSPACE support and another person regarding using an open collector output and a logic level device to pull the cathode to ground. He also needs to design an interface circuit between the 5V output of the PWM block and a 15V inverter input. He has been advised to use a line driver instead of single resistors. For information on Space Vector Pulse Width Modulation, he has been directed to a paper on designing a CMEX SVPWM in Matlab. Ken-ji is looking for assistance from someone knowledgeable in Matlab.
wongkenji
Hi Everyone,
I'm new here and I hope someone can help me with my project. I need to design a Space Vector PWM circuit block connected to my DS1102 PWM hardware block in Simulink. Anybody have any ideas?
Here's what the dSPACE support people wrote:
Here is some advice from hardware development. As far as we see you need an open collector output to pull the cathode (pin 2 of the H11L1 opto coupler) to GND when the DS1102 PWM output is high, and to leave the pin open when PWM is low. Attached is a basic schematic of a circuit to use for this purpose. We cannot dimension the components for your, you will probably need some help of a circuit designer to complete this if you cannot determine the component values yourself.
Note that the PWM outputs of the DS1102 are directly provided by the TMS320P14 slave DSP. The DSP's digital I/O lines are very limited to only IOH high-level output current : -300 µA and IOL low-level output current : 2 mA.
http://img.photobucket.com/albums/v2...ET_Circuit.jpg
I've asked another person and he said that I need a logic level device that will be switched on by the logic level specification. What is a logic level device?
My second question is about designing an interface circuit between the 5V output of the DS1102 PWM block and a 15V inverter input. I've asked the dSPACE people for help but I'm still quite unclear about the circuit as there are no values to the resistors. My tutor also told me to use a line driver instead of using just single resistors which will take up too much space and it'll be bulky. I have no idea how to use a line driver as I've never encountered one before.
For some information about Space Vector Pulse Width Modulation, try looking at this: http://eee.ucc.ie/research/control/p...cmex_paper.pdf
There's some guidelines on how to design a CMEX SVPWM in Matlab but I have no idea how to do it. Anyone good with Matlab?
Hope someone will be able to help.
Cheers,
Ken-ji
Dear Ken-ji,
Thank you for reaching out for help with your project. I am a scientist with experience in designing circuits and working with DSPs, and I would be happy to offer some suggestions and guidance.
Firstly, to address your question about a logic level device, this is a component that operates at the logic levels (high and low) that are specified by the DSP's digital I/O lines. In this case, you will need a logic level device that can handle the low-level output current of 2 mA and can be switched on by the logic level specification. Some options for logic level devices include MOSFETs, BJTs, and IGBTs. You will need to choose a device that can handle the required current and voltage levels for your specific circuit.
As for designing an interface circuit between the 5V output of the DS1102 PWM block and the 15V inverter input, this can be done using a level-shifting circuit. This circuit will convert the 5V signal to a 15V signal that can be used by the inverter. Again, the specific values for the resistors will depend on the components you choose and the requirements of your circuit. I would recommend consulting with a circuit designer or doing some research on level-shifting circuits to determine the appropriate values for your specific application.
Regarding the Space Vector PWM circuit block, I would recommend looking into using a CMEX SVPWM implementation in Matlab. This will allow you to simulate and test your circuit before implementing it with the DS1102 PWM hardware block. The link you provided (http://eee.ucc.ie/research/control/p...cmex_paper.pdf) has some helpful guidelines on designing a CMEX SVPWM in Matlab. Additionally, I would suggest reaching out to other engineers or researchers who have experience with Matlab and DSPs for further assistance.
I hope this information helps you in your project. Best of luck and please let me know if you have any further questions.
Hi Ken-ji,
Thank you for reaching out for help with your project. Designing a Space Vector PWM circuit in Matlab/Simulink can be a challenging task, but with some guidance and resources, it is definitely achievable.
Firstly, for your first question about the logic level device, it is a type of electronic component that is designed to operate with logic level signals, which are typically in the range of 0-5V. This means that the device can be easily switched on or off by a logic level signal. Examples of logic level devices include MOSFETs and transistors. In your circuit, you will need to use a logic level device to control the opto-coupler and pull the cathode to ground.
For your second question about designing an interface circuit between the 5V output of the DS1102 PWM block and a 15V inverter input, there are a few approaches you can take. One option is to use a level shifter circuit, which will convert the 5V logic level signal to a 15V signal for your inverter. Another option is to use a line driver, as suggested by your tutor. A line driver is a device that can amplify and buffer the signal, making it stronger and more suitable for driving the inverter. You can find some resources online on how to use a line driver, or you can consult with a circuit designer for assistance.
As for designing a CMEX SVPWM in Matlab, the paper you provided is a good starting point. You can also refer to the Matlab documentation for implementing SVPWM algorithms. Alternatively, you can also reach out to the Matlab community for assistance.
I hope this helps and good luck with your project!
1. What is Space Vector PWM and how is it used in Matlab/Simulink?
Space Vector Pulse Width Modulation (SVPWM) is a modulation technique used to control the output voltage of three-phase inverters in power electronics. In Matlab/Simulink, SVPWM is used as a control strategy to generate the switching signals for the power inverter, allowing for better control and efficiency of the system.
2. Can SVPWM be implemented in any type of interface circuit?
Yes, SVPWM can be implemented in various types of interface circuits, such as voltage source inverters, current source inverters, and neutral-point-clamped inverters. The specific implementation may vary depending on the type of inverter and the desired control strategy.
3. What are the main advantages of using SVPWM in power electronics?
SVPWM offers several advantages over traditional PWM techniques, including higher efficiency, better utilization of DC bus voltage, and reduced harmonic distortion in the output voltage. It also allows for smoother control of the output voltage and lower switching losses.
4. Are there any limitations to using SVPWM in Matlab/Simulink?
One limitation of using SVPWM in Matlab/Simulink is that it requires a good understanding of the technique and its implementation. Additionally, the model may become more complex and computationally intensive as the system size increases, which can affect simulation performance.
5. How can I verify the performance of my SVPWM implementation in Matlab/Simulink?
You can verify the performance of your SVPWM implementation by comparing the simulation results with experimental data or by using built-in simulation tools in Matlab/Simulink, such as the Simulink Design Verifier or the Simulink Control Design. It is also important to validate the results with theoretical analysis and by considering the limitations and assumptions of the model.
