| New Reply |
Conservation of Angular Momentum |
Share Thread | Thread Tools |
| Feb21-13, 12:52 AM | #1 |
Here's the scenario:
A uniform stick of length L and mass M lies on a horizontal surface. A point particles of mass m approaches the stick with velocity v on a straight line perpendicular to the stick that intersects with the stick at one end. After the collision, the particle is at rest. My question is, the angular momentum should be conserved in this system right? After the collision, the stick will gain angular momentum as it will be rotating (as well as translating) after the collision. But initially, the particle could either have or do not have angular momentum depending on whether the particle is rotating. Assuming that the particle does not rotate, then the particle should not have any angular momentum. Then in this case how is the angular momentum conserved? The initial angular momentum would be zero initially and non-zero after the collision right? "The law of conservation of angular momentum states that when no external torque acts on an object or a closed system of objects." In this case the torque is an internal torque in the particle-stick system right? Please help thanks. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Feb21-13, 01:18 AM | #2 |
Mentor
However, the particle can have angular momentum around a point. Angular momentum is not associated only with the rotation (spin) of extended bodies. It is also associated with the motion of a point particle relative to some reference point. For example, for a system consisting of a planet orbiting a star, there is some angular momentum associated with the orbit of that planet around the star (not just the spin of the planet around its axis). In other words, even if the planet weren't spinning, just orbiting in a circle, the system would still have angular momentum. For a point particle moving with linear momentum p, the angular momentum L of that particle around some reference point is given by the equation$$\mathbf{L} = \mathbf{r}\times\mathbf{p}$$where r is a position vector going from the reference point to the particle. So, even if the particle isn't spinning (which it can't), there is still non-zero angular momentum initially. |
| Feb21-13, 01:31 AM | #3 |
| Feb21-13, 01:34 AM | #4 |
Conservation of Angular MomentumAs the particle moves, the angular momentum of the particle will vary as it moves right? So in this problem we calculate the angular momentum of the stick from the pivot of the stick which is at the end of the stick opposite to where the particle collides with it. So I should also use that pivot as a reference point to calculate the angular momentum of the particle right. So the initial momentum before collision should be: L=r x p = L x mv = Lmv. Correct? |
| Feb21-13, 01:38 AM | #5 |
| Feb21-13, 02:04 AM | #6 |
Mentor
| Feb21-13, 02:12 AM | #7 |
Thanks again! |
| Feb21-13, 02:19 AM | #8 |
Try to calculate by yourself and see if you get the same answer |
| Mar14-13, 11:08 PM | #9 |
What about rotational angular momentum, e.g a disc that is rotating. Does the angular momentum depends on where my point of reference is?
| Mar15-13, 10:54 AM | #10 |
Mentor
| New Reply |
| Thread Tools | |
Similar Threads for: Conservation of Angular Momentum
| Thread | Forum | Replies | ||
| angular momentum and conservation of angular momentum problem | Introductory Physics Homework | 0 | ||
| Linear momentum conservation vs angular momentum conservation | Classical Physics | 2 | ||
| Conservation of Angular Momentum: angular speed | Introductory Physics Homework | 3 | ||
| Finding angular velocity using conservation of angular momentum | Introductory Physics Homework | 2 | ||
| Law of the Conservation of Angular Momentum > Principle of Conservation of Momentum | General Engineering | 0 | ||
